Black screen in Display/Monitor capture!
Ohem
Hi! I recently switched from Windows to Linux and used OBS to record with Replay for in-game moments. Adding the Display capture works fine for as long OBS is the active window, but once I shift to another window it's all black in the recording. It's the same if I move OBs to the second monitor and have the game active on my primary, it's just black. I tried switching from Wayland to X11 but didn't help, so I'm trying here.
  • 2024-07-07 21-43-52.txt
Tuna
Try if switching to Wayland helps. Pipewire capture on x11 may have it quirks, but it solely depends on the DE's implementation.
Ohem
Okay this is a bit unusual for me but here's the gist: I'm using Monitor/Display capture with PipeWire (no idea what that means) and for whatever reason all games I've tested work but not with Wh40K Darktide - but if I use (XSHM) Display capture it captures the game but is INCREDIBLY stuttery (both in-game and in Gnome).
