Bug Report Audio/Video Stuttering and Delays
MrPantsu
I stream League of legends with my new Plantronics .Audio 995 wireless headset and saw that the newest update should have fixed the usb based mic/headset stuttering problem but mine persists.
Any help will be appreciated.
Logs posted below.
18:29:50: Open Broadcaster Software v0.612b - 32bit (´・ω・`)
18:29:50: -------------------------------
18:29:50: CPU Name: AMD FX(tm)-4130 Quad-Core Processor
18:29:50: CPU Speed: 3817MHz
18:29:50: Physical Memory:  4095MB Total, 4095MB Free
18:29:50: stepping id: 2, model 1, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
18:29:50: monitor 1: pos={0, 0}, size={1920, 1080}
18:29:50: monitor 2: pos={-1600, 180}, size={1600, 900}
18:29:50: Windows Version: 6.2 Build 9200
18:29:50: Aero is Enabled
18:29:50: OBS Modules:
18:29:50: Base Address     Module
18:29:50: 01060000         OBS.exe
18:29:50: 56AF0000         OBSApi.dll
18:29:50: 56870000         DShowPlugin.dll
18:29:50: 56850000         GraphicsCapture.dll
18:29:50: 56830000         NoiseGate.dll
18:29:50: 56810000         PSVPlugin.dll
18:29:50: ------------------------------------------
18:29:50: Adapter 1
18:29:50:   Video Adapter: NVIDIA GeForce GTX 650
18:29:50:   Video Adapter Dedicated Video Memory: 1020985344
18:29:50:   Video Adapter Shared System Memory: 3221221376
18:29:50:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:29:50:   Video Adapter Output 2: pos={-1600, 180}, size={1600, 900}, attached=true
18:29:50: =====Stream Start: 2014-03-07, 18:29:50===============================================
18:29:50:   Multithreaded optimizations: On
18:29:50:   Base resolution: 1920x1080
18:29:50:   Output resolution: 1280x720
18:29:50: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
18:29:50: Audio Format: 48000hz
18:29:50: Playback device Default
18:29:50: Using desktop audio input: Speakers (2- Plantronics Wireless Audio)
18:29:50: Using auxilary audio input: Microphone (2- Plantronics Wireless Audio)
18:29:50: Audio Encoding: AAC
18:29:50:     bitrate: 128
18:29:50: Using text output
18:29:50:     device: \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:29:50:     device id \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:29:50:     chosen type: I420, usingFourCC: false, res: 800x600 - 800x600, frameIntervals: 333333-2000000
18:29:50:     use buffering: false - 0, fourCC: 'I420'
18:29:50:     audio device: Disable,
18:29:50:     audio device id Disabled,
18:29:50:
18:29:50: Using directshow input
18:29:50: Using graphics capture
18:29:50: Using Window Capture
18:29:50: Scene buffering time set to 600
18:29:50: Video Encoding: x264
18:29:50:     fps: 30
18:29:50:     width: 1280, height: 720
18:29:50:     preset: veryfast
18:29:50:     profile: main
18:29:50:     keyint: 60
18:29:50:     CBR: yes
18:29:50:     CFR: yes
18:29:50:     max bitrate: 1800
18:29:50:     buffer size: 1800
18:30:39: SharedTexCapture hooked
18:32:06: Total frames encoded: 4056, total frames duplicated: 16 (0.39%)
18:32:06: Total frames rendered: 4057, number of late frames: 2 (0.05%) (it's okay for some frames to be late)
18:32:07:
18:32:07: Profiler time results:
18:32:07:
18:32:07: ==============================================================
18:32:07: video thread frame - [100%] [avg time: 2.054 ms] [children: 51.6%] [unaccounted: 48.4%]
18:32:07: | scene->Preprocess - [40.9%] [avg time: 0.84 ms]
18:32:07: | GPU download and conversion - [10.7%] [avg time: 0.22 ms] [children: 6.82%] [unaccounted: 3.89%]
18:32:07: | | flush - [3.99%] [avg time: 0.082 ms]
