Hello guys.
I don't know what it is but the box at the right bottom corner in obs, where the current bitrate is, is blinking green/yellow. I can even set a lower bitrate, but it doesn't help. My average uploadspeed is 2.3 MB (tested few times on testmy.net).
It's only blinking if i capture something. If the screen is black it seems okay. Any idea?
My specs:
i5 2500k @ 4.4GHz (60% max cpu usage while streaming, even tested "veryfast" x264 preset)
Asus GTX 660 TI
8gb ram
1.9 mb set in obs
My specs:
Asus GTX 660 TI
8gb ram
1.9 mb set in obs
18:35:49: Open Broadcaster Software v0.551b - 64bit ( ^ω^)
18:35:49: -------------------------------
18:35:49: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
18:35:49: CPU Speed: 3309MHz
18:35:49: Physical Memory: 8109MB Total, 4075MB Free
18:35:49: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
18:35:49: monitor 1: pos={0, 0}, size={1920, 1080}
18:35:49: monitor 2: pos={1920, 0}, size={1280, 720}
18:35:49: Windows Version: 6.1 Build 7601 S
18:35:49: Aero is Enabled
18:35:49: OBS Modules:
18:35:49: Base Address Module
18:35:49: 000000003F290000 OBS.exe
18:35:49: 00000000E1A20000 OBSApi.dll
18:35:49: 00000000F1A80000 DShowPlugin.dll
18:35:49: 00000000F1900000 GraphicsCapture.dll
18:35:49: 00000000F6EC0000 NoiseGate.dll
18:35:49: 00000000F6F00000 PSVPlugin.dll
18:35:49: ------------------------------------------
18:35:49: Adapter 1
18:35:49: Video Adapter: NVIDIA GeForce GTX 660 Ti
18:35:49: Video Adapter Dedicated Video Memory: 2091319296
18:35:49: Video Adapter Shared System Memory: 2147807232
18:35:49: Adapter 2
18:35:49: Video Adapter: Intel(R) HD Graphics 3000
18:35:49: Video Adapter Dedicated Video Memory: 67108864
18:35:49: Video Adapter Shared System Memory: 1711276032
18:35:49: Using fixed low latency mode, factor 25
18:35:49: =====Stream Start: 2013-08-17, 18:35:49===============================================
18:35:49: Multithreaded optimizations: On
18:35:49: Base resolution: 1920x1080
18:35:49: Output resolution: 1280x720
18:35:49: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
18:35:49: Playback device Default
18:35:49: Using desktop audio input: Lautsprecher (C-Media PCI Audio Device)
18:35:49: Using 5.1 surround speaker setup
18:35:49: Using auxilary audio input: Tischmikrofon (HD-5000 - Microsoft LifeCam.)
18:35:49: Audio Encoding: AAC
18:35:49: bitrate: 96
18:35:49: Using custom x264 settings: "opencl=true"
18:35:49: Video Encoding: x264
18:35:49: fps: 30
18:35:49: width: 1280, height: 720
18:35:49: preset: faster
18:35:49: CBR: yes
18:35:49: CFR: no
18:35:49: max bitrate: 1900
18:35:49: MMDeviceAudioSource: Frequency for device 'Lautsprecher (C-Media PCI Audio Device)' is 1058400, samples per sec is 44100
18:35:49: MMDeviceAudioSource: Frequency for device 'Tischmikrofon (HD-5000 - Microsoft LifeCam.)' is 176400, samples per sec is 44100
18:35:50: Using Window Capture
18:35:51: Using RTMP service: Twitch / Justin.tv
18:35:51: Server selection: rtmp://live-fra.justin.tv/app
18:35:51: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
18:35:53: SO_SNDBUF was at 8192
18:35:53: SO_SNDBUF is now 65536
18:36:33: Using graphics capture
18:36:33: SharedTexCapture hooked
18:36:41: GraphicsCaptureSource::NewCapture: eliminating old capture
18:36:41: SharedTexCapture hooked
18:37:03: SharedTexCapture hooked
18:37:13: Using graphics capture
18:37:15: SharedTexCapture hooked
18:39:10: Total frames rendered: 6016, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
18:39:10: RTMPPublisher::SocketLoop: Graceful loop exit
18:39:10: Number of times waited to send: 0, Waited for a total of 0 bytes
18:39:10: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:39:11:
18:39:11: Profiler results:
18:39:11:
18:39:11: ==============================================================
18:39:11: frame - [100%] [avg time: 1.877 ms (cpu time: avg 1.682 ms, total 10124.5 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.16%]
18:39:11: | frame preprocessing and rendering - [38.7%] [avg time: 0.726 ms (cpu time: avg 0.619 ms, total 3728.42 ms)] [avg calls per frame: 1] [children: 7.19%] [unaccounted: 31.5%]
18:39:11: | | scene->Preprocess - [7.19%] [avg time: 0.135 ms (cpu time: avg 0.121 ms, total 733.202 ms)] [avg calls per frame: 1]
