Question / Help Audio Hitching
FerretBomb
Over the last few casts, on reviewing my VODs I've noticed a subtle but definitely-present audio hitch... the sound stops for a split second, then picks up again. It seems to smooth out over time, but will come back almost at random throughout the cast.
I've also had a number of my viewers complain about 'chat lag' that turns out to be the entire video stream falling behind; I'd expect this to be a Twitch-side issue (as when they refresh the stream, the lag is eliminated... but it apparently grows at a rate of 2-20 seconds per 30 minutes of viewing, ending up with some viewers up to five minutes behind) but figured I'd mention in case it might be related.
Here's a link to the VODs/logs from last night's cast; the audio-hitch is especially noticeable during the intro music... it tends to sneak in between words during the actual cast, but you can hear it in the game audio subtly stuttering.
Apologies about the three-segmented results, but the first one was cut short due to a brief network drop and restart (note the mic NOT being picked up after the auto-reconnect until I muted and unmuted it in segment 2), and the second break was due to a hard unexplained system freeze which required a full reboot.
Segment 1-
VOD: http://www.twitch.tv/ferretbomb/b/421516504
Log:
23:51:54: Video Source Plugin strings not found, dynamically loading 38 strings
23:52:23: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
23:52:23: -------------------------------
23:52:23: CPU Name: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
23:52:23: CPU Speed: 2672MHz
23:52:23: Physical Memory:  49143MB Total, 37745MB Free
23:52:23: stepping id: 4, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
23:52:23: monitor 1: pos={-1920, 0}, size={1920, 1080}
23:52:23: monitor 2: pos={0, 0}, size={1920, 1080}
23:52:23: monitor 3: pos={1920, 0}, size={1920, 1080}
23:52:23: Windows Version: 6.1 Build 7601 S
23:52:23: Aero is Enabled
23:52:23: OBS Modules:
23:52:23: Base Address     Module
23:52:23: 000000003F3C0000 OBS.exe
23:52:23: 00000000F1830000 OBSApi.dll
23:52:23: 00000000F29D0000 DShowPlugin.dll
23:52:23: 00000000F2750000 GraphicsCapture.dll
23:52:23: 00000000F41F0000 NoiseGate.dll
23:52:23: 00000000FB0B0000 scenesw.dll
23:52:23: 00000000FB2B0000 VideoSourcePluginWrapper.dll
23:52:23: ------------------------------------------
23:52:23: Adapter 1
23:52:23:   Video Adapter: AMD Radeon HD 6800 Series
23:52:23:   Video Adapter Dedicated Video Memory: 1017868288
23:52:23:   Video Adapter Shared System Memory: 4021872640
23:52:23: =====Stream Start: 2013-06-24, 23:52:23===============================================
23:52:23:   Multithreaded optimizations: On
23:52:23:   Base resolution: 1920x1080
23:52:23:   Output resolution: 1280x720
23:52:23: Loading up D3D10...
23:52:24: Playback device Default
23:52:24: ------------------------------------------
23:52:24: Using desktop audio input: Speakers (SoundMAX Integrated Digital HD Audio)
23:52:24: Using auxilary audio input: Microphone (SoundMAX Integrated Digital HD Audio)
23:52:24: Using Mic QPC timestamps
23:52:24: Audio Encoding: AAC
23:52:24:     bitrate: 128
23:52:24: Using bitmap image
23:52:24:     device: Logitech HD Pro Webcam C920,
23:52:24:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&3361f4d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
23:52:24:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
23:52:24:     audio device: Disable,
23:52:24:     audio device id Disabled,
23:52:24:
23:52:24: Using directshow input
23:52:24: Using Window Capture
23:52:24: Video Encoding: x264
23:52:24:     fps: 60
23:52:24:     width: 1280, height: 720
23:52:24:     preset: veryfast
23:52:24:     CBR: no
23:52:24:     CFR: no
23:52:24:     max bitrate: 2500
23:52:24:     buffer size: 2500
23:52:24:     quality: 10
23:52:24: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
23:52:34: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:52:34:   New Scene
23:52:34: Using Window Capture
23:52:34: Using bitmap image
23:54:20: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:54:20:   New Scene
23:54:20: Using bitmap image
23:55:09: Total frames rendered: 10032, number of frames that lagged: 5 (0.05%) (it's okay for some frames to lag)
23:55:09: =====Stream End: 2013-06-24, 23:55:09=================================================
00:00:28: =====Stream Start: 2013-06-25, 00:00:28===============================================
00:00:28:   Multithreaded optimizations: On
00:00:28:   Base resolution: 1920x1080
00:00:28:   Output resolution: 1280x720
00:00:28: ------------------------------------------
00:00:28: Loading up D3D10...
