Audio input capture not working - Log file attached
mullen_az
Trying to figure out what would cause OBS to lose audio signal from Audio Input Capture. I currently use an Apogee Duet audio interface to capture audio. Everything starts off fine but I completely lose the audio signal in obs and in turn, twitch, about 3 times on average over the course of a 1-hour stream. When this happens OBS no longer shows signal on the level meter. To resolve i have to close OBS and re-open and then the audio signal comes back fine. I haven't been able to find much info on what the cause could be but im new so there's a good chance i could use some advice on settings and if they are correct. Hoping this is a simple fix. Log from last time it occurred attached.....
  • 2020-07-04 22-13-07.txt
