Black Screen when using custom audio/ or no audio
realashxd
I'm using a PiBox Video capture Card to capture my ps4 display. My goal is basically to be able to play my ps4 on my laptop screen.
It was working fine till now, I was using custom audio output as WaveOut , and custom audio device as my bluetooth headphones connected to my laptop. It worked fine, no lag , no issues, as perfect as it could get.
But suddenly today I faced a black screen issue. I reinstalled OBS, and after trying multiple settings , I realized if I try to use WaveOut / or DirectSound , and use a custom audio device it goes into black screen. If i use capture audio only , or even WaveOut / DirectSound without adding a custom audio device, it works fine but has no audio.
I tried using 'Listen to this device' on the capture card from System sound settings, and it still doesn't work.
What is the problem here? It was literally working fine 1 hour ago, and now suddenly it just wouldn't work! Also I don't think that it is a capture card issue, because it's just 5 days old.
I'm a pure beginner, please help!!!
tubaka
I registered for this site simply to reply and say i am having the exact same issue.
I have tried two different capture cards and the behaviour is the same. Video comes through fine, but one i click to add a custom audio source it turns black. Switching back to "Capture Audio Only" which i dont really understand, instantly brings the video feed back (with no audio)
