Ok so im trying to stream Defiance on PC but am having trouble with the right settings in OBS, here are my Computer Specs:
i5 2400 3.1 GhZ
Radeon HD 7850 1GB OC
16GB Vengeance RAM
1TB WD HDD
I tried using the Estimator but found out that 4000 bitrates just dont seem to be realistic when streaming with Twitch. Here are my Speedtest results in kbps:
Can someone help me with the settings i should use for a stable stream in 720p? Im not a twitch partner either
Settings i need are Quality Balance, Max Bitrate and Buffer, x264 Preset Setting. Help would be very appreciated. Thanks :D
i5 2400 3.1 GhZ
16GB Vengeance RAM
1TB WD HDD
