Bug Report Audio stutters and gets out of synch.
Hans
Hey guys,
a few weeks ago problems started when i used my Avermedia LGP lite with the Avermedia Stream engine on OBS (But only if i stream, recording works just fine!) The Audio (only from the Capture Card) starts stuttering and cracking. I tried everything to fix the problem by myself. Changing the audio Source of the capture device (and any other option) didn´t worked. The Audio goes out of synch when the stuttering and cracking stops after 5 min. But after some minutes later the problems start again. It would be awesome if you could help me out, it drives me mad! I hope the upload of the logs worked!
Thank you in advantage !
Hans
Ok, i figured something out... when i use the global source tool for my web cam and the capture card it seems that the audio does not stutter anymore...
