Question / Help Best OBS Settings for my Build?
lMerkah
Operating System: Windows 7 64-Bit
CPU: Intel Core i7 4770 @ 3.40GHZ (4 Cores, 8 Threads)
RAM: 16GB DDR3
Motherboard: Gigabyte Z87-HD3
Graphics Card: NVIDIA GeForce GTX 750 Ti 2GB
Storage: #1 120GB SSD (Operating System)
#2 1TB HD (other programs and games)
Download Speed: 35MBPS
Upload Speed: 9MBPS
Can anyone tell me the best settings for streaming games such as League of Legends and World of Warcraft and Hearthstone?
MrBalisongGamer
Can anyone help me with my problem? I looked at my most recent log and the error i found was this...09:18:30.070: [AMF Encoder] Unable to load 'amfrt32.dll', error code 126
My videos I make are really good, and then obs decides to freeze up and just play audio . can anyone help me?
What kind of settings would I Use?
MrBalisongGamer
This is my log
09:18:28.762: CPU Name: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
09:18:28.762: CPU Speed: 2712MHz
09:18:28.762: Physical Cores: 4, Logical Cores: 4
09:18:28.763: Physical Memory: 2047MB Total, 2047MB Free (NOTE: 2 or 4 gigs max is normal for 32bit programs)
09:18:28.763: Windows Version: 10.0 Build 14393 (revision: 351; 64-bit)
09:18:28.763: Running as administrator: false
09:18:28.763: Aero is Enabled (Aero is always on for windows 8 and above)
09:18:28.763: Portable mode: false
09:18:28.810: OBS 0.16.4 (windows)
09:18:28.810: ---------------------------------
09:18:28.811: ---------------------------------
09:18:28.905: audio settings reset:
09:18:28.905: samples per sec: 44100
09:18:28.905: speakers: 2
09:18:28.906: ---------------------------------
09:18:28.906: Initializing D3D11..
09:18:28.906: Available Video Adapters:
09:18:28.910: Adapter 1: NVIDIA GeForce GTX 745
09:18:28.910: Dedicated VRAM: 3221225472
09:18:28.910: Shared VRAM: 1073676288
09:18:28.911: output 1: pos={0, 0}, size={1920, 1080}, attached=true
09:18:28.911: Adapter 2: Intel(R) HD Graphics 530
09:18:28.911: Dedicated VRAM: 134217728
09:18:28.911: Shared VRAM: 4160684032
09:18:28.915: Loading up D3D11 on adapter NVIDIA GeForce GTX 745 (0)
09:18:29.494: D3D11 loaded sucessfully, feature level used: 45056
09:18:30.058: ---------------------------------
09:18:30.058: video settings reset:
09:18:30.058: base resolution: 1920x1080
09:18:30.058: output resolution: 1920x1080
09:18:30.058: downscale filter: Bicubic
09:18:30.058: fps: 60/1
09:18:30.058: format: NV12
09:18:30.060: ---------------------------------
09:18:30.068: [CoreAudio encoder]: Adding CoreAudio AAC encoder
09:18:30.069: [AMF Encoder] Version 1.4.1.0-1.3.0.5
09:18:30.070: [AMF Encoder] Unable to load 'amfrt32.dll', error code 126.
09:18:30.080: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libcef.dll' not found, loading of module failed
09:18:30.081: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libEGL.dll' not found, loading of module failed
09:18:30.082: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libGLESv2.dll' not found, loading of module failed
09:18:30.083: Failed to load 'en-US' text for module: 'obs-browser.dll'
09:18:30.083: [browser_source: 'Version: 1.25.0']
09:18:30.086: NVENC supported
09:18:30.106: Couldn't find VLC installation, VLC video source disabled
09:18:37.113: No blackmagic support
09:18:37.474: ---------------------------------
09:18:37.474: Loaded Modules:
09:18:37.474: win-wasapi.dll
09:18:37.474: win-mf.dll
09:18:37.474: win-dshow.dll
09:18:37.474: win-decklink.dll
09:18:37.474: win-capture.dll
09:18:37.474: vlc-video.dll
09:18:37.474: text-freetype2.dll
09:18:37.474: rtmp-services.dll
09:18:37.474: obs-x264.dll
09:18:37.474: obs-transitions.dll
09:18:37.474: obs-text.dll
09:18:37.474: obs-qsv11.dll
09:18:37.474: obs-outputs.dll
09:18:37.474: obs-filters.dll
09:18:37.474: obs-ffmpeg.dll
09:18:37.475: obs-browser.dll
09:18:37.475: image-source.dll
09:18:37.475: frontend-tools.dll
09:18:37.475: enc-amf.dll
09:18:37.475: coreaudio-encoder.dll
09:18:37.475: ==== Startup complete ===============================================
09:18:37.485: All scene data cleared
09:18:37.485: ------------------------------------------------
09:18:37.507: WASAPI: Device 'Speakers / Headphones (Realtek High Definition Audio)' initialized
09:18:37.569: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
09:18:39.051: WASAPI: Device 'Microphone (Realtek High Definition Audio)' initialized
09:18:39.055: Switched to scene 'Scene'
09:18:39.055: ------------------------------------------------
09:18:39.055: Loaded scenes:
09:18:39.055: - scene 'Scene':
09:18:39.055: - source: 'Display Capture' (monitor_capture)
09:18:39.177: Update check: last known remote version is 0.16.4
  • 2016-11-08 09-18-28.txt
