Question / Help BlackMagic USB Shuttle
likemagic
Hi,
I haven't had any luck getting BlackMagic USB Shuttle working with ubuntu 18.04lts, msi x570-A-pro motherboard, amd rayzon 7 3800x processor and rx 5600 xt graphics card.
Anybody with pointers
my setup
sudo apt install ffmpeg
sudo add-apt-repository ppa:obsproject/obs-studio
sudo apt install obs-studio
sudo apt install ~/non-std_install/OBS-Studio_ndi/libndi4_4.5.1-1_amd64.deb
sudo apt install ~/non-std_install/OBS-Studio_ndi/obs-ndi_4.9.1-1_amd64.deb
sudo apt install v4l2loopback-dkms
sudo apt install libbmusb-dev
  • 2020-05-27 19-34-21-OBS.txt
Tuna
Blackmagic does not support USB version on Linux. So the regular Decklink plugin will not work. You would have to develop your own OBS plugin based on bmusb.
