Question / Help battlefield 3 audio low or not at all
vi9rus
I have been trying to stream battlefield, But the audio wont come through at all. i hear it on the headset and every so often loud sounds go through but for the most part its dead silent with all volumes maxed. Anyone have a fix?
vi9rus
just to clear a few things up, i can stream any othe game with perfect audio but battlefield has none. ive tried multiple versions and messed with every setting that makes even a lick of sense. I reaaaallly need an answer :(
hilalpro
Does battlefield allow you t change the playback device from sound options ? make sure to match it to the one used by obs.
if it doesn't then try setting obs desktop sound device to "default"
vi9rus
No settings like that in battlefield, and OBS is set at default.
vi9rus
hilalpro said:
What headsets are you using ? post a log file viewtopic.php?f=5&t=97 and a screen shot of your playback devices from windows.
Using a siberia V2 and ill paste the log file. The playback list is attached as well.
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
CPU Speed: 3500MHz
Physical Memory:  4095MB Total, 4095MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 2: pos={-1280, 0}, size={1280, 1024}
Aero is Enabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 680
  Video Adapter Dedicated Video Memory: 2091581440
  Video Adapter Shared System Memory: 2147479552
  Base resolution: 1920x1080
  Output resolution: 1280x720
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (ASUS Xonar DG Audio Device)
Using auxilary audio input: Microphone (ASUS Xonar DG Audio Device)
Audio Encoding: AAC
    bitrate: 128
Using graphics capture
x264: profile High, level 3.2
Video Encoding: x264
    fps: 60
    width: 1280, height: 720
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2000
    buffer size: 2000
    quality: 10
SharedTexCapture hooked
Total frames rendered: 3376, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:16    Avg QP:28.10  size: 75268
x264: frame P:1185  Avg QP:31.26  size:  6508
x264: frame B:2116  Avg QP:32.71  size:   206
x264: consecutive B-frames: 11.2% 11.2%  0.5% 77.2%
x264: mb I  I16..4: 23.5% 39.3% 37.2%
x264: mb P  I16..4:  3.0%  3.7%  0.1%  P16..4: 20.4%  3.8%  1.5%  0.0%  0.0%    skip:67.6%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  1.2%  0.2%  0.0%  direct: 0.3%  skip:98.2%  L0:34.3% L1:60.3% BI: 5.3%
x264: 8x8 transform intra:51.4% inter:27.4%
x264: coded y,uvDC,uvAC intra: 32.5% 29.5% 7.2% inter: 2.8% 0.9% 0.0%
x264: i16 v,h,dc,p: 36% 33% 21% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu:  8% 22% 42%  3%  8%  3%  7%  3%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 19% 15%  8%  8%  7%  9%  6% 12%
x264: i8c dc,h,v,p: 74% 16%  7%  2%
x264: Weighted P-Frames: Y:0.1% UV:0.1%
x264: kb/s:1352.80
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2000
    buffer size: 2000
    quality: 10
librtmp error: RTMP URL: No :// in url!
