^speed test results^
My log file is below. My stream is currently INCREDIBLY laggy, I feel as though my computer specs and internet speed should be more than enough to have a fluid stream. I appreciate any help I can get! Thanks!
10:37:27: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
10:37:27: -------------------------------
10:37:27: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
10:37:27: CPU Speed: 3399MHz
10:37:27: Physical Memory: 4095MB Total, 4095MB Free
10:37:27: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
10:37:27: monitor 1: pos={0, 0}, size={1920, 1080}
10:37:27: monitor 2: pos={-1920, 0}, size={1920, 1080}
10:37:27: Windows Version: 6.1 Build 7601 S
10:37:27: Aero is Disabled
10:37:27: OBS Modules:
10:37:27: Base Address Module
10:37:27: 013A0000 OBS.exe
10:37:27: 62150000 OBSApi.dll
10:37:27: 635F0000 DShowPlugin.dll
10:37:27: 635D0000 GraphicsCapture.dll
10:37:27: 635B0000 NoiseGate.dll
10:37:27: ------------------------------------------
10:37:27: Adapter 1
10:37:27: Video Adapter: NVIDIA GeForce GTX 560 Ti
10:37:27: Video Adapter Dedicated Video Memory: 2096562176
10:37:27: Video Adapter Shared System Memory: 2147364864
10:37:27: Using fixed low latency mode, factor 20
10:37:27: =====Stream Start: 2013-06-12, 10:37:27===============================================
10:37:27: Multithreaded optimizations: On
10:37:27: Base resolution: 1920x1080
10:37:27: Output resolution: 1920x1080
10:37:28: Loading up D3D10...
10:37:28: Playback device Default
10:37:28: ------------------------------------------
10:37:28: Using desktop audio input: ASUS VH232H-0 (2- NVIDIA High Definition Audio)
10:37:28: Using auxilary audio input: Microphone (2- Logitech G930 Headset)
10:37:28: Audio Encoding: AAC
10:37:28: bitrate: 128
10:37:28: Video Encoding: x264
10:37:28: fps: 60
10:37:28: width: 1920, height: 1080
10:37:28: preset: veryfast
10:37:28: CBR: yes
10:37:28: CFR: no
10:37:28: max bitrate: 4000
10:37:29: Using RTMP service: Twitch / Justin.tv
10:37:29: Server selection: rtmp://live-jfk.justin.tv/app
10:37:30: SO_SNDBUF was at 8192
10:37:30: SO_SNDBUF is now 65536
10:37:32: Using Monitor Capture
10:39:37: Total frames rendered: 5010, number of frames that lagged: 2008 (40.08%) (it's okay for some frames to lag)
10:39:37: okay, this is strange
10:39:37: RTMPPublisher::SocketLoop: Aborting due to loop exit
10:39:37: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
10:39:37: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
10:39:37: Number of times waited to send: 56, Waited for a total of 228587 bytes
10:39:37: Number of b-frames dropped: 118 (2.4%), Number of p-frames dropped: 111 (2.3%), Total 229 (4.7%)
10:39:37: =====Stream End: 2013-06-12, 10:39:37=================================================
10:40:00: Using fixed low latency mode, factor 20
10:40:00: =====Stream Start: 2013-06-12, 10:40:00===============================================
10:40:00: Multithreaded optimizations: On
10:40:00: Base resolution: 1920x1080
10:40:00: Output resolution: 1920x1080
10:40:00: ------------------------------------------
10:40:00: Loading up D3D10...
10:40:00: Playback device Default
10:40:00: Using desktop audio input: ASUS VH232H-0 (2- NVIDIA High Definition Audio)
10:40:00: Using auxilary audio input: Microphone (2- Logitech G930 Headset)
10:40:00: Audio Encoding: AAC
10:40:00: bitrate: 128
10:40:00: Using Monitor Capture
10:40:00: Video Encoding: x264
10:40:00: fps: 60
10:40:00: width: 1920, height: 1080
10:40:00: preset: veryfast
10:40:00: CBR: yes
10:40:00: CFR: no
10:40:00: max bitrate: 3000
10:40:02: Using RTMP service: Twitch / Justin.tv
10:40:02: Server selection: rtmp://live-jfk.justin.tv/app
10:40:02: SO_SNDBUF was at 8192
10:40:02: SO_SNDBUF is now 65536
10:40:44: Total frames rendered: 1640, number of frames that lagged: 377 (22.99%) (it's okay for some frames to lag)
10:40:44: RTMPPublisher::SocketLoop: Aborting due to bStopping
10:40:44: Number of times waited to send: 15, Waited for a total of 61462 bytes
10:40:44: Number of b-frames dropped: 77 (5.2%), Number of p-frames dropped: 75 (5.1%), Total 152 (10%)
10:40:44: =====Stream End: 2013-06-12, 10:40:44=================================================
10:40:55: Using fixed low latency mode, factor 20
10:40:55: =====Stream Start: 2013-06-12, 10:40:55===============================================
10:40:55: Multithreaded optimizations: On
10:40:55: Base resolution: 1920x1080
10:40:55: Output resolution: 1920x1080
10:40:55: ------------------------------------------
10:40:55: Loading up D3D10...
10:40:55: Playback device Default
10:40:55: Using desktop audio input: ASUS VH232H-0 (2- NVIDIA High Definition Audio)
10:40:55: Using auxilary audio input: Microphone (2- Logitech G930 Headset)
10:40:55: Audio Encoding: AAC
10:40:55: bitrate: 128
10:40:55: Using Monitor Capture
10:40:55: Video Encoding: x264
10:40:55: fps: 60
10:40:55: width: 1920, height: 1080
10:40:55: preset: veryfast
10:40:55: CBR: yes
10:40:55: CFR: no
10:40:55: max bitrate: 2000
10:40:56: Using RTMP service: Twitch / Justin.tv
10:40:56: Server selection: rtmp://live-jfk.justin.tv/app
10:40:57: SO_SNDBUF was at 8192
10:40:57: SO_SNDBUF is now 65536
10:42:27: Total frames rendered: 3303, number of frames that lagged: 931 (28.19%) (it's okay for some frames to lag)
10:42:27: RTMPPublisher::SocketLoop: Aborting due to bStopping
10:42:27: Number of times waited to send: 57, Waited for a total of 222828 bytes
10:42:27: Number of b-frames dropped: 161 (5.1%), Number of p-frames dropped: 158 (5%), Total 319 (10%)
10:42:27: =====Stream End: 2013-06-12, 10:42:27=================================================
10:52:54:
10:52:54: Profiler results:
10:52:54:
10:52:54: ==============================================================
10:52:54: frame - [100%] [avg time: 22.552 ms] [avg calls per frame: 1] [children: 94%] [unaccounted: 6.01%]
10:52:54: | scene->Preprocess - [68.5%] [avg time: 15.455 ms] [avg calls per frame: 1]
10:52:54: | video encoding and uploading - [25.5%] [avg time: 5.742 ms] [avg calls per frame: 1] [children: 23.1%] [unaccounted: 2.34%]
10:52:54: | | CopyResource - [0.155%] [avg time: 0.035 ms] [avg calls per frame: 0]
10:52:54: | | conversion to 4:2:0 - [0.448%] [avg time: 0.101 ms] [avg calls per frame: 0]
10:52:54: | | call to encoder - [22.3%] [avg time: 5.034 ms] [avg calls per frame: 0]
10:52:54: | | sending stuff out - [0.195%] [avg time: 0.044 ms] [avg calls per frame: 0]
10:52:54:
