I have some issues with setting the proper video input on the any BlackMagic Capture cards.
This has been tested on multiple SDI cards, from the simple BlackMagic Decklink SDI, Duo, 4k to the 4k Extreme.
As you see in the first picture, there are missing options like 1080p25, p30, etc.
http://i.imgur.com/Sy6kqSp.png
In the image below you will find the normal BlackMagic Desktop Video Manager and it support more resolutions the the plugin you have available to select the device video format.
http://i.imgur.com/qSXiEGA.png
Is there anyway to fix this?