18:39:11: | video encoding and uploading - [61.2%] [avg time: 1.148 ms (cpu time: avg 1.063 ms, total 6396.04 ms)] [avg calls per frame: 1] [children: 59.6%] [unaccounted: 1.6%]
18:39:11: | | flush - [5.43%] [avg time: 0.102 ms (cpu time: avg 0.07 ms, total 421.202 ms)] [avg calls per frame: 1]
18:39:11: | | CopyResource - [0.479%] [avg time: 0.009 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:39:11: | | conversion to 4:2:0 - [0.213%] [avg time: 0.004 ms (cpu time: avg 0.005 ms, total 31.2 ms)] [avg calls per frame: 0]
18:39:11: | | call to encoder - [52.6%] [avg time: 0.987 ms (cpu time: avg 0.959 ms, total 5772.04 ms)] [avg calls per frame: 0]
18:39:11: | | sending stuff out - [0.852%] [avg time: 0.016 ms (cpu time: avg 0.012 ms, total 78 ms)] [avg calls per frame: 0]
18:39:11: | Convert444Threads - [3.54e+003%] [avg time: 66.477 ms (cpu time: avg 1.143 ms, total 6879.64 ms)] [avg calls per frame: 1]
18:39:11:
18:39:11: =====Stream End: 2013-08-17, 18:39:11=================================================
18:39:49: Using fixed low latency mode, factor 25
18:39:49: =====Stream Start: 2013-08-17, 18:39:49===============================================
18:39:49: Multithreaded optimizations: On
18:39:49: Base resolution: 1920x1080
18:39:49: Output resolution: 1280x720
18:39:49: ------------------------------------------
18:39:49: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
18:39:50: Playback device Default
18:39:50: ------------------------------------------
18:39:50: Using desktop audio input: Lautsprecher (C-Media PCI Audio Device)
18:39:50: Using 5.1 surround speaker setup
18:39:50: Using auxilary audio input: Tischmikrofon (HD-5000 - Microsoft LifeCam.)
18:39:50: Audio Encoding: AAC
18:39:50: bitrate: 96
18:39:50: Using graphics capture
18:39:50: Using custom x264 settings: "opencl=true"
18:39:50: Video Encoding: x264
18:39:50: fps: 30
18:39:50: width: 1280, height: 720
18:39:50: preset: faster
18:39:50: CBR: no
18:39:50: CFR: no
18:39:50: max bitrate: 1900
18:39:50: buffer size: 1900
18:39:50: quality: 5
18:39:50: MMDeviceAudioSource: Frequency for device 'Lautsprecher (C-Media PCI Audio Device)' is 1058400, samples per sec is 44100
18:39:50: MMDeviceAudioSource: Frequency for device 'Tischmikrofon (HD-5000 - Microsoft LifeCam.)' is 176400, samples per sec is 44100
18:39:50: SharedTexCapture hooked
18:39:52: Using RTMP service: Twitch / Justin.tv
18:39:52: Server selection: rtmp://live-fra.justin.tv/app
18:39:52: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
18:39:53: SO_SNDBUF was at 8192
18:39:53: SO_SNDBUF is now 65536
18:40:01: Total frames rendered: 313, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
18:40:01: RTMPPublisher::SocketLoop: Graceful loop exit
18:40:01: Number of times waited to send: 0, Waited for a total of 0 bytes
18:40:01: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:40:01:
18:40:01: Profiler results:
18:40:01:
18:40:01: ==============================================================
18:40:01: frame - [100%] [avg time: 1.73 ms (cpu time: avg 1.495 ms, total 468.004 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.231%]
18:40:01: | frame preprocessing and rendering - [41.2%] [avg time: 0.713 ms (cpu time: avg 0.647 ms, total 202.802 ms)] [avg calls per frame: 1] [children: 0.0578%] [unaccounted: 41.2%]
18:40:01: | | scene->Preprocess - [0.0578%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
18:40:01: | video encoding and uploading - [58.6%] [avg time: 1.013 ms (cpu time: avg 0.847 ms, total 265.202 ms)] [avg calls per frame: 1] [children: 57.1%] [unaccounted: 1.5%]
18:40:01: | | flush - [4.45%] [avg time: 0.077 ms (cpu time: avg 0.099 ms, total 31.2 ms)] [avg calls per frame: 1]
18:40:01: | | CopyResource - [0.52%] [avg time: 0.009 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:40:01: | | conversion to 4:2:0 - [0.173%] [avg time: 0.003 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:40:01: | | call to encoder - [51.2%] [avg time: 0.885 ms (cpu time: avg 0.747 ms, total 234.002 ms)] [avg calls per frame: 0]
18:40:01: | | sending stuff out - [0.751%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:40:01: | Convert444Threads - [3.64e+003%] [avg time: 63.04 ms (cpu time: avg 1.096 ms, total 343.202 ms)] [avg calls per frame: 1]