18:32:07: | | CopyResource - [2.63%] [avg time: 0.054 ms]
18:32:07: | | conversion to 4:2:0 - [0.195%] [avg time: 0.004 ms]
18:32:07: Convert444Thread - [100%] [avg time: 1.724 ms] [children: 99.3%] [unaccounted: 0.696%]
18:32:07: | Convert444toNV12 - [99.3%] [avg time: 1.712 ms]
18:32:07: encoder thread frame - [100%] [avg time: 1.709 ms] [children: 0.351%] [unaccounted: 99.6%]
18:32:07: | sending stuff out - [0.351%] [avg time: 0.006 ms]
18:32:07:
18:32:07:
18:32:07: Profiler CPU results:
18:32:07:
18:32:07: video thread frame - [cpu time: avg 0.98 ms, total 3978.03 ms] [avg calls per frame: 1]
18:32:07: | scene->Preprocess - [cpu time: avg 0.284 ms, total 1154.4 ms] [avg calls per frame: 1]
18:32:07: | GPU download and conversion - [cpu time: avg 0.08 ms, total 327.604 ms] [avg calls per frame: 1]
18:32:07: | | flush - [cpu time: avg 0.049 ms, total 202.803 ms] [avg calls per frame: 1]
18:32:07: | | CopyResource - [cpu time: avg 0.015 ms, total 62.401 ms] [avg calls per frame: 1]
18:32:07: | | conversion to 4:2:0 - [cpu time: avg 0.003 ms, total 15.6 ms] [avg calls per frame: 1]
18:32:07: Convert444Thread - [cpu time: avg 1.677 ms, total 6770.44 ms] [avg calls per frame: 1]
18:32:07: | Convert444toNV12 - [cpu time: avg 1.665 ms, total 6723.64 ms] [avg calls per frame: 1]
18:32:07: encoder thread frame - [cpu time: avg 1.104 ms, total 4461.63 ms] [avg calls per frame: 1]
18:32:07: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
18:32:07:
18:32:07: =====Stream End: 2014-03-07, 18:32:07=================================================
Last game capture log:
2014-03-07, 18:30:30: we're booting up:
18:30:30: CaptureThread: attached to process League of Legends.exe
18:30:30: D3D9 Present
18:30:30: DXGI Present
18:30:30: NV Capture available
18:30:30: FBO available
18:30:30: GL Present
18:30:30: (half life scientist) everything..  seems to be in order
18:30:39: D3D9EndScene called
18:30:39: D3DPRESENT_PARAMETERS {
18:30:39: 	BackBufferWidth: 1920
18:30:39: 	BackBufferHeight: 1080
18:30:39: 	BackBufferFormat: D3DFMT_X8R8G8B8
18:30:39: 	BackBufferCount: 1
18:30:39: 	MultiSampleType: D3DMULTISAMPLE_NONE
18:30:39: 	MultiSampleQuality: 0
18:30:39: 	SwapEffect: D3DSWAPEFFECT_DISCARD
18:30:39: 	hDeviceWindow: 198170
18:30:39: 	Windowed: true
18:30:39: 	EnableAutoDepthStencil: true
18:30:39: 	AutoDepthStencilFormat: D3DFMT_D24S8
18:30:39: 	Flags: D3DPRESENTFLAG_DISCARD_DEPTHSTENCIL
18:30:39: 	FullScreen_RefreshRateInHz: 0
18:30:39: 	PresentationInterval: 2147483648
18:30:39: };
18:30:39: successfully set up d3d9 hooks
18:30:39: D3D9Present called
18:30:39: DoD3D9GPUHook: success
18:30:51: D3DSURFACE_DESC {
18:30:51: 	Format: D3DFMT_X8R8G8B8
18:30:51: 	Type: D3DRTYPE_SURFACE
18:30:51: 	Usage: D3DUSAGE_RENDERTARGET
18:30:51: 	Pool: D3DPOOL_DEFAULT
18:30:51: 	MultiSampleType: D3DMULTISAMPLE_NONE
18:30:51: 	MultiSampleQuality: 0
18:30:51: 	Width: 1920
18:30:51: 	Height: 1080
18:30:51: };
18:30:51: successfully capturing d3d9 frames via GPU
Lain
Lain
Hm, this is indeed really weird, but are you sure that log file is the right log file? Or does this happen every time? It's strange that OBS isn't really reporting the problem here. Hmm, and I'm somewhat worried about that headset.
Okay, I want to test out a theory. Go in to advanced settings, turn on "sync audio timestamps to video timestamps", then try recording a video, and see if it happens in that video. If it suddenly works, it means that the timing data from your headset was off. If it doesn't do anything to help, then turn it off, and send me the log file from that session again.
