Get a black screen while trying to capture BF3, both windowed and FS do not work with GC, but windowed works with screen capture.
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
CPU Speed: 3411MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 2: pos={1920, 0}, size={1280, 1024}
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 580
Video Adapter Dedicated Video Memory: 1560739840
Video Adapter Shared System Memory: 2684502016
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{f1bc2b5e-2392-4569-a26d-3c7b1da6ff6b}
Using desktop audio input: Speakers (Logitech G35 Headset)
Using 7.1 surround speaker setup (experimental)
Using auxilary audio input: Microphone (Logitech G35 Headset)
Audio Encoding: AAC
bitrate: 256
Using graphics capture
device: USB Video Device,
device id \\?\usb#vid_046d&pid_081b&mi_00#7&1e626e33&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
chosen type: YUY2, usingFourCC: false, res: 640x360 - 640x360, fps: 5-30, fourCC: 'YUY2'
Using directshow input
Using text output
Using text output
Using Window Capture
x264: profile High, level 3.2
Video Encoding: x264
fps: 45
width: 1280, height: 720
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
New Scene
Using bitmap image
Using text output
Using Monitor Capture
Using bitmap image
New Scene
SharedTexCapture hooked
New Scene
Using bitmap image
Using text output
Using bitmap image
New Scene
Total frames rendered: 19515, number of frames that lagged: 133 (0.68%) (it's okay for some frames to lag)
Total duplicated CFR frames: 604
x264: frame I:85 Avg QP: 8.60 size: 58327
x264: frame P:5303 Avg QP: 6.99 size: 6355
x264: frame B:14493 Avg QP: 5.56 size: 4192
x264: consecutive B-frames: 2.1% 1.7% 1.3% 94.9%
x264: mb I I16..4: 70.1% 14.5% 15.4%
x264: mb P I16..4: 0.6% 0.6% 0.1% P16..4: 8.1% 2.1% 0.9% 0.0% 0.0% skip:87.6%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.9% 0.2% 0.0% direct: 0.7% skip:98.0% L0:32.2% L1:52.8% BI:15.0%
x264: 8x8 transform intra:28.7% inter:53.3%
x264: coded y,uvDC,uvAC intra: 28.1% 25.5% 12.2% inter: 1.6% 0.7% 0.3%
x264: i16 v,h,dc,p: 72% 20% 5% 4%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 21% 27% 5% 9% 6% 8% 5% 8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 34% 15% 4% 5% 4% 5% 4% 5%
x264: i8c dc,h,v,p: 80% 13% 5% 2%
x264: Weighted P-Frames: Y:1.6% UV:0.9%
x264: ref P L0: 81.1% 18.9%
x264: ref B L0: 78.9% 21.1%
x264: ref B L1: 96.8% 3.2%
x264: kb/s:1800.24
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
Server selection: rtmp://live-jfk.justin.tv/app
bufferTime: 1682, outputRateWindowTime: 1000, dropThreshold: 2182
Warning -- Capture BitBlt failed.. just so you know
Total frames rendered: 14447, number of frames that lagged: 61 (0.42%) (it's okay for some frames to lag)
Total duplicated CFR frames: 568
x264: frame I:70 Avg QP:19.46 size: 89204
x264: frame P:5368 Avg QP:23.46 size: 8602
x264: frame B:9152 Avg QP:23.16 size: 2240
x264: consecutive B-frames: 11.8% 11.0% 7.9% 69.3%
x264: mb I I16..4: 16.9% 61.7% 21.4%
x264: mb P I16..4: 1.4% 2.4% 0.3% P16..4: 26.1% 6.5% 3.7% 0.0% 0.0% skip:59.5%
x264: mb B I16..4: 0.2% 0.3% 0.0% B16..8: 3.9% 0.5% 0.0% direct: 1.2% skip:93.9% L0:37.2% L1:57.7% BI: 5.2%
x264: 8x8 transform intra:59.3% inter:65.9%
