Question / Help Best settings for Black Ops 2?
Thoomass
Hello guys!
Somebody can help me with this game to set my OBS right? I have some experience i can made a goood settings for WoW but COD has a little bit power so if you have any experience from this game pls help me!
I have a AMD Athlon II x4 645 processor with 8GB ram and gforce 550 gtx ti videocard. My net is download: 50Mb upload: 5Mb!
I know COD has streaming system but i dont like that no settings just stream!
Thx
WayZHC
What are your current settings? Encoding settings, video settings and x264 preset in advanced tab? And what's your in-game resolution?
Thoomass
im using quality balance 5, max bitrate 3000, buffer size 2500, resolution downscale 1,5 1280x720 filter bilinear, fps: 30!
In game resolution is 1920x1080! sorry but i dont know what does it mean "x264 in advanced tab"?
WayZHC
Those settings should be just fine for fps gaming. You could also try cbr.
x264 preset is in the advanced settings. It's Veryfast by default and that's what i recommend to use.
Thoomass
Yes im using the veryfast and i cant play with this settings its cause massive fps lag for me! So whitch settings demand the most power? For example i change the downscale resolution or the quality balance?
WayZHC
Then try x264 preset Superfast or Ultrafast. Start with Superfast and if still massive lag set it to Ultrafast or downscale little more (from 1.5x to like 1.75x or even 2x) with Superfast x264 preset.
x264 preset and resolution is the most cpu demanding settings.