Total frames rendered: 133, number of frames that lagged: 1 (0.75%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:31.17  size: 86877
x264: frame P:18    Avg QP:31.51  size:  8771
x264: frame B:54    Avg QP:35.94  size:    65
x264: consecutive B-frames:  1.4%  0.0%  0.0% 98.6%
x264: mb I  I16..4: 20.6% 28.1% 51.3%
x264: mb P  I16..4:  0.1%  0.0%  0.0%  P16..4: 26.5%  1.9%  1.3%  0.0%  0.0%    skip:70.2%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.1%  0.0%  0.0%  direct: 0.1%  skip:99.8%  L0:24.9% L1:64.6% BI:10.6%
x264: 8x8 transform intra:27.5% inter:26.7%
x264: coded y,uvDC,uvAC intra: 77.1% 50.7% 20.0% inter: 3.4% 0.6% 0.0%
x264: i16 v,h,dc,p: 54% 14% 23%  9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 17% 27%  5%  8%  5%  6%  5% 17%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 16% 17%  9%  9%  8% 10%  7% 13%
x264: i8c dc,h,v,p: 60% 20% 16%  5%
x264: kb/s:1625.23
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2000
    buffer size: 2000
    quality: 10
Total frames rendered: 134, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:31.45  size: 83738
x264: frame P:19    Avg QP:31.75  size:  8730
x264: frame B:54    Avg QP:35.78  size:    57
x264: consecutive B-frames:  1.3%  0.0%  0.0% 98.7%
x264: mb I  I16..4: 22.1% 28.7% 49.3%
x264: mb P  I16..4:  0.1%  0.0%  0.0%  P16..4: 26.8%  2.4%  1.5%  0.0%  0.0%    skip:69.1%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.1%  0.0%  0.0%  direct: 0.1%  skip:99.8%  L0:24.6% L1:69.3% BI: 6.2%
x264: 8x8 transform intra:28.1% inter:26.1%
x264: coded y,uvDC,uvAC intra: 77.1% 51.1% 19.2% inter: 3.5% 0.7% 0.0%
x264: i16 v,h,dc,p: 52% 14% 23% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 17% 27%  5%  8%  5%  7%  5% 16%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 16% 17%  9%  9%  7%  9%  7% 13%
x264: i8c dc,h,v,p: 60% 20% 14%  5%
x264: kb/s:1639.36
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2000
    buffer size: 2000
    quality: 10
x264: frame I:1     Avg QP:31.63  size: 81555
x264: frame P:19    Avg QP:31.97  size:  9518
x264: frame B:54    Avg QP:35.25  size:    60
x264: mb I  I16..4: 22.6% 30.1% 47.3%
x264: mb P  I16..4:  0.2%  0.0%  0.0%  P16..4: 28.6%  2.4%  1.5%  0.0%  0.0%    skip:67.2%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.1%  0.0%  0.0%  direct: 0.1%  skip:99.8%  L0:32.2% L1:56.6% BI:11.2%
x264: 8x8 transform intra:29.2% inter:26.6%
x264: coded y,uvDC,uvAC intra: 76.2% 50.3% 18.4% inter: 3.8% 0.7% 0.0%
x264: i16 v,h,dc,p: 53% 15% 22% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 17% 27%  5%  8%  5%  6%  5% 16%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 16% 18%  9%  9%  7%  9%  6% 13%
x264: i8c dc,h,v,p: 61% 18% 16%  5%
x264: kb/s:1723.63
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2000
    buffer size: 2000
    quality: 10
  Server selection: rtmp://live-3c.justin.tv/app
bufferTime: 1400, outputRateWindowTime: 1000, dropThreshold: 1900
Total frames rendered: 402303, number of frames that lagged: 5743 (1.43%) (it's okay for some frames to lag)
Number of b-frames dropped: 564 (0.14%), Number of p-frames dropped: 756 (0.19%), Total 1320 (0.33%)
x264: frame I:2353  Avg QP:30.38  size: 30389
x264: frame P:201178 Avg QP:33.53  size:  5382
x264: frame B:198713 Avg QP:30.58  size:   691
x264: consecutive B-frames: 21.8% 35.3%  4.7% 38.1%
x264: mb I  I16..4: 38.4% 46.8% 14.9%
x264: mb P  I16..4:  7.0%  7.1%  0.1%  P16..4: 18.1%  5.2%  1.5%  0.0%  0.0%    skip:61.1%
x264: mb B  I16..4:  0.5%  0.3%  0.0%  B16..8:  5.0%  0.8%  0.0%  direct: 0.7%  skip:92.6%  L0:37.7% L1:57.7% BI: 4.6%
x264: 8x8 transform intra:49.0% inter:35.6%
x264: coded y,uvDC,uvAC intra: 28.2% 18.4% 3.1% inter: 2.8% 1.6% 0.0%
x264: i16 v,h,dc,p: 37% 31% 22% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 21% 45%  2%  5%  3%  4%  3%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 25% 19%  6%  7%  6%  7%  5%  7%
x264: i8c dc,h,v,p: 80% 12%  7%  1%
x264: Weighted P-Frames: Y:4.4% UV:1.4%
x264: kb/s:1491.52
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 3000
    buffer size: 3000
    quality: 10
Total frames rendered: 6280, number of frames that lagged: 170 (2.71%) (it's okay for some frames to lag)
x264: frame I:33    Avg QP:25.92  size: 44866
x264: frame P:2536  Avg QP:31.23  size: 10525
x264: frame B:3659  Avg QP:29.40  size:  1297
x264: consecutive B-frames: 13.8% 23.3%  0.6% 62.3%
x264: mb I  I16..4: 44.6% 35.4% 20.0%
x264: mb P  I16..4:  3.9%  5.4%  0.2%  P16..4: 18.6%  7.2%  4.1%  0.0%  0.0%    skip:60.6%
x264: mb B  I16..4:  0.2%  0.2%  0.0%  B16..8:  4.1%  1.3%  0.2%  direct: 1.9%  skip:92.1%  L0:29.3% L1:53.7% BI:17.0%
x264: 8x8 transform intra:54.0% inter:26.0%
x264: coded y,uvDC,uvAC intra: 38.5% 21.9% 4.0% inter: 5.3% 1.5% 0.1%
x264: i16 v,h,dc,p: 33% 32% 24% 11%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu:  8% 24% 40%  3%  6%  3%  6%  3%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 20% 20%  7%  8%  7%  8%  6%  8%
x264: i8c dc,h,v,p: 75% 16%  8%  1%
x264: Weighted P-Frames: Y:2.9% UV:0.7%
x264: kb/s:2447.32
  Output resolution: 1920x1080
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
x264: profile High, level 4.2
    fps: 60
    width: 1920, height: 1080
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 3000
    buffer size: 3000
    quality: 10
bufferTime: 1456, outputRateWindowTime: 1000, dropThreshold: 1956
Total frames rendered: 1375, number of frames that lagged: 604 (43.93%) (it's okay for some frames to lag)
x264: frame I:18    Avg QP:35.02  size: 53430
x264: frame P:766   Avg QP:38.39  size: 14026
x264: frame B:540   Avg QP:40.15  size:  2484
x264: consecutive B-frames: 25.1% 58.3%  9.1%  7.5%
x264: mb I  I16..4: 47.2% 42.5% 10.3%
x264: mb P  I16..4:  8.6%  8.2%  0.1%  P16..4: 16.2%  4.4%  1.6%  0.0%  0.0%    skip:60.8%
x264: mb B  I16..4:  0.8%  0.4%  0.0%  B16..8:  7.0%  1.2%  0.1%  direct: 1.2%  skip:89.3%  L0:36.8% L1:56.4% BI: 6.8%
x264: 8x8 transform intra:47.0% inter:24.6%
x264: coded y,uvDC,uvAC intra: 29.9% 17.9% 2.0% inter: 3.7% 1.6% 0.0%
x264: i16 v,h,dc,p: 36% 29% 26% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu:  8% 21% 48%  3%  5%  3%  5%  3%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 17% 23%  8%  7%  8%  8%  6%  7%
x264: i8c dc,h,v,p: 84% 10%  5%  1%
x264: Weighted P-Frames: Y:3.4% UV:0.4%
x264: kb/s:2987.58
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2200
    buffer size: 2200
    quality: 10
bufferTime: 1403, outputRateWindowTime: 1000, dropThreshold: 1903
Total frames rendered: 15532, number of frames that lagged: 99 (0.64%) (it's okay for some frames to lag)
x264: frame I:90    Avg QP:30.07  size: 18780
x264: frame P:7656  Avg QP:32.67  size:  6104
x264: frame B:7736  Avg QP:29.36  size:   750
x264: consecutive B-frames: 19.7% 37.9%  9.2% 33.2%
x264: mb I  I16..4: 49.4% 42.3%  8.2%
x264: mb P  I16..4:  5.2%  5.6%  0.1%  P16..4: 19.3%  6.0%  2.0%  0.0%  0.0%    skip:61.7%