x264: coded y,uvDC,uvAC intra: 49.6% 43.6% 17.7% inter: 5.9% 3.1% 0.5%
x264: i16 v,h,dc,p: 30% 41% 12% 17%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 17% 25% 6% 8% 8% 8% 7% 8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 23% 15% 7% 8% 7% 7% 6% 6%
x264: i8c dc,h,v,p: 68% 19% 11% 3%
x264: Weighted P-Frames: Y:2.6% UV:0.9%
x264: ref P L0: 78.5% 21.5%
x264: ref B L0: 81.2% 18.8%
x264: ref B L1: 95.1% 4.9%
x264: kb/s:1799.41
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using bitmap image
Using text output
Using text output
Using text output
Using bitmap image
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
Total frames rendered: 47, number of frames that lagged: 1 (2.13%) (it's okay for some frames to lag)
Total duplicated CFR frames: 0
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using bitmap image
Using text output
Using text output
Using text output
Using bitmap image
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
bufferTime: 1513, outputRateWindowTime: 1000, dropThreshold: 2013
Total frames rendered: 10121, number of frames that lagged: 29 (0.29%) (it's okay for some frames to lag)
Total duplicated CFR frames: 109
x264: frame I:41 Avg QP: 8.95 size: 90534
x264: frame P:2546 Avg QP: 4.61 size: 5547
x264: frame B:7515 Avg QP: 2.45 size: 4345
x264: consecutive B-frames: 0.8% 0.0% 0.0% 99.2%
x264: mb I I16..4: 71.8% 1.4% 26.8%
x264: mb P I16..4: 0.2% 0.0% 0.1% P16..4: 2.8% 0.6% 0.2% 0.0% 0.0% skip:96.2%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.3% 0.2% 0.0% direct: 0.4% skip:99.1% L0:36.8% L1:24.7% BI:38.4%
x264: 8x8 transform intra:2.0% inter:26.9%
x264: coded y,uvDC,uvAC intra: 25.2% 20.1% 19.6% inter: 0.7% 0.3% 0.2%
x264: i16 v,h,dc,p: 87% 11% 2% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 36% 23% 3% 2% 2% 4% 3% 4%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 35% 16% 4% 3% 3% 4% 4% 5%
x264: i8c dc,h,v,p: 83% 11% 5% 1%
x264: ref P L0: 84.3% 15.7%
x264: ref B L0: 75.4% 24.6%
x264: ref B L1: 98.6% 1.4%
x264: kb/s:1799.11
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
Total frames rendered: 2799, number of frames that lagged: 4 (0.14%) (it's okay for some frames to lag)
Total duplicated CFR frames: 15
x264: frame I:11 Avg QP: 0.99 size: 8761
x264: frame P:691 Avg QP: 0.72 size: 4935
x264: frame B:2041 Avg QP: 1.08 size: 4989
x264: mb I I16..4: 98.4% 0.0% 1.6%
x264: mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.3% 0.6% 0.0% 0.0% 0.0% skip:99.0%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.2% 0.2% 0.0% direct: 0.4% skip:99.2% L0:37.1% L1:22.1% BI:40.8%
x264: 8x8 transform intra:0.0% inter:2.5%
x264: coded y,uvDC,uvAC intra: 1.2% 0.9% 0.9% inter: 0.4% 0.0% 0.0%
x264: i16 v,h,dc,p: 98% 0% 2% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 0% 50% 50% 0% 0% 0% 0% 0% 0%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 36% 14% 2% 3% 5% 4% 5% 5%
x264: i8c dc,h,v,p: 99% 0% 0% 0%
x264: ref P L0: 54.3% 45.7%
x264: ref B L0: 69.6% 30.4%
x264: ref B L1: 99.0% 1.0%
x264: kb/s:1796.72
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
New Scene
Using bitmap image
Using text output
Using bitmap image
New Scene
Total frames rendered: 2202, number of frames that lagged: 58 (2.63%) (it's okay for some frames to lag)
Total duplicated CFR frames: 90
x264: frame I:10 Avg QP: 2.56 size: 19673
x264: frame P:566 Avg QP: 2.52 size: 5679
x264: frame B:1644 Avg QP: 3.03 size: 4665
x264: consecutive B-frames: 1.2% 0.0% 0.1% 98.6%
x264: mb I I16..4: 89.1% 6.8% 4.1%
x264: mb P I16..4: 0.4% 0.3% 0.1% P16..4: 2.8% 1.7% 0.7% 0.0% 0.0% skip:94.0%
x264: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 0.6% 0.2% 0.0% direct: 0.8% skip:98.2% L0:37.3% L1:42.8% BI:19.8%
x264: 8x8 transform intra:18.0% inter:41.4%
x264: coded y,uvDC,uvAC intra: 19.5% 19.6% 11.1% inter: 1.1% 0.6% 0.1%
x264: i16 v,h,dc,p: 93% 3% 3% 2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 23% 23% 5% 6% 6% 7% 5% 11%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 32% 16% 5% 4% 4% 5% 4% 4%
x264: i8c dc,h,v,p: 85% 9% 4% 2%
x264: Weighted P-Frames: Y:1.2% UV:0.9%
x264: ref P L0: 70.5% 29.5%
x264: ref B L0: 78.1% 21.9%
x264: ref B L1: 98.3% 1.7%
x264: kb/s:1796.85
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
bufferTime: 1680, outputRateWindowTime: 1000, dropThreshold: 2180
Total frames rendered: 2712, number of frames that lagged: 595 (21.94%) (it's okay for some frames to lag)
Total duplicated CFR frames: 212
x264: frame I:18 Avg QP:26.62 size: 63985
x264: frame P:1316 Avg QP:31.57 size: 7158
x264: frame B:1503 Avg QP:28.84 size: 2392
x264: consecutive B-frames: 21.6% 22.7% 1.9% 53.8%
x264: mb I I16..4: 20.1% 58.3% 21.7%
x264: mb P I16..4: 4.0% 4.7% 0.6% P16..4: 28.8% 5.5% 2.8% 0.0% 0.0% skip:53.6%
x264: mb B I16..4: 0.9% 0.7% 0.0% B16..8: 8.1% 1.0% 0.0% direct: 2.5% skip:86.8% L0:39.7% L1:56.7% BI: 3.6%
x264: 8x8 transform intra:50.4% inter:75.6%
x264: coded y,uvDC,uvAC intra: 30.6% 27.4% 9.3% inter: 6.1% 4.2% 0.6%
x264: i16 v,h,dc,p: 33% 37% 11% 20%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 20% 33% 5% 6% 5% 7% 4% 7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 31% 20% 5% 7% 4% 7% 3% 5%
x264: i8c dc,h,v,p: 76% 15% 7% 2%
x264: Weighted P-Frames: Y:9.0% UV:2.2%
x264: ref P L0: 76.7% 23.3%
x264: ref B L0: 81.8% 18.2%
x264: ref B L1: 97.9% 2.1%
x264: kb/s:1797.62
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
x264: profile High, level 3.1
fps: 30
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
bufferTime: 1779, outputRateWindowTime: 1000, dropThreshold: 2279
Warning -- GraphicsCaptureSource::BeginScene: Failed to inject library, error code = -5
Total frames rendered: 2924, number of frames that lagged: 4 (0.14%) (it's okay for some frames to lag)
x264: frame I:12 Avg QP:13.02 size:180623
x264: frame P:737 Avg QP: 6.14 size: 9455
x264: frame B:2122 Avg QP:12.84 size: 5830
x264: consecutive B-frames: 1.4% 0.0% 0.3% 98.3%
x264: mb I I16..4: 44.3% 11.5% 44.2%
x264: mb P I16..4: 0.7% 0.2% 0.4% P16..4: 9.3% 0.6% 0.4% 0.0% 0.0% skip:88.4%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.4% 0.2% 0.0% direct: 0.4% skip:98.9% L0:41.3% L1:37.9% BI:20.8%
x264: 8x8 transform intra:11.6% inter:32.7%
x264: coded y,uvDC,uvAC intra: 40.8% 41.8% 38.2% inter: 1.5% 1.4% 1.2%
x264: i16 v,h,dc,p: 59% 39% 2% 1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 44% 16% 4% 3% 2% 5% 3% 12%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 37% 11% 3% 3% 3% 5% 3% 6%
x264: i8c dc,h,v,p: 64% 22% 11% 3%
x264: ref P L0: 94.8% 5.2%
x264: ref B L0: 75.1% 24.9%