18:40:01:
18:40:01: =====Stream End: 2013-08-17, 18:40:01=================================================
18:40:08: Using fixed low latency mode, factor 25
18:40:08: =====Stream Start: 2013-08-17, 18:40:08===============================================
18:40:08: Multithreaded optimizations: On
18:40:08: Base resolution: 1920x1080
18:40:08: Output resolution: 1280x720
18:40:08: ------------------------------------------
18:40:08: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
18:40:08: Playback device Default
18:40:08: Using desktop audio input: Lautsprecher (C-Media PCI Audio Device)
18:40:08: Using 5.1 surround speaker setup
18:40:08: Using auxilary audio input: Tischmikrofon (HD-5000 - Microsoft LifeCam.)
18:40:09: ------------------------------------------
18:40:09: Audio Encoding: AAC
18:40:09: bitrate: 96
18:40:09: Using graphics capture
18:40:09: Using custom x264 settings: "opencl=true"
18:40:09: Video Encoding: x264
18:40:09: fps: 30
18:40:09: width: 1280, height: 720
18:40:09: preset: faster
18:40:09: CBR: no
18:40:09: CFR: no
18:40:09: max bitrate: 1500
18:40:09: buffer size: 1500
18:40:09: quality: 5
18:40:09: MMDeviceAudioSource: Frequency for device 'Lautsprecher (C-Media PCI Audio Device)' is 1058400, samples per sec is 44100
18:40:09: MMDeviceAudioSource: Frequency for device 'Tischmikrofon (HD-5000 - Microsoft LifeCam.)' is 176400, samples per sec is 44100
18:40:09: SharedTexCapture hooked
18:40:11: Using RTMP service: Twitch / Justin.tv
18:40:11: Server selection: rtmp://live-fra.justin.tv/app
18:40:11: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
18:40:12: SO_SNDBUF was at 8192
18:40:12: SO_SNDBUF is now 65536
18:40:18: Total frames rendered: 266, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
18:40:19: RTMPPublisher::SocketLoop: Graceful loop exit
18:40:19: Number of times waited to send: 0, Waited for a total of 0 bytes
18:40:19: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:40:19:
18:40:19: Profiler results:
18:40:19:
18:40:19: ==============================================================
18:40:19: frame - [100%] [avg time: 1.705 ms (cpu time: avg 1.29 ms, total 343.202 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.176%]
18:40:19: | frame preprocessing and rendering - [40.5%] [avg time: 0.69 ms (cpu time: avg 0.469 ms, total 124.8 ms)] [avg calls per frame: 1] [children: 0.0587%] [unaccounted: 40.4%]
18:40:19: | | scene->Preprocess - [0.0587%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
18:40:19: | video encoding and uploading - [59.4%] [avg time: 1.012 ms (cpu time: avg 0.821 ms, total 218.402 ms)] [avg calls per frame: 1] [children: 58.4%] [unaccounted: 0.997%]
18:40:19: | | flush - [4.05%] [avg time: 0.069 ms (cpu time: avg 0.058 ms, total 15.6 ms)] [avg calls per frame: 1]
18:40:19: | | CopyResource - [0.469%] [avg time: 0.008 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:40:19: | | conversion to 4:2:0 - [0.176%] [avg time: 0.003 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:40:19: | | call to encoder - [53%] [avg time: 0.903 ms (cpu time: avg 0.762 ms, total 202.802 ms)] [avg calls per frame: 0]
18:40:19: | | sending stuff out - [0.704%] [avg time: 0.012 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:40:19: | Convert444Threads - [3.66e+003%] [avg time: 62.401 ms (cpu time: avg 1.348 ms, total 358.802 ms)] [avg calls per frame: 1]
18:40:19:
18:40:19: =====Stream End: 2013-08-17, 18:40:19=================================================
18:42:18: Using fixed low latency mode, factor 25
18:42:18: =====Stream Start: 2013-08-17, 18:42:18===============================================
18:42:18: Multithreaded optimizations: On
18:42:18: Base resolution: 1920x1080
18:42:18: Output resolution: 1280x720
18:42:18: ------------------------------------------
18:42:18: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
18:42:18: Playback device Default
18:42:18: Using desktop audio input: Lautsprecher (C-Media PCI Audio Device)
18:42:18: Using 5.1 surround speaker setup
18:42:18: Using auxilary audio input: Tischmikrofon (HD-5000 - Microsoft LifeCam.)