MrPantsu
ok so I tried syncing audio timestamps and the problems still persits
here is the new log file
18:50:51: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
18:50:51: CUDA loaded successfully
18:50:51: 1 CUDA capable devices found
18:50:51: [ GPU #0 - < GeForce GTX 650 > has Compute SM 3.0, NVENC Available ]
18:51:34: Open Broadcaster Software v0.613b - 32bit (´・ω・`)
18:51:34: -------------------------------
18:51:34: CPU Name: AMD FX(tm)-4130 Quad-Core Processor
18:51:34: CPU Speed: 3817MHz
18:51:34: Physical Memory:  4095MB Total, 4095MB Free
18:51:34: stepping id: 2, model 1, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
18:51:34: monitor 1: pos={0, 0}, size={1920, 1080}
18:51:34: monitor 2: pos={-1600, 180}, size={1600, 900}
18:51:34: Windows Version: 6.2 Build 9200
18:51:34: Aero is Enabled
18:51:34: OBS Modules:
18:51:34: Base Address     Module
18:51:34: 00BA0000         OBS.exe
18:51:34: 5A7A0000         OBSApi.dll
18:51:34: 5A510000         DShowPlugin.dll
18:51:34: 5A4F0000         GraphicsCapture.dll
18:51:34: 5A4D0000         NoiseGate.dll
18:51:34: 5A4B0000         PSVPlugin.dll
18:51:34: ------------------------------------------
18:51:34: Adapter 1
18:51:34:   Video Adapter: NVIDIA GeForce GTX 650
18:51:34:   Video Adapter Dedicated Video Memory: 1020985344
18:51:34:   Video Adapter Shared System Memory: 3221221376
18:51:34:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:51:34:   Video Adapter Output 2: pos={-1600, 180}, size={1600, 900}, attached=true
18:51:34: =====Stream Start: 2014-03-10, 18:51:34===============================================
18:51:34:   Multithreaded optimizations: On
18:51:34:   Base resolution: 1920x1080
18:51:34:   Output resolution: 1280x720
18:51:34: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
18:51:34: Audio Format: 48000 Hz
18:51:34: Audio Channels: 2 Ch
18:51:34: Playback device Default
18:51:34: Using desktop audio input: Speakers (2- Plantronics Wireless Audio)
18:51:34: Using auxilary audio input: Microphone (2- Plantronics Wireless Audio)
18:51:34: Audio Encoding: AAC
18:51:34:     bitrate: 128
18:51:34:     device: \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:51:34:     device id \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:51:34:     chosen type: I420, usingFourCC: false, res: 800x600 - 800x600, frameIntervals: 333333-2000000
18:51:34:     use buffering: false - 0, fourCC: 'I420'
18:51:34:     audio device: Disable,
18:51:34:     audio device id Disabled,
18:51:34:
18:51:34: Using directshow input
18:51:34: Using graphics capture
18:51:34: Using Window Capture
18:51:35: Scene buffering time set to 900
18:51:36: ------------------------------------------
18:51:36: Video Encoding: x264
18:51:36:     fps: 30
18:51:36:     width: 1280, height: 720
18:51:36:     preset: veryfast
18:51:36:     profile: main
18:51:36:     keyint: 60
18:51:36:     CBR: yes
18:51:36:     CFR: yes
18:51:36:     max bitrate: 1800
18:51:36:     buffer size: 1800
18:51:36: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
18:52:26: SharedTexCapture hooked
18:54:23: Total frames encoded: 4983, total frames duplicated: 83 (1.67%)
18:54:23: Number of frames skipped due to encoder lag: 33 (0.66%)
18:54:23: Total frames rendered: 4948, number of late frames: 6 (0.12%) (it's okay for some frames to be late)
18:54:23:
18:54:23: Profiler time results:
18:54:23:
18:54:23: ==============================================================
18:54:23: video thread frame - [100%] [avg time: 2.165 ms] [children: 51.7%] [unaccounted: 48.3%]
18:54:23: | scene->Preprocess - [39.9%] [avg time: 0.863 ms]
18:54:23: | GPU download and conversion - [11.9%] [avg time: 0.257 ms] [children: 8.68%] [unaccounted: 3.19%]
18:54:23: | | flush - [4.8%] [avg time: 0.104 ms]
18:54:23: | | CopyResource - [3.7%] [avg time: 0.08 ms]
18:54:23: | | conversion to 4:2:0 - [0.185%] [avg time: 0.004 ms]
18:54:23: Convert444Thread - [100%] [avg time: 1.734 ms] [children: 99.4%] [unaccounted: 0.634%]
18:54:23: | Convert444toNV12 - [99.4%] [avg time: 1.723 ms]
18:54:23: encoder thread frame - [100%] [avg time: 2.288 ms] [children: 0.262%] [unaccounted: 99.7%]
18:54:23: | sending stuff out - [0.262%] [avg time: 0.006 ms]
18:54:23:
18:54:23:
18:54:23: Profiler CPU results:
18:54:23:
18:54:23: video thread frame - [cpu time: avg 0.945 ms, total 4680.03 ms] [avg calls per frame: 1]
18:54:23: | scene->Preprocess - [cpu time: avg 0.204 ms, total 1014.01 ms] [avg calls per frame: 1]
18:54:23: | GPU download and conversion - [cpu time: avg 0.097 ms, total 483.607 ms] [avg calls per frame: 1]
18:54:23: | | flush - [cpu time: avg 0.04 ms, total 202.805 ms] [avg calls per frame: 1]
18:54:23: | | CopyResource - [cpu time: avg 0.031 ms, total 156.002 ms] [avg calls per frame: 1]
18:54:23: | | conversion to 4:2:0 - [cpu time: avg 0.006 ms, total 31.2 ms] [avg calls per frame: 1]
18:54:23: Convert444Thread - [cpu time: avg 1.49 ms, total 7332.05 ms] [avg calls per frame: 1]
18:54:23: | Convert444toNV12 - [cpu time: avg 1.487 ms, total 7316.45 ms] [avg calls per frame: 1]
18:54:23: encoder thread frame - [cpu time: avg 1.104 ms, total 5475.64 ms] [avg calls per frame: 1]
18:54:23: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
18:54:23:
18:54:23: =====Stream End: 2014-03-10, 18:54:23=================================================
18:54:41: =====Stream Start: 2014-03-10, 18:54:41===============================================
18:54:41:   Multithreaded optimizations: On
18:54:41:   Base resolution: 1920x1080
18:54:41:   Output resolution: 1280x720
18:54:41: ------------------------------------------
18:54:41: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
18:54:41: Audio Format: 48000 Hz
18:54:41: Audio Channels: 2 Ch
18:54:41: Playback device Default
18:54:41: Using desktop audio input: Speakers (2- Plantronics Wireless Audio)
18:54:41: Using auxilary audio input: Microphone (2- Plantronics Wireless Audio)
18:54:41: Audio Encoding: AAC
18:54:41:     bitrate: 128
18:54:41:     device: \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:54:41:     device id \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:54:41:     chosen type: I420, usingFourCC: false, res: 800x600 - 800x600, frameIntervals: 333333-2000000
18:54:41:     use buffering: false - 0, fourCC: 'I420'
18:54:41:     audio device: Disable,
18:54:41:     audio device id Disabled,
18:54:41:
18:54:41: Using directshow input
18:54:41: Using graphics capture
18:54:41: Using Window Capture
18:54:41: Scene buffering time set to 900
18:54:41: Video Encoding: x264
18:54:41:     fps: 30
18:54:41:     width: 1280, height: 720
18:54:41:     preset: veryfast
18:54:41:     profile: main
18:54:41:     keyint: 60
18:54:41:     CBR: yes
18:54:41:     CFR: yes
18:54:41:     max bitrate: 1800
18:54:41:     buffer size: 1800
18:54:41: SharedTexCapture hooked
18:54:44: Using RTMP service: Twitch / Justin.tv
18:54:44:   Server selection: rtmp://live.justin.tv/app
18:54:44:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
18:54:44: Completed handshake with rtmp://live.justin.tv/app in 64 ms.
18:54:44: SO_SNDBUF was at 65536
18:54:44: SO_SNDBUF is now 65536
18:54:46: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 69549 / 246784)
18:55:25: RTMPPublisher::SocketLoop: Stalled for 1898 ms to write 12298 bytes (buffer: 0 / 246784), unstable connection?
18:56:09: Total frames encoded: 2617, total frames duplicated: 63 (2.41%)
18:56:09: Number of frames skipped due to encoder lag: 16 (0.61%)
18:56:09: Total frames rendered: 2601, number of late frames: 7 (0.27%) (it's okay for some frames to be late)
18:56:10: RTMPPublisher::SocketLoop: Graceful loop exit
18:56:10: Average send payload: 5092 bytes, average send interval: 23 ms
18:56:10: Number of times waited to send: 0, Waited for a total of 0 bytes
18:56:10: Number of b-frames dropped: 150 (6%), Number of p-frames dropped: 178 (7.1%), Total 328 (13%)
18:56:10: Number of bytes sent: 18266369
18:56:10:
18:56:10: Profiler time results:
18:56:10:
18:56:10: ==============================================================
18:56:10: video thread frame - [100%] [avg time: 3.049 ms] [children: 51.1%] [unaccounted: 48.9%]
18:56:10: | scene->Preprocess - [33%] [avg time: 1.006 ms]
18:56:10: | GPU download and conversion - [18.1%] [avg time: 0.551 ms] [children: 13.6%] [unaccounted: 4.49%]
18:56:10: | | flush - [6.95%] [avg time: 0.212 ms]
18:56:10: | | CopyResource - [6.46%] [avg time: 0.197 ms]
18:56:10: | | conversion to 4:2:0 - [0.164%] [avg time: 0.005 ms]
18:56:10: Convert444Thread - [100%] [avg time: 2.319 ms] [children: 99.1%] [unaccounted: 0.862%]
18:56:10: | Convert444toNV12 - [99.1%] [avg time: 2.299 ms]
18:56:10: encoder thread frame - [100%] [avg time: 3.183 ms] [children: 4.21%] [unaccounted: 95.8%]
18:56:10: | sending stuff out - [4.21%] [avg time: 0.134 ms]
18:56:10:
18:56:10:
18:56:10: Profiler CPU results:
18:56:10:
18:56:10: video thread frame - [cpu time: avg 1.097 ms, total 2854.82 ms] [avg calls per frame: 1]
18:56:10: | scene->Preprocess - [cpu time: avg 0.311 ms, total 811.204 ms] [avg calls per frame: 1]
18:56:10: | GPU download and conversion - [cpu time: avg 0.119 ms, total 312 ms] [avg calls per frame: 1]
18:56:10: | | flush - [cpu time: avg 0.077 ms, total 202.8 ms] [avg calls per frame: 1]
18:56:10: | | CopyResource - [cpu time: avg 0.012 ms, total 31.2 ms] [avg calls per frame: 1]
18:56:10: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
18:56:10: Convert444Thread - [cpu time: avg 1.644 ms, total 4227.63 ms] [avg calls per frame: 1]
18:56:10: | Convert444toNV12 - [cpu time: avg 1.632 ms, total 4196.43 ms] [avg calls per frame: 1]
18:56:10: encoder thread frame - [cpu time: avg 1.403 ms, total 3634.82 ms] [avg calls per frame: 1]
18:56:10: | sending stuff out - [cpu time: avg 0.072 ms, total 187.201 ms] [avg calls per frame: 1]
18:56:10:
18:56:10: =====Stream End: 2014-03-10, 18:56:10=================================================
18:57:07: =====Stream Start: 2014-03-10, 18:57:07===============================================
18:57:07:   Multithreaded optimizations: On
18:57:07:   Base resolution: 1920x1080
18:57:07:   Output resolution: 1280x720
18:57:07: ------------------------------------------
18:57:07: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
18:57:07: Audio Format: 48000 Hz
18:57:07: Audio Channels: 2 Ch
18:57:07: Playback device Default
18:57:07: Using desktop audio input: Speakers (2- Plantronics Wireless Audio)
18:57:07: Using auxilary audio input: Microphone (2- Plantronics Wireless Audio)
18:57:08: ------------------------------------------
18:57:08: Audio Encoding: AAC
18:57:08:     bitrate: 128
18:57:08:     device: \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:57:08:     device id \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:57:08:     chosen type: I420, usingFourCC: false, res: 800x600 - 800x600, frameIntervals: 333333-2000000
18:57:08:     use buffering: false - 0, fourCC: 'I420'
18:57:08:     audio device: Disable,
18:57:08:     audio device id Disabled,
18:57:08:
18:57:08: Using directshow input
18:57:08: Using graphics capture
18:57:08: Using Window Capture
18:57:08: Scene buffering time set to 900
18:57:08: Video Encoding: x264
18:57:08:     fps: 30
18:57:08:     width: 1280, height: 720
18:57:08:     preset: veryfast
18:57:08:     profile: main
18:57:08:     keyint: 60
18:57:08:     CBR: yes
18:57:08:     CFR: yes
18:57:08:     max bitrate: 1800
18:57:08:     buffer size: 1800
18:57:11: Using RTMP service: Twitch / Justin.tv
18:57:11:   Server selection: rtmp://live.justin.tv/app
18:57:11:   Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
18:57:11: Completed handshake with rtmp://live.justin.tv/app in 52 ms.
18:57:11: SO_SNDBUF was at 65536
18:57:11: SO_SNDBUF is now 65536
18:57:13: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 0 / 246784)
18:58:01: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 246784)
18:58:01: SharedTexCapture hooked
18:58:08: ------------------------------------------
18:58:08:     device: \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:58:08:     device id \\?\usb#vid_046d&pid_081b&mi_00#8&e433b86&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:58:08:     chosen type: I420, usingFourCC: false, res: 800x600 - 800x600, frameIntervals: 333333-2000000
18:58:08:     use buffering: false - 0, fourCC: 'I420'
18:58:08:     audio device: Disable,
18:58:08:     audio device id Disabled,
18:58:08:
18:58:08: Using directshow input
18:58:47: GraphicsCaptureSource::NewCapture:  eliminating old capture
18:58:47: SharedTexCapture hooked
19:01:46: GraphicsCaptureSource::NewCapture:  eliminating old capture
19:01:46: SharedTexCapture hooked
19:02:28: Total frames encoded: 9565, total frames duplicated: 48 (0.50%)
19:02:28: Total frames rendered: 9558, number of late frames: 3 (0.03%) (it's okay for some frames to be late)
19:02:28: RTMPPublisher::SocketLoop: Graceful loop exit
19:02:28: Average send payload: 5191 bytes, average send interval: 22 ms
19:02:28: Number of times waited to send: 0, Waited for a total of 0 bytes
19:02:28: Number of b-frames dropped: 128 (1.4%), Number of p-frames dropped: 162 (1.7%), Total 290 (3.1%)
19:02:28: Number of bytes sent: 74356867
19:02:28:
19:02:28: Profiler time results:
19:02:28:
19:02:28: ==============================================================
19:02:28: video thread frame - [100%] [avg time: 2.132 ms] [children: 48.1%] [unaccounted: 51.9%]
19:02:28: | scene->Preprocess - [37.2%] [avg time: 0.793 ms]
19:02:28: | GPU download and conversion - [10.9%] [avg time: 0.233 ms] [children: 8.11%] [unaccounted: 2.81%]
19:02:28: | | flush - [5.11%] [avg time: 0.109 ms]
19:02:28: | | CopyResource - [2.77%] [avg time: 0.059 ms]
19:02:28: | | conversion to 4:2:0 - [0.235%] [avg time: 0.005 ms]
19:02:28: Convert444Thread - [100%] [avg time: 1.62 ms] [children: 99.3%] [unaccounted: 0.741%]
19:02:28: | Convert444toNV12 - [99.3%] [avg time: 1.608 ms]
19:02:28: encoder thread frame - [100%] [avg time: 1.669 ms] [children: 4.73%] [unaccounted: 95.3%]
19:02:28: | sending stuff out - [4.73%] [avg time: 0.079 ms]
19:02:28:
19:02:28:
19:02:28: Profiler CPU results:
19:02:28:
19:02:28: video thread frame - [cpu time: avg 0.949 ms, total 9079.26 ms] [avg calls per frame: 1]
19:02:28: | scene->Preprocess - [cpu time: avg 0.217 ms, total 2074.81 ms] [avg calls per frame: 1]
19:02:28: | GPU download and conversion - [cpu time: avg 0.078 ms, total 748.803 ms] [avg calls per frame: 1]
19:02:28: | | flush - [cpu time: avg 0.032 ms, total 312.002 ms] [avg calls per frame: 1]
19:02:28: | | CopyResource - [cpu time: avg 0.014 ms, total 140.401 ms] [avg calls per frame: 1]
19:02:28: | | conversion to 4:2:0 - [cpu time: avg 0.004 ms, total 46.8 ms] [avg calls per frame: 1]
19:02:28: Convert444Thread - [cpu time: avg 1.47 ms, total 14008.9 ms] [avg calls per frame: 1]
19:02:28: | Convert444toNV12 - [cpu time: avg 1.47 ms, total 14008.9 ms] [avg calls per frame: 1]
19:02:28: encoder thread frame - [cpu time: avg 1.069 ms, total 10202.5 ms] [avg calls per frame: 1]
19:02:28: | sending stuff out - [cpu time: avg 0.016 ms, total 156.001 ms] [avg calls per frame: 1]
19:02:28:
19:02:28: =====Stream End: 2014-03-10, 19:02:28=================================================
2014-03-10, 18:57:53: we're booting up:
18:57:53: CaptureThread: attached to process League of Legends.exe
18:57:54: D3D9 Present
18:57:54: DXGI Present
18:57:54: NV Capture available
18:57:54: FBO available
18:57:54: GL Present
18:57:54: (half life scientist) everything..  seems to be in order
18:58:01: D3D9EndScene called
18:58:01: D3DPRESENT_PARAMETERS {
18:58:01: 	BackBufferWidth: 1920
18:58:01: 	BackBufferHeight: 1080
18:58:01: 	BackBufferFormat: D3DFMT_X8R8G8B8
18:58:01: 	BackBufferCount: 1
18:58:01: 	MultiSampleType: D3DMULTISAMPLE_NONE
18:58:01: 	MultiSampleQuality: 0
18:58:01: 	SwapEffect: D3DSWAPEFFECT_DISCARD
18:58:01: 	hDeviceWindow: 329096
18:58:01: 	Windowed: true
18:58:01: 	EnableAutoDepthStencil: true
18:58:01: 	AutoDepthStencilFormat: D3DFMT_D24S8
18:58:01: 	Flags: D3DPRESENTFLAG_DISCARD_DEPTHSTENCIL
18:58:01: 	FullScreen_RefreshRateInHz: 0
18:58:01: 	PresentationInterval: 2147483648
18:58:01: };
18:58:01: successfully set up d3d9 hooks
18:58:01: D3D9Present called
18:58:01: DoD3D9GPUHook: success
18:58:13: D3DSURFACE_DESC {
18:58:13: 	Format: D3DFMT_X8R8G8B8
18:58:13: 	Type: D3DRTYPE_SURFACE
18:58:13: 	Usage: D3DUSAGE_RENDERTARGET
18:58:13: 	Pool: D3DPOOL_DEFAULT
18:58:13: 	MultiSampleType: D3DMULTISAMPLE_NONE
18:58:13: 	MultiSampleQuality: 0
18:58:13: 	Width: 1920
18:58:13: 	Height: 1080
18:58:13: };
18:58:13: successfully capturing d3d9 frames via GPU
18:58:47: D3D9Reset called
18:58:47: ---------------------- Cleared D3D9 Capture ----------------------
18:58:47: successfully set up d3d9 hooks
18:58:47: D3D9EndScene called
18:58:47: D3D9Present called
18:58:47: DoD3D9GPUHook: success
18:58:47: D3DSURFACE_DESC {
18:58:47: 	Format: D3DFMT_X8R8G8B8
18:58:47: 	Type: D3DRTYPE_SURFACE
18:58:47: 	Usage: D3DUSAGE_RENDERTARGET
18:58:47: 	Pool: D3DPOOL_DEFAULT
18:58:47: 	MultiSampleType: D3DMULTISAMPLE_NONE
18:58:47: 	MultiSampleQuality: 0
18:58:47: 	Width: 1920
18:58:47: 	Height: 1080
18:58:47: };
18:58:47: successfully capturing d3d9 frames via GPU
19:01:45: D3D9Reset called
19:01:45: ---------------------- Cleared D3D9 Capture ----------------------
19:01:45: successfully set up d3d9 hooks
19:01:45: D3D9EndScene called
19:01:45: D3D9Present called
19:01:45: DoD3D9GPUHook: success
19:01:46: D3DSURFACE_DESC {
19:01:46: 	Format: D3DFMT_X8R8G8B8
19:01:46: 	Type: D3DRTYPE_SURFACE
19:01:46: 	Usage: D3DUSAGE_RENDERTARGET
19:01:46: 	Pool: D3DPOOL_DEFAULT
19:01:46: 	MultiSampleType: D3DMULTISAMPLE_NONE
19:01:46: 	MultiSampleQuality: 0
19:01:46: 	Width: 1920
19:01:46: 	Height: 1080
19:01:46: };
19:01:46: successfully capturing d3d9 frames via GPU
EDIT: I played a game without OBS open and it still did the same thing after a few minutes. Guess i have to return another headset........... :(
