21:41:04: CLR host plugin strings not found, dynamically loading 4 strings
21:41:04: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
21:41:04: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
21:41:04: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
21:41:04: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
21:41:04: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
21:41:04: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
21:41:05: CLRHost:: Could not find/load browser settings at location C:\Users\Admin\AppData\Roaming\OBS\pluginData\browser.json
21:41:05: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
21:41:05: Video Source Plugin strings not found, dynamically loading 38 strings
21:41:08: Open Broadcaster Software v0.60b test build 9 - 32bit (´・ω・`)
21:41:08: -------------------------------
21:41:08: CPU Name: AMD Phenom(tm) II X6 1090T Processor
21:41:08: CPU Speed: 3812MHz
21:41:08: Physical Memory: 4095MB Total, 4095MB Free
21:41:08: stepping id: 0, model 10, family 16, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
21:41:08: monitor 1: pos={0, 0}, size={1920, 1080}
21:41:08: monitor 2: pos={-1920, 0}, size={1920, 1080}
21:41:08: Windows Version: 6.1 Build 7601 S
21:41:08: Aero is Disabled
21:41:08: OBS Modules:
21:41:08: Base Address Module
21:41:08: 00310000 OBS.exe
21:41:08: 6F8E0000 OBSApi.dll
21:41:08: 74580000 CLRHostPlugin.dll
21:41:08: 72E90000 DShowPlugin.dll
21:41:08: 742F0000 GraphicsCapture.dll
21:41:08: 74230000 NoiseGate.dll
21:41:08: 741E0000 PSVPlugin.dll
21:41:08: 741A0000 scenesw.dll
21:41:08: 74670000 VideoSourcePluginWrapper.dll
21:41:08: ------------------------------------------
21:41:08: Adapter 1
21:41:08: Video Adapter: AMD Radeon HD 7900 Series
21:41:08: Video Adapter Dedicated Video Memory: 3198189568
21:41:08: Video Adapter Shared System Memory: 1096712192
21:41:08: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
21:41:08: Video Adapter Output 2: pos={-1920, 0}, size={1920, 1080}, attached=true
21:41:08: =====Stream Start: 2014-02-11, 21:41:08===============================================
21:41:08: Multithreaded optimizations: On
21:41:08: Base resolution: 1280x720
21:41:08: Output resolution: 1280x720
21:41:08: Loading up D3D10 on AMD Radeon HD 7900 Series (Adapter 1)...
21:41:08: Audio Format: 44100hz
21:41:08: Playback device Default
21:41:08: Using desktop audio input: 1 - AVERMEDIA HD (AMD High Definition Audio Device)
21:41:08: Using auxilary audio input: Microphone (2- Wireless Stereo Headset)
21:41:08: Audio Encoding: AAC
21:41:08: bitrate: 96
21:41:08: Using bitmap image
21:41:08: device: Logitech HD Webcam C525,
21:41:08: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
21:41:08: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
21:41:08: use buffering: false - 0, fourCC: 'I420'
21:41:08: audio device: Disable,
21:41:08: audio device id Disabled,
21:41:08:
21:41:08: Using directshow input
21:41:08: device: AVerMedia HD Capture C985 Bus 2,
21:41:08: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
21:41:08: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
21:41:08: use buffering: false - 30000000, fourCC: 'YV12'
21:41:08:
21:41:08: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
21:41:08: Using Video Source
21:41:08: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
21:41:08: Scene buffering time set to 700
21:41:08: Video Encoding: x264
21:41:08: fps: 30
21:41:08: width: 1280, height: 720
21:41:08: preset: veryfast
21:41:08: profile: main
21:41:08: keyint: 250
21:41:08: CBR: yes
21:41:08: CFR: yes
21:41:08: max bitrate: 2500
21:41:08: buffer size: 2500
21:41:08: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
21:41:09: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 102415564
21:41:12: CLRHost:: Browser 1: Status message:
21:41:12: CLRHost:: Browser 1: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:14: CLRHost:: Browser 1: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:15: Total frames encoded: 172, total frames duplicated: 12 (6.98%)
21:41:15: Total frames rendered: 178, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:41:16:
21:41:16: Profiler time results:
21:41:16:
21:41:16: ==============================================================
21:41:16: video thread frame - [100%] [avg time: 12.794 ms] [children: 43.2%] [unaccounted: 56.8%]
21:41:16: | scene->Preprocess - [38.5%] [avg time: 4.93 ms]
21:41:16: | GPU download and conversion - [4.67%] [avg time: 0.598 ms] [children: 4.37%] [unaccounted: 0.305%]
21:41:16: | | flush - [4.14%] [avg time: 0.53 ms]
21:41:16: | | CopyResource - [0.149%] [avg time: 0.019 ms]
21:41:16: | | conversion to 4:2:0 - [0.0782%] [avg time: 0.01 ms]
21:41:16: Convert444Threads - [100%] [avg time: 1.154 ms] [children: 99.3%] [unaccounted: 0.693%]
21:41:16: | Convert444toNV12 - [99.3%] [avg time: 1.146 ms]
21:41:16: encoder thread frame - [100%] [avg time: 1.895 ms]
21:41:16:
21:41:16:
21:41:16: Profiler CPU results:
21:41:16:
21:41:16: video thread frame - [cpu time: avg 5.871 ms, total 1045.21 ms] [avg calls per frame: 1]
21:41:16: | scene->Preprocess - [cpu time: avg 4.732 ms, total 842.403 ms] [avg calls per frame: 1]
21:41:16: | GPU download and conversion - [cpu time: avg 0.087 ms, total 15.6 ms] [avg calls per frame: 1]
21:41:16: | | flush - [cpu time: avg 0.087 ms, total 15.6 ms] [avg calls per frame: 1]
21:41:16: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
21:41:16: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
21:41:16: Convert444Threads - [cpu time: avg 0.815 ms, total 249.601 ms] [avg calls per frame: 2]
21:41:16: | Convert444toNV12 - [cpu time: avg 0.815 ms, total 249.601 ms] [avg calls per frame: 2]
21:41:16: encoder thread frame - [cpu time: avg 1.446 ms, total 218.401 ms] [avg calls per frame: 1]
21:41:16:
21:41:16: =====Stream End: 2014-02-11, 21:41:16=================================================
21:41:17: =====Stream Start: 2014-02-11, 21:41:17===============================================
21:41:17: Multithreaded optimizations: On
21:41:17: Base resolution: 1280x720
21:41:17: Output resolution: 1280x720
21:41:17: ------------------------------------------
21:41:17: Loading up D3D10 on AMD Radeon HD 7900 Series (Adapter 1)...
21:41:17: Audio Format: 44100hz
21:41:17: Playback device Default
21:41:17: Using desktop audio input: 1 - AVERMEDIA HD (AMD High Definition Audio Device)
21:41:17: Using auxilary audio input: Microphone (2- Wireless Stereo Headset)
21:41:17: Audio Encoding: AAC
21:41:17: bitrate: 96
21:41:17: Using bitmap image
21:41:17: device: Logitech HD Webcam C525,
21:41:17: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
21:41:17: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
21:41:17: use buffering: false - 0, fourCC: 'I420'
21:41:17: audio device: Disable,
21:41:17: audio device id Disabled,
21:41:17:
21:41:17: Using directshow input
21:41:17: device: AVerMedia HD Capture C985 Bus 2,
21:41:17: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
21:41:17: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
21:41:17: use buffering: false - 30000000, fourCC: 'YV12'
21:41:17:
21:41:17: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
21:41:17: Using Video Source
21:41:17: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
21:41:18: CLRHost:: Browser 2: Status message:
21:41:18: Scene buffering time set to 700
21:41:18: ------------------------------------------
21:41:18: Video Encoding: x264
21:41:18: fps: 30
21:41:18: width: 1280, height: 720
21:41:18: preset: veryfast
21:41:18: profile: main
21:41:18: keyint: 250
21:41:18: CBR: yes
21:41:18: CFR: yes
21:41:18: max bitrate: 2500
21:41:18: buffer size: 2500
21:41:18: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
21:41:18:
21:41:18: Profiler result for the last frame:
21:41:18: ==============================================================
21:41:18: video thread frame - [time: 29.981 ms (cpu time: 15.6 ms)]
21:41:18: | scene->Preprocess - [time: 0.035 ms (cpu time: 0 ms)]
21:41:18: | GPU download and conversion - [time: 1.942 ms (cpu time: 0 ms)]
21:41:18: | | flush - [time: 0.031 ms (cpu time: 0 ms)]
21:41:18:
21:41:18: CLRHost:: Browser 2: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:18: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 102424714
21:41:19: CLRHost:: Browser 2: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:20: Using RTMP service: Twitch / Justin.tv
21:41:20: Server selection: rtmp://live-iad.justin.tv/app
21:41:20: Interface: Realtek RTL8139/810x Family Fast Ethernet NIC (ethernet, 100 mbps)
21:41:21: Completed handshake with rtmp://live-iad.justin.tv/app in 532 ms.
21:41:21: CLRHost:: Browser 2: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:41:21: New Scene
21:41:22: SO_SNDBUF was at 8192
21:41:22: SO_SNDBUF is now 65536
21:41:22: Using text output
21:41:22: Using bitmap image
21:41:22: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
21:41:22: CLRHost:: Browser 3: Status message:
21:41:22: CLRHost:: Browser 3: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:23: Using bitmap image
21:41:23: Using Video Source
21:41:23: PERFORMANCE WARNING: Scene change took 1773 ms, maybe some sources should be global sources?
