Bug Report Bluetooth speaker crashes all audio
ed022
This set up was working until - to my knowledge - just the other day. I have a Bluetooth speaker set as my default audio device, and OBS is set to use said default audio device for streaming. Just recently, it would crash when I start to stream. But not just a simple crash; it actually disables the speaker/device entirely until OBS has completely closed, then it releases it and any buffered sounds might then play. This does not happen with my laptop speakers as the default audio device, and, I reiterate, it didn't happen until just recently. Any thoughts?
https://obsproject.com/ - include the contents of this crash log and the
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 00007FF94D102D52 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.658b
Windows version: 10.0 (Build 10586)
CPU: Intel(R) Core(TM) i5-4300U CPU @ 1.90GHz
Crashing thread stack trace:
0000002316F6EFC8 00007FF94D102D52 00007FF928E80C60 0000000000007531 0000002316F6EF28 0000002316F6F069 kernelbase.dll!0x7ff94d102d52
0000002316F6EFD0 00007FF928E514B3 0000016C1C25B470 00007FF6AB8675A0 0000016C1C25B470 00007FF900000002 obsapi.dll!OSTerminateThread+0x33
0000002316F6F000 00007FF6AB7AE9F1 0000002316F6F1D0 000000000000138B 00000000000F057C FFFFFFFF9601101E obs.exe!OBS::Stop+0x1e1
0000002316F6F0D0 00007FF6AB7DD43F 0000000000000000 0000000000000000 0000000000000048 0000000000000001 obs.exe!OBS::OBSProc+0xecf
0000002316F6F320 00007FF950171169 0000016C1C7E4620 00007FF6AB7DC570 00000000000F057C 0000000000000111 user32.dll!0x7ff950171169
0000002316F6F410 00007FF9501708F5 0000000000000000 00007FF950171300 000000000000138B 0000016C1C7E4620 user32.dll!0x7ff9501708f5
0000002316F6F4A0 00007FF95017065B 0000016C1C1FD3F0 0000000054010001 0000000000000001 00007FF9507D5253 user32.dll!0x7ff95017065b
0000002316F6F500 00007FF9377E80DE 0000000000000202 0000002316F6F5B8 0000016C1C1FD3F0 0000000000000000 comctl32.dll!0x7ff9377e80de
0000002316F6F540 00007FF9377AF9F7 0000000000000000 00007FF950164246 0000000000000000 0000000000000001 comctl32.dll!0x7ff9377af9f7
0000002316F6F600 00007FF950171169 0000016C1C7EA150 00007FF9377AF250 000000000007057E 0000002317189800 user32.dll!0x7ff950171169
0000002316F6F6F0 00007FF950170C97 0000016C1C287710 0000000000000000 0000000000000001 0000000000000000 user32.dll!0x7ff950170c97
0000002316F6F770 00007FF950173B8F 0000000000070428 0000002316F6F8D0 0000016C1C287710 0000016C1C287710 user32.dll!0x7ff950173b8f
0000002316F6F7D0 00007FF6AB79D929 0000000000000000 00007FF6AB770000 0000000000000000 0000000000000000 obs.exe!WinMain+0xb79
0000002316F6FD90 00007FF6AB81F2C0 0000000000000000 00007FF6AB81F164 0000002317188000 0000000000000000 obs.exe!__tmainCRTStartup+0x148
0000002316F6FDD0 00007FF9503E8102 00007FF9503E80E0 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff9503e8102
0000002316F6FE00 00007FF95081C5B4 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff95081c5b4
Video thread stack trace:
00000023182FF2F8 00007FF950865164 0000000000000002 00007FF928E57882 0000016C1C25B470 0000011A8439515E ntdll.dll!0x7ff950865164
00000023182FF300 00007FF94D05AADF 0000000001FCA055 0000000000000000 0000011A00000000 0000000000000208 kernelbase.dll!0x7ff94d05aadf
00000023182FF3A0 00007FF6AB7B5B9D 00007FF6AB7B2470 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureLoop+0x1c3d
00000023182FF830 00007FF6AB7B2479 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureThread+0x9
00000023182FF860 00007FF9503E8102 00007FF9503E80E0 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff9503e8102
00000023182FF890 00007FF95081C5B4 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff95081c5b4
Encode thread stack trace:
00000023181FF7B8 00007FF950865764 00000023181FF878 0000000000001E97 0000000000000000 0000000000001727 ntdll.dll!0x7ff950865764
00000023181FF7C0 00007FF94D0838C7 0000011A873441DC 0000011A00000000 0000002300000000 0000000000000000 kernelbase.dll!0x7ff94d0838c7
00000023181FF860 00007FF6AB7B3525 0000000000000000 00007FF6AB7B2460 0000000000000000 0000000000000000 obs.exe!SleepToNS+0x65
00000023181FF890 00007FF6AB7B397B 0000000000000001 0000000000000001 0000000000000000 0000000000000000 obs.exe!OBS::EncodeLoop+0x20b
00000023181FF9D0 00007FF6AB7B2469 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::EncodeThread+0x9
00000023181FFA00 00007FF9503E8102 00007FF9503E80E0 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff9503e8102
00000023181FFA30 00007FF95081C5B4 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff95081c5b4​
ed022
Here's a workaround I found: In the Windows "Recording Devices" screen, disable the bluetooth speaker, and instead enable Stereo Mix, and set it as the default recording device. Not entirely sure why that sorted it, but, here's hoping that it'll either help sort the bug entirely and/or help others encountering this bug in the future.
