Question / Help Audio Lag On Stream?
I did about a 45 minute stream of some 'Last Of Us' gameplay, and also saved the file to my PC. Upon watching the stream back on my PC i noticed that the audio was lagging behind. Heres the clip at the end to show how bad the lip sync is...
http://youtu.be/jT1mJ53ohAE?t=46m41s
Is there a way to sort out audio lag at all, or what is the reason behind the audio lag??. I have attached the log file for the streaming session.
  • 2013-08-12-2122-04.log
dodgepong
Administrator
Community Helper
Have you tried the latest test, version .09? Jim added some code that might fix it.
No i havent, i just downloaded .08 last week, but ill give it a go. What has changed from .08 that might help fix the audio lag?