21:41:24: CLRHost:: Browser 3: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:24: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 1623 / 331776)
21:41:24:
21:41:24: Profiler result for the last frame:
21:41:24: ==============================================================
21:41:24: video thread frame - [time: 5.365 ms (cpu time: 0 ms)]
21:41:24: | scene->Preprocess - [time: 0.048 ms (cpu time: 0 ms)]
21:41:24: | GPU download and conversion - [time: 0.172 ms (cpu time: 0 ms)]
21:41:24: | | flush - [time: 0.115 ms (cpu time: 0 ms)]
21:41:24: | | CopyResource - [time: 0.011 ms (cpu time: 0 ms)]
21:41:24: | | conversion to 4:2:0 - [time: 0.015 ms (cpu time: 0 ms)]
21:41:24: Convert444Threads - [time: 1.031 ms (cpu time: 0 ms)]
21:41:24: | Convert444toNV12 - [time: 1.02 ms (cpu time: 0 ms)]
21:41:24: encoder thread frame - [time: 1.418 ms (cpu time: 0 ms)]
21:41:24:
21:41:25:
21:41:25: Profiler result for the last frame:
21:41:25: ==============================================================
21:41:25: video thread frame - [time: 7.96 ms (cpu time: 0 ms)]
21:41:25: | scene->Preprocess - [time: 0.044 ms (cpu time: 0 ms)]
21:41:25: | GPU download and conversion - [time: 1.193 ms (cpu time: 0 ms)]
21:41:25: | | flush - [time: 1.162 ms (cpu time: 0 ms)]
21:41:25: | | CopyResource - [time: 0.012 ms (cpu time: 0 ms)]
21:41:25: | | conversion to 4:2:0 - [time: 0.004 ms (cpu time: 0 ms)]
21:41:25: Convert444Threads - [time: 1.056 ms (cpu time: 0 ms)]
21:41:25: | Convert444toNV12 - [time: 1.049 ms (cpu time: 0 ms)]
21:41:25: encoder thread frame - [time: 1.434 ms (cpu time: 0 ms)]
21:41:25:
21:41:25:
21:41:25: video thread frame - [time: 8.15 ms (cpu time: 0 ms)]
21:41:25: | scene->Preprocess - [time: 0.022 ms (cpu time: 0 ms)]
21:41:25: | GPU download and conversion - [time: 0.556 ms (cpu time: 0 ms)]
21:41:25: | | flush - [time: 0.521 ms (cpu time: 0 ms)]
21:41:25: | | CopyResource - [time: 0.01 ms (cpu time: 0 ms)]
21:41:25: | | conversion to 4:2:0 - [time: 0.003 ms (cpu time: 0 ms)]
21:41:25: Convert444Threads - [time: 0.903 ms (cpu time: 0 ms)]
21:41:25: | Convert444toNV12 - [time: 0.897 ms (cpu time: 0 ms)]
21:41:25: encoder thread frame - [time: 1.377 ms (cpu time: 0 ms)]
21:41:25:
21:41:25:
21:41:25: video thread frame - [time: 8.643 ms (cpu time: 0 ms)]
21:41:25: | scene->Preprocess - [time: 0.043 ms (cpu time: 0 ms)]
21:41:25: | GPU download and conversion - [time: 0.103 ms (cpu time: 0 ms)]
21:41:25: | | flush - [time: 0.078 ms (cpu time: 0 ms)]
21:41:25: | | CopyResource - [time: 0.009 ms (cpu time: 0 ms)]
21:41:25: Convert444Threads - [time: 0.966 ms (cpu time: 0 ms)]
21:41:25: | Convert444toNV12 - [time: 0.961 ms (cpu time: 0 ms)]
21:41:25: encoder thread frame - [time: 1.513 ms (cpu time: 0 ms)]
21:41:25:
21:41:25: CLRHost:: Browser 3: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:36: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 90
21:41:36: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 110
21:41:36: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 120
21:41:39: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:41:39: New Scene
21:41:39: Using bitmap image
21:41:39: ------------------------------------------
21:41:39: device: Logitech HD Webcam C525,
21:41:39: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
21:41:39: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
21:41:39: use buffering: false - 0, fourCC: 'I420'
21:41:39: audio device: Disable,
21:41:39: audio device id Disabled,
21:41:39:
21:41:39: Using directshow input
21:41:39: device: AVerMedia HD Capture C985 Bus 2,
21:41:39: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
21:41:39: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
21:41:39: use buffering: false - 30000000, fourCC: 'YV12'
21:41:39:
21:41:39: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
21:41:40: Using directshow input
21:41:40: Using bitmap image
21:41:40: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
21:41:40: Using Video Source
21:41:40: CLRHost:: Browser 4: Status message:
21:41:40: PERFORMANCE WARNING: Scene change took 775 ms, maybe some sources should be global sources?
21:41:40: CLRHost:: Browser 4: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:42: CLRHost:: Browser 4: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:41:43: CLRHost:: Browser 4: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:48:30: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:48:30: New Scene
21:48:32: Using text output
21:48:32: Using bitmap image
21:48:32: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
21:48:32: CLRHost:: Browser 5: Status message:
21:48:32: CLRHost:: Browser 5: Uncaught ReferenceError: $ is not defined @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248290
21:48:33: Using bitmap image
21:48:33: Using Video Source
21:48:33: PERFORMANCE WARNING: Scene change took 2768 ms, maybe some sources should be global sources?
21:52:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:52:36: New Scene
21:52:36: Using bitmap image
21:52:36: ------------------------------------------
21:52:36: device: Logitech HD Webcam C525,
21:52:36: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
21:52:36: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
21:52:36: use buffering: false - 0, fourCC: 'I420'
21:52:36: audio device: Disable,
21:52:36: audio device id Disabled,
21:52:36:
21:52:36: Using directshow input
21:52:36: device: AVerMedia HD Capture C985 Bus 2,
21:52:36: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
21:52:36: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
21:52:36: use buffering: false - 30000000, fourCC: 'YV12'
21:52:36:
21:52:36: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
21:52:36: Using Video Source
21:52:36: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
21:52:37: PERFORMANCE WARNING: Scene change took 798 ms, maybe some sources should be global sources?
21:52:37: CLRHost:: Browser 6: Status message:
21:52:37: CLRHost:: Browser 6: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:52:39: CLRHost:: Browser 6: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:52:41: CLRHost:: Browser 6: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
21:55:59: Audio timestamp for device 'AVerMedia HD Capture C985 Bus 2' was behind target timestamp by 70
22:08:40: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 140
22:14:09: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:15:28: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 150
22:15:33: Total frames encoded: 61636, total frames duplicated: 2827 (4.59%)
22:15:33: Number of frames skipped due to encoder lag: 35 (0.06%)
22:15:33: Total frames rendered: 61282, number of late frames: 60 (0.10%) (it's okay for some frames to be late)
22:15:34: RTMPPublisher::SocketLoop: Graceful loop exit
22:15:34: Average send payload: 7540 bytes, average send interval: 23 ms
22:15:34: Number of times waited to send: 0, Waited for a total of 0 bytes
22:15:34: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:15:34: Number of bytes sent: 667602114
22:15:34:
22:15:34: Profiler time results:
22:15:34:
22:15:34: ==============================================================
22:15:34: video thread frame - [100%] [avg time: 7.647 ms] [children: 39.8%] [unaccounted: 60.2%]
22:15:34: | scene->Preprocess - [32.9%] [avg time: 2.513 ms]
22:15:34: | GPU download and conversion - [6.98%] [avg time: 0.534 ms] [children: 6.04%] [unaccounted: 0.942%]
22:15:34: | | flush - [5.49%] [avg time: 0.42 ms]
22:15:34: | | CopyResource - [0.484%] [avg time: 0.037 ms]
22:15:34: | | conversion to 4:2:0 - [0.0654%] [avg time: 0.005 ms]
22:15:34: Convert444Threads - [100%] [avg time: 1.215 ms] [children: 99%] [unaccounted: 0.988%]
22:15:34: | Convert444toNV12 - [99%] [avg time: 1.203 ms]
22:15:34: encoder thread frame - [100%] [avg time: 2.122 ms]
22:15:34:
22:15:34:
22:15:34: Profiler CPU results:
22:15:34:
22:15:34: video thread frame - [cpu time: avg 2.763 ms, total 169370 ms] [avg calls per frame: 1]
22:15:34: | scene->Preprocess - [cpu time: avg 1.806 ms, total 110730 ms] [avg calls per frame: 1]
22:15:34: | GPU download and conversion - [cpu time: avg 0.078 ms, total 4820.44 ms] [avg calls per frame: 1]
22:15:34: | | flush - [cpu time: avg 0.05 ms, total 3088.83 ms] [avg calls per frame: 1]
22:15:34: | | CopyResource - [cpu time: avg 0.01 ms, total 655.204 ms] [avg calls per frame: 1]
22:15:34: | | conversion to 4:2:0 - [cpu time: avg 0.003 ms, total 234.001 ms] [avg calls per frame: 1]
22:15:34: Convert444Threads - [cpu time: avg 0.955 ms, total 117079 ms] [avg calls per frame: 2]
22:15:34: | Convert444toNV12 - [cpu time: avg 0.951 ms, total 116548 ms] [avg calls per frame: 2]
22:15:34: encoder thread frame - [cpu time: avg 1.359 ms, total 83741.3 ms] [avg calls per frame: 1]
22:15:34:
22:15:34: =====Stream End: 2014-02-11, 22:15:34=================================================
22:15:35: =====Stream Start: 2014-02-11, 22:15:35===============================================
22:15:35: Multithreaded optimizations: On
22:15:35: Base resolution: 1280x720
22:15:35: Output resolution: 1280x720
22:15:35: ------------------------------------------
22:15:35: Loading up D3D10 on AMD Radeon HD 7900 Series (Adapter 1)...
22:15:35: Audio Format: 44100hz
22:15:35: Playback device Default
22:15:35: Using desktop audio input: Speakers (2- Wireless Stereo Headset)
22:15:35: Using auxilary audio input: Microphone (2- Wireless Stereo Headset)
22:15:35: Audio Encoding: AAC
22:15:35: bitrate: 96
22:15:35: Using bitmap image
22:15:35: device: Logitech HD Webcam C525,
22:15:35: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
22:15:35: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
22:15:35: use buffering: false - 0, fourCC: 'I420'
22:15:35: audio device: Disable,
22:15:35: audio device id Disabled,
22:15:35:
22:15:36: Using directshow input
22:15:36: Using bitmap image
22:15:36: ------------------------------------------
22:15:36: device: AVerMedia HD Capture C985 Bus 2,
22:15:36: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
22:15:36: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
22:15:36: use buffering: false - 30000000, fourCC: 'YV12'
22:15:36:
22:15:36: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
22:15:36: Using Video Source
22:15:36: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:15:36: Scene buffering time set to 700
22:15:36: Video Encoding: x264
22:15:36: fps: 30
22:15:36: width: 1280, height: 720
22:15:36: preset: veryfast
22:15:36: profile: main
22:15:36: keyint: 250
22:15:36: CBR: yes
22:15:36: CFR: yes
22:15:36: max bitrate: 2500
22:15:36: buffer size: 2500
22:15:36: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
22:15:36: CLRHost:: Browser 7: Status message:
22:15:36: CLRHost:: Browser 7: Uncaught ReferenceError: $ is not defined @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248290
22:15:37: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 104482986
22:15:37:
22:15:37: Profiler result for the last frame:
22:15:37: ==============================================================
22:15:37: video thread frame - [time: 1181.48 ms (cpu time: 1076.41 ms)]
22:15:37: | scene->Preprocess - [time: 0.041 ms (cpu time: 0 ms)]
22:15:37: | GPU download and conversion - [time: 0.16 ms (cpu time: 0 ms)]
22:15:37: | | flush - [time: 0.136 ms (cpu time: 0 ms)]
22:15:37: | | CopyResource - [time: 0.008 ms (cpu time: 0 ms)]
22:15:37:
22:15:37:
22:15:37: video thread frame - [time: 18.905 ms (cpu time: 15.601 ms)]
22:15:37: | scene->Preprocess - [time: 13.952 ms (cpu time: 15.601 ms)]
22:15:37: | GPU download and conversion - [time: 0.326 ms (cpu time: 0 ms)]
22:15:37: | | flush - [time: 0.296 ms (cpu time: 0 ms)]
22:15:37: | | CopyResource - [time: 0.002 ms (cpu time: 0 ms)]
22:15:37: | | conversion to 4:2:0 - [time: 0.003 ms (cpu time: 0 ms)]
22:15:37:
22:15:37: Total frames encoded: 1, total frames duplicated: 0 (0.00%)
22:15:37: Total frames rendered: 5, number of late frames: 2 (40.00%) (it's okay for some frames to be late)
22:15:38: Number of times waited to send: 0, Waited for a total of 0 bytes
22:15:38: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
22:15:38: Number of bytes sent: 0
22:15:38:
22:15:38: Profiler time results:
22:15:38:
22:15:38: ==============================================================
22:15:38: video thread frame - [100%] [avg time: 251.347 ms] [children: 2.41%] [unaccounted: 97.6%]
22:15:38: | scene->Preprocess - [2.34%] [avg time: 5.892 ms]
22:15:38: | GPU download and conversion - [0.0684%] [avg time: 0.172 ms] [children: 0.0617%] [unaccounted: 0.00676%]
22:15:38: | | flush - [0.0577%] [avg time: 0.145 ms]
22:15:38: | | CopyResource - [0.00278%] [avg time: 0.007 ms]
22:15:38: | | conversion to 4:2:0 - [0.00119%] [avg time: 0.003 ms]
22:15:38: Convert444Threads - [100%] [avg time: 3.095 ms] [children: 99.6%] [unaccounted: 0.355%]
22:15:38: | Convert444toNV12 - [99.6%] [avg time: 3.084 ms]
22:15:38: encoder thread frame - [100%] [avg time: 0.03 ms]
22:15:38:
22:15:38:
22:15:38: Profiler CPU results:
22:15:38:
22:15:38: video thread frame - [cpu time: avg 221.521 ms, total 1107.61 ms] [avg calls per frame: 1]
22:15:38: | scene->Preprocess - [cpu time: avg 6.24 ms, total 31.201 ms] [avg calls per frame: 1]
22:15:38: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:15:38: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:15:38: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:15:38: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:15:38: Convert444Threads - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 2]
22:15:38: | Convert444toNV12 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 2]
22:15:38: encoder thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
22:15:38:
22:15:38: =====Stream End: 2014-02-11, 22:15:38=================================================
22:15:39: =====Stream Start: 2014-02-11, 22:15:39===============================================
22:15:39: Multithreaded optimizations: On
22:15:39: Base resolution: 1280x720
22:15:39: Output resolution: 1280x720
22:15:39: ------------------------------------------
22:15:39: Loading up D3D10 on AMD Radeon HD 7900 Series (Adapter 1)...
22:15:39: Audio Format: 44100hz
22:15:39: Playback device Default
22:15:39: Using desktop audio input: Speakers (2- Wireless Stereo Headset)
22:15:39: Using auxilary audio input: Microphone (2- Wireless Stereo Headset)
22:15:39: Audio Encoding: AAC
22:15:39: bitrate: 96
22:15:39: Using bitmap image
22:15:39: device: Logitech HD Webcam C525,
22:15:39: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
22:15:39: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
22:15:39: use buffering: false - 0, fourCC: 'I420'
22:15:39: audio device: Disable,
22:15:39: audio device id Disabled,
22:15:39:
22:15:39: Using directshow input
22:15:39: device: AVerMedia HD Capture C985 Bus 2,
22:15:39: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
22:15:39: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
22:15:39: use buffering: false - 30000000, fourCC: 'YV12'
22:15:39:
22:15:39: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
22:15:39: Using Video Source
22:15:39: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:15:39: CLRHost:: Browser 8: Status message:
22:15:40: Scene buffering time set to 700
22:15:40: ------------------------------------------
22:15:40: Video Encoding: x264
22:15:40: fps: 30
22:15:40: width: 1280, height: 720
22:15:40: preset: veryfast
22:15:40: profile: main
22:15:40: keyint: 250
22:15:40: CBR: yes
22:15:40: CFR: yes
22:15:40: max bitrate: 2500
22:15:40: buffer size: 2500
22:15:40: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
22:15:40: CLRHost:: Browser 8: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:15:41:
22:15:41: Profiler result for the last frame:
22:15:41: ==============================================================
22:15:41: video thread frame - [time: 32.284 ms (cpu time: 0 ms)]
22:15:41: | scene->Preprocess - [time: 6.291 ms (cpu time: 0 ms)]
22:15:41: | GPU download and conversion - [time: 2.061 ms (cpu time: 0 ms)]
22:15:41: | | flush - [time: 2.025 ms (cpu time: 0 ms)]
22:15:41: | | CopyResource - [time: 0.003 ms (cpu time: 0 ms)]
22:15:41: | | conversion to 4:2:0 - [time: 0.004 ms (cpu time: 0 ms)]
22:15:41: Convert444Threads - [time: 1.505 ms (cpu time: 0 ms)]
22:15:41: | Convert444toNV12 - [time: 1.497 ms (cpu time: 0 ms)]
22:15:41:
22:15:42: CLRHost:: Browser 8: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:15:42: Using RTMP service: Twitch / Justin.tv
22:15:42: Server selection: rtmp://live-iad.justin.tv/app
22:15:42: Interface: Realtek RTL8139/810x Family Fast Ethernet NIC (ethernet, 100 mbps)
22:15:43: Completed handshake with rtmp://live-iad.justin.tv/app in 475 ms.
22:15:43: CLRHost:: Browser 8: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:15:43: SO_SNDBUF was at 8192
22:15:43: SO_SNDBUF is now 65536
22:15:45: Audio timestamp for device 'AVerMedia HD Capture C985 Bus 2' was behind target timestamp by 90
22:15:45: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 34060 / 331776)
22:21:03: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:21:03: New Scene
22:21:04: Using text output
22:21:04: Using bitmap image
22:21:04: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:21:05: CLRHost:: Browser 9: Status message:
22:21:05: Using bitmap image
22:21:05: CLRHost:: Browser 9: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:21:05: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:21:05: Using Video Source
22:21:05: PERFORMANCE WARNING: Scene change took 1889 ms, maybe some sources should be global sources?
22:21:05: CLRHost:: Browser 9: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:21:07: CLRHost:: Browser 9: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:24:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:24:08: New Scene
22:24:09: Using bitmap image
22:24:09: ------------------------------------------
22:24:09: device: Logitech HD Webcam C525,
22:24:09: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
22:24:09: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
22:24:09: use buffering: false - 0, fourCC: 'I420'
22:24:09: audio device: Disable,
22:24:09: audio device id Disabled,
22:24:09:
22:24:09: Using directshow input
22:24:09: device: AVerMedia HD Capture C985 Bus 2,
22:24:09: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
22:24:09: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
22:24:09: use buffering: false - 30000000, fourCC: 'YV12'
22:24:09:
22:24:09: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
22:24:09: Using Video Source
22:24:09: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:24:09: PERFORMANCE WARNING: Scene change took 590 ms, maybe some sources should be global sources?
22:24:09: CLRHost:: Browser 10: Status message:
22:24:09: CLRHost:: Browser 10: Uncaught ReferenceError: $ is not defined @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248290
22:27:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:27:02: New Scene
22:27:03: Using text output
22:27:03: Using bitmap image
22:27:03: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:27:04: CLRHost:: Browser 11: Status message:
22:27:04: Using bitmap image
22:27:04: Using Video Source
22:27:04: PERFORMANCE WARNING: Scene change took 1792 ms, maybe some sources should be global sources?
22:27:04: CLRHost:: Browser 11: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:27:06: CLRHost:: Browser 11: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:27:07: CLRHost:: Browser 11: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:29:01: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 100
22:29:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:29:02: New Scene
22:29:02: Using bitmap image
22:29:02: ------------------------------------------
22:29:02: device: Logitech HD Webcam C525,
22:29:02: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
22:29:02: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
22:29:02: use buffering: false - 0, fourCC: 'I420'
22:29:02: audio device: Disable,
22:29:02: audio device id Disabled,
22:29:02:
22:29:02: Using directshow input
22:29:02: device: AVerMedia HD Capture C985 Bus 2,
22:29:02: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
22:29:02: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
22:29:02: use buffering: false - 30000000, fourCC: 'YV12'
22:29:02:
22:29:02: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
22:29:03: Using directshow input
22:29:03: Using bitmap image
22:29:03: Using Video Source
22:29:03: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
22:29:03: PERFORMANCE WARNING: Scene change took 605 ms, maybe some sources should be global sources?
22:29:03: CLRHost:: Browser 12: Status message:
22:29:03: CLRHost:: Browser 12: Grabbing offset: 0 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:29:03: CLRHost:: Browser 12: Grabbing offset: 100 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:29:05: CLRHost:: Browser 12: Grabbing offset: 200 @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248213
22:31:47: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 120
22:31:47: Audio timestamp for device 'AVerMedia HD Capture C985 Bus 2' was behind target timestamp by 80
22:39:19: RTMPPublisher::SocketLoop: Stalled for 1837 ms to write 328984 bytes (buffer: 0 / 331776), unstable connection?
23:07:26: RTMPPublisher::SocketLoop: Stalled for 1627 ms to write 331434 bytes (buffer: 0 / 331776), unstable connection?
23:07:28: RTMPPublisher::SocketLoop: Stalled for 2533 ms to write 328978 bytes (buffer: 0 / 331776), unstable connection?
23:07:31: RTMPPublisher::SocketLoop: Stalled for 2665 ms to write 330826 bytes (buffer: 0 / 331776), unstable connection?
23:09:05: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
23:41:16: RTMPPublisher::SocketLoop: Stalled for 2099 ms to write 330855 bytes (buffer: 0 / 331776), unstable connection?
23:41:23: RTMPPublisher::SocketLoop: Stalled for 4764 ms to write 331167 bytes (buffer: 0 / 331776), unstable connection?
23:48:06: RTMPPublisher::SocketLoop: Stalled for 1784 ms to write 328998 bytes (buffer: 0 / 331776), unstable connection?
23:56:13: RTMPPublisher::SocketLoop: Received FD_CLOSE, 49821 ms since last send (buffer: 328366 / 331776)
23:56:13: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
23:56:14: Total frames encoded: 180998, total frames duplicated: 7137 (3.94%)
23:56:14: Number of frames skipped due to encoder lag: 8 (0.00%)
23:56:14: Total frames rendered: 180559, number of late frames: 101 (0.06%) (it's okay for some frames to be late)
23:56:15: Average send payload: 7569 bytes, average send interval: 23 ms
23:56:15: Number of times waited to send: 34, Waited for a total of 123755 bytes
23:56:15: Number of b-frames dropped: 208 (0.11%), Number of p-frames dropped: 297 (0.16%), Total 505 (0.28%)
23:56:15: Number of bytes sent: 1940873653
23:56:15:
23:56:15: Profiler time results:
23:56:15:
23:56:15: ==============================================================
23:56:15: video thread frame - [100%] [avg time: 8.603 ms] [children: 46.8%] [unaccounted: 53.2%]
23:56:15: | scene->Preprocess - [29.6%] [avg time: 2.545 ms]
23:56:15: | GPU download and conversion - [17.2%] [avg time: 1.477 ms] [children: 16.5%] [unaccounted: 0.663%]
23:56:15: | | flush - [16.2%] [avg time: 1.394 ms]
23:56:15: | | CopyResource - [0.244%] [avg time: 0.021 ms]
23:56:15: | | conversion to 4:2:0 - [0.0581%] [avg time: 0.005 ms]
23:56:15: Convert444Threads - [100%] [avg time: 1.049 ms] [children: 99%] [unaccounted: 1.05%]
23:56:15: | Convert444toNV12 - [99%] [avg time: 1.038 ms]
23:56:15: encoder thread frame - [100%] [avg time: 2.13 ms]
23:56:15:
23:56:15:
23:56:15: Profiler CPU results:
23:56:15:
23:56:15: video thread frame - [cpu time: avg 3.101 ms, total 559981 ms] [avg calls per frame: 1]
23:56:15: | scene->Preprocess - [cpu time: avg 2.021 ms, total 365011 ms] [avg calls per frame: 1]
23:56:15: | GPU download and conversion - [cpu time: avg 0.115 ms, total 20904.1 ms] [avg calls per frame: 1]
23:56:15: | | flush - [cpu time: avg 0.081 ms, total 14757.7 ms] [avg calls per frame: 1]
23:56:15: | | CopyResource - [cpu time: avg 0.013 ms, total 2449.22 ms] [avg calls per frame: 1]
23:56:15: | | conversion to 4:2:0 - [cpu time: avg 0.005 ms, total 1029.61 ms] [avg calls per frame: 1]
23:56:15: Convert444Threads - [cpu time: avg 0.926 ms, total 334700 ms] [avg calls per frame: 2]
23:56:15: | Convert444toNV12 - [cpu time: avg 0.922 ms, total 333062 ms] [avg calls per frame: 2]
23:56:15: encoder thread frame - [cpu time: avg 1.402 ms, total 253798 ms] [avg calls per frame: 1]
23:56:15:
23:56:15: =====Stream End: 2014-02-11, 23:56:15=================================================
23:57:30: =====Stream Start: 2014-02-11, 23:57:30===============================================
23:57:30: Multithreaded optimizations: On
23:57:30: Base resolution: 1280x720
23:57:30: Output resolution: 1280x720
23:57:30: ------------------------------------------
23:57:30: Loading up D3D10 on AMD Radeon HD 7900 Series (Adapter 1)...
23:57:30: Audio Format: 44100hz
23:57:30: Playback device Default
23:57:30: Using desktop audio input: Speakers (2- Wireless Stereo Headset)
23:57:30: Using auxilary audio input: Microphone (2- Wireless Stereo Headset)
23:57:30: Audio Encoding: AAC
23:57:30: bitrate: 96
23:57:30: Using bitmap image
23:57:30: device: Logitech HD Webcam C525,
23:57:30: device id \\?\usb#vid_046d&pid_0826&mi_02#6&adae5f7&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
23:57:30: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
23:57:30: use buffering: false - 0, fourCC: 'I420'
23:57:30: audio device: Disable,
23:57:30: audio device id Disabled,
23:57:30:
23:57:30: Using directshow input
23:57:30: device: AVerMedia HD Capture C985 Bus 2,
23:57:30: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&28b85f88&0&00a9#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
23:57:30: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666
23:57:30: use buffering: false - 30000000, fourCC: 'YV12'
23:57:30:
23:57:30: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
23:57:31: Using directshow input
23:57:31: Using bitmap image
23:57:31: Using Video Source
23:57:31: CLRHost:: BrowserRenderHandler::OnPaint failed to create texture
23:57:31: Scene buffering time set to 700
23:57:31: ------------------------------------------
23:57:31: Video Encoding: x264
23:57:31: fps: 30
23:57:31: width: 1280, height: 720
23:57:31: preset: veryfast
23:57:31: profile: main
23:57:31: keyint: 250
23:57:31: CBR: yes
23:57:31: CFR: yes
23:57:31: max bitrate: 2500
23:57:31: buffer size: 2500
23:57:31: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
23:57:32:
23:57:32: Profiler result for the last frame:
23:57:32: ==============================================================
23:57:32: video thread frame - [time: 1168.11 ms (cpu time: 1060.81 ms)]
23:57:32: | scene->Preprocess - [time: 0.037 ms (cpu time: 0 ms)]
23:57:32: | GPU download and conversion - [time: 0.543 ms (cpu time: 0 ms)]
23:57:32: | | flush - [time: 0.52 ms (cpu time: 0 ms)]
23:57:32: | | CopyResource - [time: 0.007 ms (cpu time: 0 ms)]
23:57:32:
23:57:32:
23:57:32: video thread frame - [time: 20.835 ms (cpu time: 15.6 ms)]
23:57:32: | scene->Preprocess - [time: 7.332 ms (cpu time: 15.6 ms)]
23:57:32: | GPU download and conversion - [time: 1.721 ms (cpu time: 0 ms)]
23:57:32: | | flush - [time: 1.658 ms (cpu time: 0 ms)]
23:57:32: | | CopyResource - [time: 0.035 ms (cpu time: 0 ms)]
23:57:32: | | conversion to 4:2:0 - [time: 0.004 ms (cpu time: 0 ms)]
23:57:32: Convert444Threads - [time: 1.278 ms (cpu time: 0 ms)]
23:57:32: | Convert444toNV12 - [time: 1.268 ms (cpu time: 0 ms)]
23:57:32:
23:57:33: CLRHost:: Browser 13: Status message:
23:57:33: CLRHost:: Browser 13: Uncaught ReferenceError: $ is not defined @http://www.nightdev.com/hosted/follower-alert/?channel=wapeddell&type=custom-centered&alert=http%3A%2F%2Fi.imgur.com%2F0j8JSek.png&sound=248290
23:57:33: Using RTMP service: Twitch / Justin.tv
23:57:33: Server selection: rtmp://live-iad.justin.tv/app
23:57:34: Interface: Realtek RTL8139/810x Family Fast Ethernet NIC (ethernet, 100 mbps)
23:57:34: Completed handshake with rtmp://live-iad.justin.tv/app in 514 ms.
23:57:35: SO_SNDBUF was at 8192
23:57:35: SO_SNDBUF is now 65536
23:57:36: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 838 / 331776)
23:57:42: Audio timestamp for device 'AVerMedia HD Capture C985 Bus 2' was behind target timestamp by 10
23:57:47: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 90
23:57:48: Audio timestamp for device 'Microphone (2- Wireless Stereo Headset)' was behind target timestamp by 110
23:57:48: Audio timestamp for device 'AVerMedia HD Capture C985 Bus 2' was behind target timestamp by 110
23:58:01: RTMPPublisher::SocketLoop: Stalled for 4469 ms to write 329062 bytes (buffer: 0 / 331776), unstable connection?
00:09:05: RTMPPublisher::SocketLoop: Stalled for 1662 ms to write 329636 bytes (buffer: 0 / 331776), unstable connection?
00:09:08: RTMPPublisher::SocketLoop: Stalled for 3022 ms to write 329031 bytes (buffer: 0 / 331776), unstable connection?
00:09:11: RTMPPublisher::SocketLoop: Stalled for 1571 ms to write 256451 bytes (buffer: 0 / 331776), unstable connection?
00:10:53: RTMPPublisher::SocketLoop: Stalled for 3919 ms to write 330422 bytes (buffer: 0 / 331776), unstable connection?
00:17:17: RTMPPublisher::SocketLoop: Stalled for 2088 ms to write 330267 bytes (buffer: 0 / 331776), unstable connection?
00:34:49: RTMPPublisher::SocketLoop: Stalled for 2009 ms to write 331709 bytes (buffer: 0 / 331776), unstable connection?
00:40:06: RTMPPublisher::SocketLoop: Stalled for 1941 ms to write 330052 bytes (buffer: 0 / 331776), unstable connection?
00:44:01: Total frames encoded: 83662, total frames duplicated: 1882 (2.25%)
00:44:01: Number of frames skipped due to encoder lag: 38 (0.05%)
00:44:01: Total frames rendered: 83593, number of late frames: 12 (0.01%) (it's okay for some frames to be late)
00:44:02: RTMPPublisher::SocketLoop: Graceful loop exit
00:44:02: Average send payload: 8072 bytes, average send interval: 24 ms
00:44:02: Number of times waited to send: 25, Waited for a total of 87640 bytes
00:44:02: Number of b-frames dropped: 205 (0.25%), Number of p-frames dropped: 276 (0.33%), Total 481 (0.58%)
00:44:02: Number of bytes sent: 901229972
00:44:02:
00:44:02: Profiler time results:
00:44:02:
00:44:02: ==============================================================
00:44:02: video thread frame - [100%] [avg time: 7.628 ms] [children: 41.5%] [unaccounted: 58.5%]
00:44:02: | scene->Preprocess - [35.2%] [avg time: 2.688 ms]
00:44:02: | GPU download and conversion - [6.24%] [avg time: 0.476 ms] [children: 5.34%] [unaccounted: 0.905%]
00:44:02: | | flush - [5.05%] [avg time: 0.385 ms]
00:44:02: | | CopyResource - [0.236%] [avg time: 0.018 ms]
00:44:02: | | conversion to 4:2:0 - [0.0524%] [avg time: 0.004 ms]
00:44:02: Convert444Threads - [100%] [avg time: 1.249 ms] [children: 99%] [unaccounted: 1.04%]
00:44:02: | Convert444toNV12 - [99%] [avg time: 1.236 ms]
00:44:02: encoder thread frame - [100%] [avg time: 2.257 ms]
00:44:02:
00:44:02:
00:44:02: Profiler CPU results:
00:44:02:
00:44:02: video thread frame - [cpu time: avg 2.96 ms, total 247496 ms] [avg calls per frame: 1]
00:44:02: | scene->Preprocess - [cpu time: avg 2.063 ms, total 172475 ms] [avg calls per frame: 1]
00:44:02: | GPU download and conversion - [cpu time: avg 0.078 ms, total 6520.85 ms] [avg calls per frame: 1]
00:44:02: | | flush - [cpu time: avg 0.047 ms, total 3962.43 ms] [avg calls per frame: 1]
00:44:02: | | CopyResource - [cpu time: avg 0.013 ms, total 1107.61 ms] [avg calls per frame: 1]
00:44:02: | | conversion to 4:2:0 - [cpu time: avg 0.002 ms, total 234.002 ms] [avg calls per frame: 1]
00:44:02: Convert444Threads - [cpu time: avg 0.925 ms, total 154737 ms] [avg calls per frame: 2]
00:44:02: | Convert444toNV12 - [cpu time: avg 0.919 ms, total 153786 ms] [avg calls per frame: 2]
00:44:02: encoder thread frame - [cpu time: avg 1.461 ms, total 122211 ms] [avg calls per frame: 1]
00:44:02:
00:44:02: =====Stream End: 2014-02-12, 00:44:02=================================================
00:44:14: CLR host plugin instance deleted; removing dynamically loaded localization strings
00:44:14: Video Source Plugin instance deleted; removing dynamically loaded localization strings