00:00:29: Playback device Default
00:00:29: ------------------------------------------
00:00:29: Using desktop audio input: Speakers (SoundMAX Integrated Digital HD Audio)
00:00:29: Using auxilary audio input: Microphone (SoundMAX Integrated Digital HD Audio)
00:00:29: Using Mic QPC timestamps
00:00:29: Audio Encoding: AAC
00:00:29:     bitrate: 128
00:00:29: Using bitmap image
00:00:29: Video Encoding: x264
00:00:29:     fps: 60
00:00:29:     width: 1280, height: 720
00:00:29:     preset: veryfast
00:00:29:     CBR: no
00:00:29:     CFR: no
00:00:29:     max bitrate: 2500
00:00:29:     buffer size: 2500
00:00:29:     quality: 10
00:00:29: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
00:00:30: Using RTMP service: Twitch / Justin.tv
00:00:30:   Server selection: rtmp://live-dfw-backup.justin.tv/app
00:00:31: SO_SNDBUF was at 8192
00:00:31: SO_SNDBUF is now 65536
00:01:47: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:01:47:   New Scene
00:01:47: ------------------------------------------
00:01:47:     device: Logitech HD Pro Webcam C920,
00:01:47:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&3361f4d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
00:01:47:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
00:01:47:     audio device: Disable,
00:01:47:     audio device id Disabled,
00:01:47:
00:01:47: Using directshow input
00:01:48: Using Window Capture
00:01:48: Using bitmap image
00:05:32: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:05:32:   New Scene
00:05:32: Using bitmap image
00:05:32: Using Window Capture
00:05:37: Using Window Capture
00:43:29: RTMPPublisher::SocketLoop: Socket error, send() returned -1, GetLastError() 10053
00:43:29: Total frames rendered: 157344, number of frames that lagged: 111 (0.07%) (it's okay for some frames to lag)
00:43:30: okay, this is strange
00:43:30: librtmp error: WriteN, RTMP send error 10053 (79 bytes)
00:43:30: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
00:43:30: Number of times waited to send: 15, Waited for a total of 37693 bytes
00:43:30: Number of b-frames dropped: 738 (0.47%), Number of p-frames dropped: 797 (0.51%), Total 1535 (0.98%)
00:43:30: =====Stream End: 2013-06-25, 00:43:30=================================================
00:43:40: =====Stream Start: 2013-06-25, 00:43:40===============================================
00:43:40:   Multithreaded optimizations: On
00:43:40:   Base resolution: 1920x1080
00:43:40:   Output resolution: 1280x720
00:43:40: ------------------------------------------
00:43:40: Loading up D3D10...
00:43:41: Playback device Default
00:43:41: ------------------------------------------
00:43:41: Using desktop audio input: Speakers (SoundMAX Integrated Digital HD Audio)
00:43:41: Using auxilary audio input: Microphone (SoundMAX Integrated Digital HD Audio)
00:43:41: Using Mic QPC timestamps
00:43:41: Audio Encoding: AAC
00:43:41:     bitrate: 128
00:43:41: Using bitmap image
00:43:41:     device: Logitech HD Pro Webcam C920,
00:43:41:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&3361f4d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
00:43:41:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
00:43:41:     audio device: Disable,
00:43:41:     audio device id Disabled,
00:43:41:
00:43:41: Using directshow input
00:43:41: Using Window Capture
00:43:41: Video Encoding: x264
00:43:41:     fps: 60
00:43:41:     width: 1280, height: 720
00:43:41:     preset: veryfast
00:43:41:     CBR: no
00:43:41:     CFR: no
00:43:41:     max bitrate: 2500
00:43:41:     buffer size: 2500
00:43:41:     quality: 10
00:43:41: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
00:43:43: Using RTMP service: Twitch / Justin.tv
00:43:43:   Server selection: rtmp://live-dfw-backup.justin.tv/app
00:43:44: SO_SNDBUF was at 8192
00:43:44: SO_SNDBUF is now 65536
01:54:44: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:54:44:   New Scene
01:54:44: Using Window Capture
01:54:44: Using bitmap image
01:55:00: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:55:00:   New Scene
01:55:00: Using bitmap image
01:55:00: Using Window Capture
01:56:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:56:17:   New Scene
01:56:17: Using Window Capture
01:56:17: Using bitmap image
01:57:08: ------------------------------------------
01:57:08:     device: Logitech HD Pro Webcam C920,
01:57:08:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&3361f4d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
01:57:08:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
01:57:08:     audio device: Disable,
01:57:08:     audio device id Disabled,
01:57:08:
01:57:45: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:57:45:   New Scene
01:57:46: Using bitmap image
01:57:46: Using Window Capture
02:12:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
02:12:21:   New Scene
02:12:21: Using Video Source
02:12:21: Using bitmap image
02:12:30: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
02:12:30:   New Scene
02:12:30: Using bitmap image
02:12:30: Using Window Capture
02:26:29: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
02:26:29:   New Scene
02:26:29: Using Video Source
02:26:29: Using bitmap image
02:26:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
02:26:38:   New Scene
02:26:38: Using bitmap image
02:26:38: Using Window Capture
02:37:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
02:37:07:   New Scene
02:37:07: Using Video Source
02:37:07: Using bitmap image
02:37:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
02:37:16:   New Scene
02:37:16: Using bitmap image
02:37:16: Using Window Capture
02:46:48: Using Monitor Capture
(Please note that NONE of my scenes have a normally-active active Monitor Capture; I enabled it to demonstrate an on-screen chat method, and shortly afterward the entire system hung after switching to Notepad and maximizing it, with zSNES running in the background)
Segment 2-
VOD: http://www.twitch.tv/ferretbomb/b/421528339
Log:
03:00:10: Video Source Plugin strings not found, dynamically loading 38 strings
03:02:00: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
03:02:00: -------------------------------
03:02:00: CPU Name: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
03:02:00: CPU Speed: 2672MHz
03:02:00: Physical Memory:  49143MB Total, 43068MB Free
03:02:00: stepping id: 4, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
03:02:00: monitor 1: pos={-1920, 0}, size={1920, 1080}
03:02:00: monitor 2: pos={0, 0}, size={1920, 1080}
03:02:00: monitor 3: pos={1920, 0}, size={1920, 1080}
03:02:00: Windows Version: 6.1 Build 7601 S
03:02:00: Aero is Enabled
03:02:00: OBS Modules:
03:02:00: Base Address     Module
03:02:00: 000000003F810000 OBS.exe
03:02:00: 00000000E49F0000 OBSApi.dll
03:02:00: 00000000EAE90000 DShowPlugin.dll
03:02:00: 00000000EAAC0000 GraphicsCapture.dll
03:02:00: 00000000EDA50000 NoiseGate.dll
03:02:00: 00000000ED950000 scenesw.dll
03:02:00: 00000000EDA00000 VideoSourcePluginWrapper.dll
03:02:00: ------------------------------------------
03:02:00: Adapter 1
03:02:00:   Video Adapter: AMD Radeon HD 6800 Series
03:02:00:   Video Adapter Dedicated Video Memory: 1017868288
03:02:00:   Video Adapter Shared System Memory: 4021872640
03:02:00: =====Stream Start: 2013-06-25, 03:02:00===============================================
03:02:00:   Multithreaded optimizations: On
03:02:00:   Base resolution: 1920x1080
03:02:00:   Output resolution: 1280x720
03:02:01: Loading up D3D10...
03:02:05: Playback device Default
03:02:05: ------------------------------------------
03:02:05: Using desktop audio input: Speakers (SoundMAX Integrated Digital HD Audio)
03:02:05: Using auxilary audio input: Microphone (SoundMAX Integrated Digital HD Audio)
03:02:05: Using Mic QPC timestamps
03:02:05: Audio Encoding: AAC
03:02:05:     bitrate: 128
03:02:05: Using bitmap image
03:02:05: Video Encoding: x264
03:02:05:     fps: 60
03:02:05:     width: 1280, height: 720
03:02:05:     preset: veryfast
03:02:05:     CBR: no
03:02:05:     CFR: no
03:02:05:     max bitrate: 2500
03:02:05:     buffer size: 2500
03:02:05:     quality: 10
03:02:05: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
03:02:06: Using RTMP service: Twitch / Justin.tv
03:02:06:   Server selection: rtmp://live-dfw-backup.justin.tv/app
03:02:08: SO_SNDBUF was at 8192
03:02:08: SO_SNDBUF is now 65536
03:02:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
03:02:09:   New Scene
03:02:13: ------------------------------------------
03:02:13:     device: Logitech HD Pro Webcam C920,
03:02:13:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&3361f4d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
03:02:13:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
03:02:13:     audio device: Disable,
03:02:13:     audio device id Disabled,
03:02:13:
03:02:15: Using directshow input
03:02:15: Using Window Capture
03:02:15: Using bitmap image
03:03:57: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
03:03:57:   New Scene
03:03:57: Using bitmap image
03:03:57: Using Window Capture
03:04:35: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
03:04:35:   New Scene
03:04:35: Using Window Capture
03:04:35: Using bitmap image
03:08:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
03:08:07:   New Scene
03:08:07: Using bitmap image
03:08:07: Using Window Capture
03:08:08: Using bitmap image
03:08:08: Using Window Capture
03:08:29: Using graphics capture
03:08:30: SharedTexCapture hooked
03:09:27: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
03:09:27:   New Scene
03:09:28: Using bitmap image
03:09:28: Using graphics capture
03:09:47: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
03:09:47:   New Scene
03:09:47: Using bitmap image
03:09:47: Using Window Capture
03:09:47: Using graphics capture
03:09:47: SharedTexCapture hooked
04:02:06: Capture window 0x000801CE invalid or changing, terminating capture
04:04:44: Using Window Capture
04:42:58: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
04:42:58:   New Scene
04:42:58: Using Window Capture
04:42:58: Using bitmap image
04:45:22: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
04:45:22:   New Scene
04:45:22: Using bitmap image
04:48:31: Total frames rendered: 382999, number of frames that lagged: 1780 (0.46%) (it's okay for some frames to lag)
04:48:32: RTMPPublisher::SocketLoop: Aborting due to bStopping
04:48:32: Number of times waited to send: 0, Waited for a total of 0 bytes
04:48:32: Number of b-frames dropped: 32 (0.0084%), Number of p-frames dropped: 38 (0.0099%), Total 70 (0.018%)
04:48:32: =====Stream End: 2013-06-25, 04:48:32=================================================
06:38:39: =====Stream Start: 2013-06-25, 06:38:39===============================================
06:38:39:   Multithreaded optimizations: On
06:38:39:   Base resolution: 1920x1080
06:38:39:   Output resolution: 1280x720
06:38:39: ------------------------------------------
06:38:39: Loading up D3D10...