18:42:18: Audio Encoding: AAC
18:42:18: bitrate: 96
18:42:18: Using graphics capture
18:42:18: Using custom x264 settings: "opencl=true"
18:42:18: Video Encoding: x264
18:42:18: fps: 30
18:42:18: width: 1280, height: 720
18:42:18: preset: faster
18:42:18: CBR: yes
18:42:18: CFR: no
18:42:18: max bitrate: 1900
18:42:18: MMDeviceAudioSource: Frequency for device 'Lautsprecher (C-Media PCI Audio Device)' is 1058400, samples per sec is 44100
18:42:18: MMDeviceAudioSource: Frequency for device 'Tischmikrofon (HD-5000 - Microsoft LifeCam.)' is 176400, samples per sec is 44100
18:42:18: SharedTexCapture hooked
18:42:20: Using RTMP service: Twitch / Justin.tv
18:42:20: Server selection: rtmp://live-fra.justin.tv/app
18:42:20: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
18:42:22: SO_SNDBUF was at 8192
18:42:22: SO_SNDBUF is now 65536
18:42:35: Total frames rendered: 482, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
18:42:35: RTMPPublisher::SocketLoop: Graceful loop exit
18:42:35: Number of times waited to send: 0, Waited for a total of 0 bytes
18:42:35: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:42:35:
18:42:35: Profiler results:
18:42:35:
18:42:35: ==============================================================
18:42:35: frame - [100%] [avg time: 1.663 ms (cpu time: avg 1.618 ms, total 780.005 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.18%]
18:42:35: | frame preprocessing and rendering - [38.8%] [avg time: 0.646 ms (cpu time: avg 0.582 ms, total 280.801 ms)] [avg calls per frame: 1] [children: 0.0601%] [unaccounted: 38.8%]
18:42:35: | | scene->Preprocess - [0.0601%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
18:42:35: | video encoding and uploading - [61%] [avg time: 1.014 ms (cpu time: avg 1.035 ms, total 499.204 ms)] [avg calls per frame: 1] [children: 59.8%] [unaccounted: 1.14%]
18:42:35: | | flush - [4.27%] [avg time: 0.071 ms (cpu time: avg 0.097 ms, total 46.8 ms)] [avg calls per frame: 1]
18:42:35: | | CopyResource - [0.541%] [avg time: 0.009 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:42:35: | | conversion to 4:2:0 - [0.12%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:42:35: | | call to encoder - [54.1%] [avg time: 0.899 ms (cpu time: avg 0.938 ms, total 452.404 ms)] [avg calls per frame: 0]
18:42:35: | | sending stuff out - [0.842%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:42:35: | Convert444Threads - [3.87e+003%] [avg time: 64.311 ms (cpu time: avg 1.1 ms, total 530.402 ms)] [avg calls per frame: 1]
18:42:35:
18:42:35: =====Stream End: 2013-08-17, 18:42:35=================================================
18:35:49: Adapter 1
18:35:49: Adapter 2
18:35:49: fps: 30
18:35:49: CBR: yes
18:35:49: CFR: no
18:39:11:
18:39:11:
18:39:11:
18:39:50: fps: 30
18:39:50: CBR: no
18:39:50: CFR: no
18:40:01:
18:40:01:
18:40:01:
18:40:09: fps: 30
18:40:09: CBR: no
18:40:09: CFR: no
18:40:19:
18:40:19:
18:40:19:
18:42:18: fps: 30
18:42:18: CBR: yes
18:42:18: CFR: no
18:42:35:
18:42:35:
18:42:35:
