Best OBS Encoder for High-Quality 1080p60 Streaming + Recording (Xeon E5-2670v3 + RX 6600)
Vyffen
Hi all,
I want to stream and record at the same time Fortnite, Minecraft, Roblox, and Rocket League at 1080p60 on a Xeon E5-2670v3 with an RX 6600. My priority is maximum stream quality while keeping good FPS in-game.
Would x264 or AMD H.264 be better for this setup when streaming and recording simultaneously? Any advice on settings or trade-offs to get the best balance between visual quality and performance?
rockbottom
Test, I suspect you'll like the quality of x264 over the GPU encoder.
You can send a real high quality stream & also send it to disc if you like. So there's only a single encoding running.
rockbottom
Best quality of the 2. If you notice any encoding lag in the OBS stats, use a faster Preset. I would stick with x264 if there's no lag. Let the GPU do just the rendering.