06:38:40: Playback device Default
06:38:40: ------------------------------------------
06:38:40: Using desktop audio input: Speakers (SoundMAX Integrated Digital HD Audio)
06:38:40: Using auxilary audio input: Microphone (SoundMAX Integrated Digital HD Audio)
06:38:40: Using Mic QPC timestamps
06:38:40: Audio Encoding: AAC
06:38:40:     bitrate: 128
06:38:40: Using bitmap image
06:38:40:     device: Logitech HD Pro Webcam C920,
06:38:40:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&3361f4d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
06:38:40:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
06:38:40:     audio device: Disable,
06:38:40:     audio device id Disabled,
06:38:40:
06:38:40: Using directshow input
06:38:40: Using Window Capture
06:38:40: Using graphics capture
06:38:40: Video Encoding: x264
06:38:40:     fps: 60
06:38:40:     width: 1280, height: 720
06:38:40:     preset: veryfast
06:38:40:     CBR: no
06:38:40:     CFR: no
06:38:40:     max bitrate: 2500
06:38:40:     buffer size: 2500
06:38:40:     quality: 10
06:38:41: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
06:38:45: Using Monitor Capture
06:39:57: Total frames rendered: 1738, number of frames that lagged: 991 (57.02%) (it's okay for some frames to lag)
06:39:58: =====Stream End: 2013-06-25, 06:39:58=================================================
06:40:00: =====Stream Start: 2013-06-25, 06:40:00===============================================
06:40:00:   Multithreaded optimizations: On
06:40:00:   Base resolution: 1920x1080
06:40:00:   Output resolution: 1280x720
06:40:00: ------------------------------------------
06:40:00: Loading up D3D10...
06:40:01: Playback device Default
06:40:01: ------------------------------------------
06:40:01: Using desktop audio input: Speakers (SoundMAX Integrated Digital HD Audio)
06:40:01: Using auxilary audio input: Microphone (SoundMAX Integrated Digital HD Audio)
06:40:01: Using Mic QPC timestamps
06:40:01: Audio Encoding: AAC
06:40:01:     bitrate: 128
06:40:01: Using bitmap image
06:40:01:     device: Logitech HD Pro Webcam C920,
06:40:01:     device id \\?\usb#vid_046d&pid_082d&mi_00#6&3361f4d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
06:40:01:     chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
06:40:01:     audio device: Disable,
06:40:01:     audio device id Disabled,
06:40:01:
06:40:01: Using directshow input
06:40:01: Using Window Capture
06:40:01: Video Encoding: x264
06:40:01:     fps: 60
06:40:01:     width: 1280, height: 720
06:40:01:     preset: veryfast
06:40:01:     CBR: no
06:40:01:     CFR: no
06:40:01:     max bitrate: 2500
06:40:01:     buffer size: 2500
06:40:01:     quality: 10
06:40:01: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
06:40:09: Total frames rendered: 475, number of frames that lagged: 6 (1.26%) (it's okay for some frames to lag)
06:40:10: =====Stream End: 2013-06-25, 06:40:10=================================================
06:40:20: Video Source Plugin instance deleted; removing dynamically loaded localization strings
06:40:20:
06:40:20: Profiler results:
06:40:20:
06:40:20: ==============================================================
06:40:20: frame - [100%] [avg time: 6.142 ms] [avg calls per frame: 1] [children: 88.2%] [unaccounted: 11.8%]
06:40:20: | scene->Preprocess - [53.9%] [avg time: 3.311 ms] [avg calls per frame: 1]
06:40:20: | video encoding and uploading - [34.3%] [avg time: 2.104 ms] [avg calls per frame: 1] [children: 33.8%] [unaccounted: 0.456%]
06:40:20: | | CopyResource - [0.261%] [avg time: 0.016 ms] [avg calls per frame: 0]
06:40:20: | | conversion to 4:2:0 - [0.0651%] [avg time: 0.004 ms] [avg calls per frame: 0]
06:40:20: | | call to encoder - [33.1%] [avg time: 2.033 ms] [avg calls per frame: 0]
06:40:20: | | sending stuff out - [0.374%] [avg time: 0.023 ms] [avg calls per frame: 0]
06:40:20:
Segment 3- (Unsure if the above log is for this, this is the post-crash one)
VOD: http://www.twitch.tv/ferretbomb/b/421561081
Just as a note, also not sure what's causing the lagged frames; I keep an eye on my CPU utilization, and it stays between 60-70% at all times. May be from when I had the monitor capture on (briefly), which is all I can figure.
Main annoyance is that audio hitching, and secondarily maybe the stream fall-behind for viewers (though I'm pretty sure that's purely on Twitch's end).