x264: mb B  I16..4:  0.3%  0.2%  0.0%  B16..8:  5.4%  1.0%  0.0%  direct: 0.7%  skip:92.3%  L0:35.7% L1:57.5% BI: 6.8%
x264: 8x8 transform intra:49.8% inter:37.8%
x264: coded y,uvDC,uvAC intra: 30.5% 18.8% 2.4% inter: 3.8% 1.9% 0.0%
x264: i16 v,h,dc,p: 37% 31% 23%  9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu:  9% 20% 45%  3%  5%  3%  5%  3%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 21% 22%  7%  8%  6%  8%  5%  7%
x264: i8c dc,h,v,p: 78% 13%  8%  1%
x264: Weighted P-Frames: Y:5.7% UV:1.2%
x264: kb/s:1657.09
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2500
    buffer size: 2500
    quality: 10
bufferTime: 1413, outputRateWindowTime: 1000, dropThreshold: 1913
Total frames rendered: 354091, number of frames that lagged: 13552 (3.83%) (it's okay for some frames to lag)
x264: frame I:2077  Avg QP:29.32  size: 33796
x264: frame P:168703 Avg QP:31.50  size:  6691
x264: frame B:183261 Avg QP:29.56  size:   942
x264: consecutive B-frames: 19.2% 33.6%  5.4% 41.8%
x264: mb I  I16..4: 35.5% 48.9% 15.6%
x264: mb P  I16..4:  7.4%  6.1%  0.2%  P16..4: 23.0%  7.1%  2.1%  0.0%  0.0%    skip:54.2%
x264: mb B  I16..4:  0.6%  0.3%  0.0%  B16..8:  7.0%  1.2%  0.0%  direct: 0.9%  skip:90.0%  L0:39.3% L1:55.8% BI: 5.0%
x264: 8x8 transform intra:43.9% inter:33.9%
x264: coded y,uvDC,uvAC intra: 32.9% 28.2% 5.8% inter: 3.4% 2.7% 0.1%
x264: i16 v,h,dc,p: 39% 29% 24%  8%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 19% 42%  3%  6%  4%  5%  4%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 21% 21%  7%  7%  6%  7%  5%  6%
x264: i8c dc,h,v,p: 73% 15% 10%  2%
x264: Weighted P-Frames: Y:2.5% UV:1.0%
x264: kb/s:1753.11
Loading up D3D10...
Playback device {0.0.0.00000000}.{92b10d25-ac3c-4077-8a2c-8612f433ae73}
Audio Encoding: AAC
    bitrate: 128
    fps: 60
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2500
    buffer size: 2500
    quality: 10
bufferTime: 1989, outputRateWindowTime: 1000, dropThreshold: 2489
Total frames rendered: 207767, number of frames that lagged: 1739 (0.84%) (it's okay for some frames to lag)
x264: frame I:1200  Avg QP:27.37  size: 26452
x264: frame P:97321 Avg QP:31.12  size:  5933
x264: frame B:109195 Avg QP:26.71  size:   713
x264: consecutive B-frames: 19.2% 31.0%  3.4% 46.4%
x264: mb I  I16..4: 43.6% 43.3% 13.2%
x264: mb P  I16..4:  5.9%  6.9%  0.2%  P16..4: 18.4%  6.1%  1.8%  0.0%  0.0%    skip:60.7%
x264: mb B  I16..4:  0.4%  0.3%  0.0%  B16..8:  5.0%  0.9%  0.0%  direct: 0.7%  skip:92.7%  L0:35.8% L1:58.7% BI: 5.5%
x264: 8x8 transform intra:52.0% inter:39.1%
x264: coded y,uvDC,uvAC intra: 31.2% 17.1% 2.4% inter: 3.3% 1.7% 0.0%
x264: i16 v,h,dc,p: 36% 32% 22% 11%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 22% 42%  3%  5%  3%  5%  3%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 26% 20%  6%  7%  5%  7%  5%  7%
x264: i8c dc,h,v,p: 76% 14%  8%  1%
x264: Weighted P-Frames: Y:5.5% UV:1.9%
x264: kb/s:1567.55
Profiler results:
frame - [100%] [avg time: 5.07 ms] [avg calls per frame: 1] [children: 87.8%] [unaccounted: 12.2%]
| scene->Preprocess - [0.0789%] [avg time: 0.004 ms] [avg calls per frame: 1]
| video encoding and uploading - [87.7%] [avg time: 4.446 ms] [avg calls per frame: 1] [children: 37.6%] [unaccounted: 50.1%]
| | CopyResource - [0.947%] [avg time: 0.048 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [2.68%] [avg time: 0.136 ms] [avg calls per frame: 0]
| | call to encoder - [33.6%] [avg time: 1.704 ms] [avg calls per frame: 0]
| | sending stuff out - [0.355%] [avg time: 0.018 ms] [avg calls per frame: 0]
