16:55:21: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
16:55:21: -------------------------------
16:55:21: CPU Name: AMD FX(tm)-4100 Quad-Core Processor
16:55:21: CPU Speed: 3616MHz
16:55:21: Physical Memory: 4095MB Total, 4095MB Free
16:55:21: stepping id: 2, model 1, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
16:55:21: monitor 1: pos={0, 0}, size={1920, 1080}
16:55:21: Windows Version: 6.1 Build 7601 S
16:55:21: Aero is Disabled
16:55:21: OBS Modules:
16:55:21: Base Address Module
16:55:21: 00C80000 OBS.exe
16:55:21: 581B0000 OBSApi.dll
16:55:21: 58480000 DShowPlugin.dll
16:55:21: 597A0000 GraphicsCapture.dll
16:55:21: 59780000 NoiseGate.dll
16:55:21: ------------------------------------------
16:55:21: Adapter 1
16:55:21: Video Adapter: NVIDIA GeForce GTX 560
16:55:21: Video Adapter Dedicated Video Memory: 2096562176
16:55:21: Video Adapter Shared System Memory: 2147037184
16:55:21: =====Stream Start: 2013-05-31, 16:55:21===============================================
16:55:21: Multithreaded optimizations: On
16:55:21: Base resolution: 1280x720
16:55:21: Output resolution: 1280x720
16:55:21: Loading up D3D10...
16:55:21: Playback device Default
16:55:21: Using desktop audio input: Speakers (3- Logitech USB Headset)
16:55:21: Using auxilary audio input: Microphone (3- Logitech USB Headset)
16:55:21: Audio Encoding: AAC
16:55:21: bitrate: 128
16:55:21: Using bitmap image
16:55:21: Video Encoding: x264
16:55:21: fps: 30
16:55:21: width: 1280, height: 720
16:55:21: preset: veryfast
16:55:21: CBR: no
16:55:21: CFR: no
16:55:21: max bitrate: 1700
16:55:21: buffer size: 4000
16:55:21: quality: 7
16:55:23: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:55:23: New Scene
16:55:23: Using Window Capture
16:55:23: Using text output
16:55:23: Using bitmap image
16:55:24: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:55:24: New Scene
16:55:24: Using bitmap image
16:55:24: New Scene
16:55:24: Using Window Capture
16:55:26: Using graphics capture
16:55:27: SharedTexCapture hooked
16:55:27: Using Monitor Capture
16:55:29: Total frames rendered: 253, number of frames that lagged: 2 (0.79%) (it's okay for some frames to lag)
16:55:29: =====Stream End: 2013-05-31, 16:55:29=================================================
16:55:30: =====Stream Start: 2013-05-31, 16:55:30===============================================
16:55:30: Multithreaded optimizations: On
16:55:30: Base resolution: 1280x720
16:55:30: Output resolution: 1280x720
16:55:30: ------------------------------------------
16:55:30: Loading up D3D10...
16:55:30: Playback device Default
16:55:30: Using desktop audio input: Speakers (3- Logitech USB Headset)
16:55:31: ------------------------------------------
16:55:31: Using auxilary audio input: Microphone (3- Logitech USB Headset)
16:55:31: Audio Encoding: AAC
16:55:31: bitrate: 128
16:55:31: Using Monitor Capture
16:55:31: Using graphics capture
16:55:31: Video Encoding: x264
16:55:31: fps: 30
16:55:31: width: 1280, height: 720
16:55:31: preset: veryfast
16:55:31: CBR: no
16:55:31: CFR: no
16:55:31: max bitrate: 1700
16:55:31: buffer size: 4000
16:55:31: quality: 7
16:55:31: SharedTexCapture hooked
17:01:35: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:01:35: New Scene
17:01:35: Using bitmap image
17:02:11: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:02:11: New Scene
17:02:11: Using Monitor Capture
17:02:11: Using graphics capture
17:02:12: SharedTexCapture hooked
17:25:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:25:54: New Scene
17:25:54: Using Window Capture
17:25:54: Using text output
17:25:54: Using bitmap image
17:26:04: Total frames rendered: 57350, number of frames that lagged: 168 (0.29%) (it's okay for some frames to lag)
17:26:04: =====Stream End: 2013-05-31, 17:26:04=================================================
17:30:27:
17:30:27: Profiler results:
17:30:27:
17:30:27: ==============================================================
17:30:27: frame - [100%] [avg time: 2.901 ms] [avg calls per frame: 1] [children: 78.7%] [unaccounted: 21.3%]
17:30:27: | scene->Preprocess - [12.1%] [avg time: 0.351 ms] [avg calls per frame: 1]
17:30:27: | video encoding and uploading - [66.6%] [avg time: 1.933 ms] [avg calls per frame: 1] [children: 65.7%] [unaccounted: 0.965%]
17:30:27: | | CopyResource - [0.62%] [avg time: 0.018 ms] [avg calls per frame: 0]
17:30:27: | | conversion to 4:2:0 - [2.62%] [avg time: 0.076 ms] [avg calls per frame: 0]
17:30:27: | | call to encoder - [61%] [avg time: 1.771 ms] [avg calls per frame: 0]
17:30:27: | | sending stuff out - [1.38%] [avg time: 0.04 ms] [avg calls per frame: 0]
17:30:27:
