Question / Help Audio Low Pitched Only in Cinnamon
FireStarW
Hello, I am trying to find a solution to a very strange problem.
When recording with OBS while using the cinnamon DE, the audio is pitched lower, as if there is a sample rate problem similar to ones I found on this forum.
However, when switching to an LXDE session, the audio issue is gone.
In cinnamon I tried making the 'default-sample-rate == alternate-sample-rate' in pulseaudio but it did not affect it.
I'm not quite sure if this is an OBS issue or a DE issue but I'd love to be able to use cinnamon while using OBS
I've uploaded logs from when I was in Cinnamon and when I was in LXDE
Edit: to clarify, I'm running Linux Mint 17.3
  • 2016-04-06 18-09-02-LXDE.txt
  • 2016-04-06 17-35-18-cinnamon.txt
