Camera Mic not Picking Up
NoahEH94
I am using a Ordro 4K camera that came with the Ordro CM-520. When I record a video on just the camera with out a capture card or OBS, the audio records fine, but as soon as I open OBS and try to record through the capture card, the audio is not picked up. I have tried to change the default mic/aux to the capture card, but that did not work. I also can plug the microphone directly into my computer's aux port and OBS will record the audio from the mic that way. Any help on this?
  • 2020-08-24 10-58-37.txt
SpectreKid
I cannot determine what is particularly wrong based on the log you provided, so what I can suggest is to export your profile and scene collections and reinstall OBS to see if that may help. Other than that, make sure that you have chosen the correct microphone when you plugged it in inside of OBS Studio, and make sure that the audio tracks that the camera's microphone is designated in is being recorded by OBS. Other than that, I don't know.
