Question / Help Bad quality recording with good settings
Dostendite
Logs:
My custom config:
10:07:04: CLR host plugin strings not found, dynamically loading 4 strings
10:07:04: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
10:07:04: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
10:07:04: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
10:07:04: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
10:07:04: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
10:07:04: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
10:07:04: CLRHost:: Could not find/load browser settings at location C:\Users\Dostendite\AppData\Roaming\OBS\pluginData\browser.json
10:07:04: CLRHost:: Exception: System.IO.FileNotFoundException: No se pudo encontrar el archivo 'C:\Users\Dostendite\AppData\Roaming\OBS\pluginData\browser.json'.
10:07:04: Nombre de archivo: 'C:\Users\Dostendite\AppData\Roaming\OBS\pluginData\browser.json'
10:07:04: en System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
10:07:04: en System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
10:07:04: en System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
10:07:04: en CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
10:07:04: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
Warning -- Could not open locale string file 'plugins/scenesw/locale/es.txt'
10:07:10: CLR host plugin instance deleted; removing dynamically loaded localization strings
Last game capture log:
2016-08-18, 07:02:40: we're booting up:
07:02:40: CaptureThread: attached to process javaw.exe
07:02:40: GL Present
07:02:40: DirectDraw capture: Windows 8 not supported yet
07:02:40: (half life scientist) everything.. seems to be in order
07:02:40: SwapBuffers(1392574531) Called
07:02:40: NV Capture available
07:02:40: FBO available
07:02:40: setting up gl data
07:02:40: share device: 1106397072
07:02:40: share texture: 1016267504
07:02:40: share device handle: 4054503774
07:02:40: share texture handle: 4002489490
07:02:40: DoGLGPUHook: success
07:02:40: wglSwapBuffers(1392574531) Called
07:03:02: stop requested, terminating gl capture
07:03:02: ---------------------- Cleared OpenGL Capture ----------------------
07:03:02: wglSwapBuffers(1392574531) Called
07:03:02: setting up gl data
07:03:02: SwapBuffers(1392574531) Called
07:03:04: DirectDraw capture: Windows 8 not supported yet
07:03:28: wglDeleteContext Called
07:03:28: ---------------------- Cleared OpenGL Capture ----------------------
07:03:28: DirectDraw capture: Windows 8 not supported yet
  • 2016-09-23-1007-04.log
  • 2016-09-23-0915-09.log
Osiris
I did, those settings do NOT produce bad quality video. And if you think they do, post a sample of a video you think is bad quality.