x264: ref B L1: 97.4% 2.6%
x264: kb/s:1797.91
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 40
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
bufferTime: 1478, outputRateWindowTime: 1000, dropThreshold: 1978
Total frames rendered: 5342, number of frames that lagged: 308 (5.77%) (it's okay for some frames to lag)
Total duplicated CFR frames: 147
x264: frame I:38 Avg QP:25.20 size: 62398
x264: frame P:2205 Avg QP:26.99 size: 8593
x264: frame B:3166 Avg QP:26.06 size: 2869
x264: consecutive B-frames: 13.5% 24.0% 3.5% 58.9%
x264: mb I I16..4: 33.8% 44.6% 21.6%
x264: mb P I16..4: 3.9% 4.6% 0.7% P16..4: 29.4% 5.7% 3.2% 0.0% 0.0% skip:52.5%
x264: mb B I16..4: 0.7% 0.7% 0.0% B16..8: 6.9% 1.1% 0.0% direct: 1.9% skip:88.7% L0:37.8% L1:57.9% BI: 4.3%
x264: 8x8 transform intra:49.5% inter:69.9%
x264: coded y,uvDC,uvAC intra: 33.1% 34.8% 10.0% inter: 6.3% 5.0% 1.0%
x264: i16 v,h,dc,p: 29% 44% 9% 19%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 28% 28% 4% 7% 4% 11% 3% 7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 35% 17% 4% 7% 4% 8% 3% 5%
x264: i8c dc,h,v,p: 65% 26% 7% 2%
x264: Weighted P-Frames: Y:10.6% UV:4.4%
x264: ref P L0: 80.6% 19.4%
x264: ref B L0: 80.9% 19.1%
x264: ref B L1: 97.1% 2.9%
x264: kb/s:1798.57
Profiler results:
frame - [100%] [avg time: 7.631 ms] [avg calls per frame: 1] [children: 91.2%] [unaccounted: 8.81%]
| scene->Preprocess - [39.2%] [avg time: 2.992 ms] [avg calls per frame: 1]
| video encoding and uploading - [52%] [avg time: 3.967 ms] [avg calls per frame: 1] [children: 17.2%] [unaccounted: 34.8%]
| | CopyResource - [0.275%] [avg time: 0.021 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.183%] [avg time: 0.014 ms] [avg calls per frame: 0]
| | call to encoder - [16.7%] [avg time: 1.271 ms] [avg calls per frame: 1]
| | sending stuff out - [0.0786%] [avg time: 0.006 ms] [avg calls per frame: 1]
CPU Speed: 3411MHz
Aero is Disabled
Adapter 1
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
New Scene
Using bitmap image
Using text output
Using bitmap image
New Scene
New Scene
Using bitmap image
Using text output
Using bitmap image
New Scene
x264: kb/s:1800.24
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
x264: kb/s:1799.41
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using bitmap image
Using text output
Using text output
Using text output
Using bitmap image
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using bitmap image
Using text output
Using text output
Using text output
Using bitmap image
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
x264: kb/s:1799.11
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
x264: kb/s:1796.72
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
New Scene
Using bitmap image
Using text output
Using bitmap image
New Scene
x264: kb/s:1796.85
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 45
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
x264: kb/s:1797.62
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 30
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
x264: kb/s:1797.91
Loading up D3D10...
Audio Encoding: AAC
bitrate: 256
Using text output
Using text output
fps: 40
preset: fast
CBR: yes
CFR: yes
max bitrate: 1800
x264: kb/s:1798.57
Profiler results:
