Bug Report Audio Desync Issue in .522b
dwyrin
I use OBS a lot for Streaming and recording video from a variety of sources; Software Capture, Video Capture Device, Game Capture. Not all together, mind you. However a recent update to .522b has me desync'ing audio everywhere, both in game and via microphone.
Help?
I should also mention this happens regardless of if I'm Streaming or Recording to file
00:52:34: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
00:52:34: -------------------------------
00:52:34: CPU Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
00:52:34: CPU Speed: 3392MHz
00:52:34: Physical Memory:  4095MB Total, 4095MB Free
00:52:34: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
00:52:34: monitor 1: pos={1920, 30}, size={1680, 1050}
00:52:34: monitor 2: pos={0, 0}, size={1920, 1080}
00:52:34: Windows Version: 6.1 Build 7601 S
00:52:34: Aero is Enabled
00:52:34: OBS Modules:
00:52:34: Base Address     Module
00:52:34: 012F0000         OBS.exe
00:52:34: 6BCA0000         OBSApi.dll
00:52:34: 6EED0000         DShowPlugin.dll
00:52:34: 6EB00000         GraphicsCapture.dll
00:52:34: 6E270000         NoiseGate.dll
00:52:34: ------------------------------------------
00:52:34: Adapter 1
00:52:34:   Video Adapter: AMD Radeon HD 6700 Series
00:52:34:   Video Adapter Dedicated Video Memory: 1062043648
00:52:34:   Video Adapter Shared System Memory: 3999737856
00:52:34: =====Stream Start: 2013-05-12, 00:52:34===============================================
00:52:34:   Multithreaded optimizations: On
00:52:34:   Base resolution: 1920x1080
00:52:34:   Output resolution: 1280x720
00:52:34: Loading up D3D10...
00:52:34: Playback device Default
00:52:34: Using desktop audio input: Speakers (Realtek High Definition Audio)
00:52:34: Using auxilary audio input: Microphone (Blue Snowball)
00:52:34: Audio Encoding: AAC
00:52:34:     bitrate: 128
00:52:34: Using text output
00:52:34: Video Encoding: x264
00:52:34:     fps: 30
00:52:34:     width: 1280, height: 720
00:52:34:     preset: veryfast
00:52:34:     CBR: yes
00:52:34:     CFR: no
00:52:34:     max bitrate: 2000
00:52:37: Total frames rendered: 77, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
00:52:37: =====Stream End: 2013-05-12, 00:52:37=================================================
00:52:41: =====Stream Start: 2013-05-12, 00:52:41===============================================
00:52:41:   Multithreaded optimizations: On
00:52:41:   Base resolution: 1920x1080
00:52:41:   Output resolution: 1280x720
00:52:41: ------------------------------------------
00:52:41: Loading up D3D10...
00:52:42: Playback device Default
00:52:42: ------------------------------------------
00:52:42: Using desktop audio input: Speakers (Realtek High Definition Audio)
00:52:42: Using auxilary audio input: Microphone (Blue Snowball)
00:52:42: Audio Encoding: AAC
00:52:42:     bitrate: 128
00:52:42: Using text output
00:52:42: Video Encoding: x264
00:52:42:     fps: 30
00:52:42:     width: 1280, height: 720
00:52:42:     preset: veryfast
00:52:42:     CBR: yes
00:52:42:     CFR: no
00:52:42:     max bitrate: 2000
00:52:43: Using RTMP service: Twitch / Justin.tv
00:52:43:   Server selection: rtmp://live-dfw.justin.tv/app
00:52:45: SO_SNDBUF was at 8192
00:52:45: SO_SNDBUF is now 65536
00:54:36: Using graphics capture
00:54:36: SharedTexCapture hooked
00:54:47: Using graphics capture
00:54:47: SharedTexCapture hooked
02:11:03: Capture window 0x00690CF6 invalid or changing, terminating capture
02:11:19: Using text output
02:12:36: Total frames rendered: 143830, number of frames that lagged: 19 (0.01%) (it's okay for some frames to lag)
02:12:36: RTMPPublisher::SocketLoop: Aborting due to bStopping
02:12:36: Number of times waited to send: 0, Waited for a total of 0 bytes
02:12:36: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
02:12:36: =====Stream End: 2013-05-12, 02:12:36=================================================
13:23:02:
13:23:02: Profiler results:
13:23:02:
13:23:02: ==============================================================
13:23:02: frame - [100%] [avg time: 2.354 ms] [avg calls per frame: 1] [children: 77.2%] [unaccounted: 22.8%]
13:23:02: | scene->Preprocess - [0.0425%] [avg time: 0.001 ms] [avg calls per frame: 1]
13:23:02: | video encoding and uploading - [77.2%] [avg time: 1.817 ms] [avg calls per frame: 1] [children: 75.7%] [unaccounted: 1.49%]
13:23:02: | | CopyResource - [0.382%] [avg time: 0.009 ms] [avg calls per frame: 0]
13:23:02: | | conversion to 4:2:0 - [0.68%] [avg time: 0.016 ms] [avg calls per frame: 0]
13:23:02: | | call to encoder - [73.1%] [avg time: 1.72 ms] [avg calls per frame: 0]
13:23:02: | | sending stuff out - [1.57%] [avg time: 0.037 ms] [avg calls per frame: 0]
13:23:02:
Shade
Hi, I have the same exact issue since 0.522b.
21:51:29: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
21:51:29: -------------------------------
21:51:29: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
21:51:29: CPU Speed: 3292MHz
21:51:29: Physical Memory:  4095MB Total, 4095MB Free
21:51:29: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
21:51:29: monitor 1: pos={1680, 216}, size={1366, 768}
21:51:29: monitor 2: pos={0, 0}, size={1680, 1050}
21:51:29: Windows Version: 6.1 Build 7601 S
21:51:29: Aero is Disabled
21:51:29: OBS Modules:
21:51:29: Base Address     Module
21:51:29: 01130000         OBS.exe
21:51:29: 6E6A0000         OBSApi.dll
21:51:29: 73460000         DShowPlugin.dll
21:51:29: 72D30000         GraphicsCapture.dll
21:51:29: 70640000         NoiseGate.dll
21:51:29: 74560000         SC2SceneSwitcher.dll
21:51:29: ------------------------------------------
21:51:29: Adapter 1
21:51:29:   Video Adapter: NVIDIA GeForce GTX 460
21:51:29:   Video Adapter Dedicated Video Memory: 1025966080
21:51:29:   Video Adapter Shared System Memory: 3220779008
21:51:29: =====Stream Start: 2013-05-13, 21:51:29===============================================
21:51:29:   Multithreaded optimizations: On
21:51:29:   Base resolution: 1680x1050
21:51:29:   Output resolution: 1120x700
21:51:29: Loading up D3D10...
21:51:29: Playback device {0.0.0.00000000}.{2cadf44a-82a8-4c50-b2a3-15de86d1fc2d}
21:51:29: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:51:29: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:51:29: Audio Encoding: AAC
21:51:29:     bitrate: 128
21:51:29: Using Slide Show
21:51:29: Using text output
21:51:29: Using bitmap image
21:51:29: Using Monitor Capture
21:51:29: Video Encoding: x264
21:51:29:     fps: 25
21:51:29:     width: 1120, height: 700
21:51:29:     preset: veryfast
21:51:29:     CBR: no
21:51:29:     CFR: no
21:51:29:     max bitrate: 650
21:51:29:     buffer size: 650
21:51:29:     quality: 8
21:51:31: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:51:31:   New Scene
21:51:31: Using bitmap image
21:51:31: Using text output
21:51:31: Using Monitor Capture
21:52:58: Total frames rendered: 2213, number of frames that lagged: 4 (0.18%) (it's okay for some frames to lag)
21:52:58: =====Stream End: 2013-05-13, 21:52:58=================================================
21:53:00: Using automatic low latency mode
21:53:00: =====Stream Start: 2013-05-13, 21:53:00===============================================
21:53:00:   Multithreaded optimizations: On
21:53:00:   Base resolution: 1680x1050
21:53:00:   Output resolution: 1120x700
21:53:00: ------------------------------------------
21:53:00: Loading up D3D10...
21:53:00: Playback device {0.0.0.00000000}.{2cadf44a-82a8-4c50-b2a3-15de86d1fc2d}
21:53:00: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:53:00: Using auxilary audio input: Microphone (Realtek High Definition Audio)
21:53:00: Audio Encoding: AAC
21:53:00:     bitrate: 128
21:53:00: Using bitmap image
21:53:00: Using text output
21:53:00: Using Monitor Capture
21:53:00: Video Encoding: x264
21:53:00:     fps: 25
21:53:00:     width: 1120, height: 700
21:53:00:     preset: veryfast
21:53:00:     CBR: no
21:53:00:     CFR: no
21:53:00:     max bitrate: 650
21:53:00:     buffer size: 650
21:53:00:     quality: 8
21:53:02: Using RTMP service: Twitch / Justin.tv
21:53:02:   Server selection: rtmp://live-ams.justin.tv/app
21:53:03: SO_SNDBUF was at 8192
21:53:03: SO_SNDBUF is now 65536
21:55:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:55:54:   New Scene
21:55:54: Using Slide Show
21:55:54: Using text output
21:55:54: Using bitmap image
21:55:54: Using Monitor Capture
21:56:10: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:56:10:   New Scene
21:56:10: Using bitmap image
21:56:10: Using text output
21:56:10: Using Monitor Capture
21:57:37: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:57:37:   New Scene
21:57:37: Using Slide Show
21:57:37: Using text output
21:57:37: Using bitmap image
21:57:37: Using Monitor Capture
21:58:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:58:04:   New Scene
21:58:04: Using bitmap image
21:58:04: Using text output
21:58:04: Using Monitor Capture
21:58:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:58:05:   New Scene
21:58:05: Using Slide Show
21:58:05: Using text output
21:58:05: Using bitmap image
21:58:05: Using Monitor Capture
21:58:48: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
21:58:58: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
21:59:11: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 524288
22:21:18: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:21:18:   New Scene
22:21:18: Using bitmap image
22:21:18: Using text output
22:21:18: Using Monitor Capture
22:24:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:24:07:   New Scene
22:24:07: Using Slide Show
22:24:07: Using text output
22:24:07: Using bitmap image
22:24:07: Using Monitor Capture
22:24:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:24:56:   New Scene
22:24:56: Using bitmap image
22:24:56: Using text output
22:24:56: Using Monitor Capture
22:25:00: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:25:00:   New Scene
22:25:00: Using Slide Show
22:25:00: Using text output
22:25:00: Using bitmap image
22:25:01: Using Monitor Capture
22:26:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:26:17:   New Scene
22:26:17: Using bitmap image
22:26:17: Using text output
22:26:17: Using Monitor Capture
22:26:20: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:26:20:   New Scene
22:26:20: Using Slide Show
22:26:20: Using text output
22:26:20: Using bitmap image
22:26:20: Using Monitor Capture
22:32:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:32:56:   New Scene
22:32:56: Using bitmap image
22:32:56: Using text output
22:32:56: Using Monitor Capture
22:35:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:35:40:   New Scene
22:35:40: Using Slide Show
22:35:40: Using text output
22:35:40: Using bitmap image
22:35:40: Using Monitor Capture
22:35:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:35:53:   New Scene
22:35:53: Using bitmap image
22:35:53: Using text output
22:35:53: Using Monitor Capture
22:35:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:35:56:   New Scene
22:35:56: Using Slide Show
22:35:56: Using text output
22:35:56: Using bitmap image
22:35:56: Using Monitor Capture
22:36:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:36:01:   New Scene
22:36:01: Using bitmap image
22:36:01: Using text output
22:36:01: Using Monitor Capture
22:36:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:36:07:   New Scene
22:36:07: Using Slide Show
22:36:07: Using text output
22:36:07: Using bitmap image
22:36:07: Using Monitor Capture
22:36:33: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:36:33:   New Scene
22:36:33: Using bitmap image
22:36:33: Using text output
22:36:34: Using bitmap image
22:36:34: Using Monitor Capture
22:36:35: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:36:35:   New Scene
22:36:35: Using Slide Show
22:36:35: Using text output
22:36:35: Using bitmap image
22:36:35: Using Monitor Capture
22:36:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:36:53:   New Scene
22:36:53: Using bitmap image
22:36:53: Using text output
22:36:53: Using Monitor Capture
22:36:55: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:36:55:   New Scene
22:36:55: Using Slide Show
22:36:55: Using text output
22:36:55: Using bitmap image
22:36:55: Using Monitor Capture
22:37:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:37:17:   New Scene
22:37:17: Using bitmap image
22:37:17: Using text output
22:37:17: Using Monitor Capture
22:37:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:37:21:   New Scene
22:37:21: Using Slide Show
22:37:21: Using text output
22:37:21: Using bitmap image
22:37:21: Using Monitor Capture
22:37:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:37:26:   New Scene
22:37:26: Using bitmap image
22:37:26: Using text output
22:37:26: Using Monitor Capture
22:37:27: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:37:27:   New Scene
22:37:27: Using Slide Show
22:37:27: Using text output
22:37:27: Using bitmap image
22:37:27: Using Monitor Capture
22:37:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:37:48:   New Scene
22:37:48: Using bitmap image
22:37:48: Using text output
22:37:48: Using Monitor Capture
22:37:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:37:56:   New Scene
22:37:56: Using Slide Show
22:37:56: Using text output
22:37:56: Using bitmap image
22:37:56: Using Monitor Capture
22:40:32: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:40:32:   New Scene
22:40:32: Using bitmap image
22:40:32: Using text output
22:40:32: Using Monitor Capture
22:42:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:42:38:   New Scene
22:42:38: Using Slide Show
22:42:38: Using text output
22:42:38: Using bitmap image
22:42:38: Using Monitor Capture
22:42:39: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:42:39:   New Scene
22:42:39: Using bitmap image
22:42:39: Using text output
22:42:39: Using Monitor Capture
22:42:44: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:42:44:   New Scene
22:42:44: Using Slide Show
22:42:44: Using text output
22:42:44: Using bitmap image
22:42:44: Using Monitor Capture
22:42:47: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:42:47:   New Scene
22:42:47: Using bitmap image
22:42:47: Using text output
22:42:47: Using Monitor Capture
22:42:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:42:51:   New Scene
22:42:51: Using Slide Show
22:42:51: Using text output
22:42:51: Using bitmap image
22:42:51: Using Monitor Capture
22:43:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:43:04:   New Scene
22:43:04: Using bitmap image
22:43:04: Using text output
22:43:04: Using Monitor Capture
22:43:05: Using Monitor Capture
22:43:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:43:09:   New Scene
22:43:09: Using Slide Show
22:43:09: Using text output
22:43:09: Using bitmap image
22:43:09: Using Monitor Capture
22:44:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:44:04:   New Scene
22:44:04: Using bitmap image
22:44:04: Using text output
22:44:04: Using Monitor Capture
22:44:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:44:07:   New Scene
22:44:07: Using Slide Show
22:44:07: Using text output
22:44:07: Using bitmap image
22:44:07: Using Monitor Capture
22:44:25: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:44:25:   New Scene
22:44:25: Using bitmap image
22:44:25: Using text output
22:44:25: Using Monitor Capture
22:44:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:44:26:   New Scene
22:44:26: Using Slide Show
22:44:26: Using text output
22:44:26: Using bitmap image
22:44:26: Using Monitor Capture
22:58:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
22:58:51:   New Scene
22:58:51: Using bitmap image
22:58:51: Using text output
22:58:51: Using Monitor Capture
23:01:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:01:17:   New Scene
23:01:17: Using Slide Show
23:01:17: Using text output
23:01:17: Using bitmap image
23:01:17: Using Monitor Capture
23:02:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:02:02:   New Scene
23:02:02: Using bitmap image
23:02:02: Using text output
23:02:02: Using Monitor Capture
23:02:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:02:06:   New Scene
23:02:06: Using Slide Show
23:02:06: Using text output
23:02:06: Using bitmap image
23:02:06: Using Monitor Capture
23:02:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:02:08:   New Scene
23:02:08: Using bitmap image
23:02:08: Using text output
23:02:08: Using Monitor Capture
23:02:12: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:02:12:   New Scene
23:02:12: Using Slide Show
23:02:12: Using text output
23:02:12: Using bitmap image
23:02:12: Using Monitor Capture
23:17:23: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:17:23:   New Scene
23:17:23: Using bitmap image
23:17:23: Using text output
23:17:23: Using Monitor Capture
23:21:24: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:21:24:   New Scene
23:21:24: Using Slide Show
23:21:24: Using text output
23:21:24: Using bitmap image
23:21:24: Using Monitor Capture
23:31:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
23:31:41:   New Scene
23:31:41: Using bitmap image
23:31:41: Using text output
23:31:41: Using Monitor Capture
23:32:40: Total frames rendered: 149461, number of frames that lagged: 23 (0.02%) (it's okay for some frames to lag)
23:32:40: RTMPPublisher::SocketLoop: Aborting due to bStopping
23:32:40: Number of times waited to send: 2919, Waited for a total of 8028197 bytes
23:32:40: Number of b-frames dropped: 38 (0.025%), Number of p-frames dropped: 0 (0%), Total 38 (0.025%)
23:32:40: =====Stream End: 2013-05-13, 23:32:40=================================================
23:35:15:
23:35:15: Profiler results:
23:35:15:
23:35:15: ==============================================================
23:35:15: frame - [100%] [avg time: 8.214 ms] [avg calls per frame: 1] [children: 96.5%] [unaccounted: 3.46%]
23:35:15: | scene->Preprocess - [81.7%] [avg time: 6.708 ms] [avg calls per frame: 1]
23:35:15: | video encoding and uploading - [14.9%] [avg time: 1.222 ms] [avg calls per frame: 1] [children: 14.1%] [unaccounted: 0.779%]
23:35:15: | | CopyResource - [0.17%] [avg time: 0.014 ms] [avg calls per frame: 0]
23:35:15: | | conversion to 4:2:0 - [0.694%] [avg time: 0.057 ms] [avg calls per frame: 0]
23:35:15: | | call to encoder - [12.9%] [avg time: 1.061 ms] [avg calls per frame: 0]
23:35:15: | | sending stuff out - [0.317%] [avg time: 0.026 ms] [avg calls per frame: 0]
23:35:15:
dwyrin
Nope. Not resolved. Uploaded a Video as well of said problem as well
http://www.youtube.com/watch?v=DU5m0KQf ... e=youtu.be
18:24:42: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
18:24:42: -------------------------------
18:24:42: CPU Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
18:24:42: CPU Speed: 3392MHz
18:24:42: Physical Memory:  4095MB Total, 3297MB Free
18:24:42: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
18:24:42: monitor 1: pos={1920, 30}, size={1680, 1050}
18:24:42: monitor 2: pos={0, 0}, size={1920, 1080}
18:24:42: Windows Version: 6.1 Build 7601 S
18:24:42: Aero is Enabled
18:24:42: OBS Modules:
18:24:42: Base Address     Module
18:24:42: 00F30000         OBS.exe
18:24:42: 6E6F0000         OBSApi.dll
18:24:42: 733C0000         DShowPlugin.dll
18:24:42: 70FB0000         GraphicsCapture.dll
18:24:42: 6F060000         NoiseGate.dll
18:24:42: ------------------------------------------
18:24:42: Adapter 1
18:24:42:   Video Adapter: AMD Radeon HD 6700 Series
18:24:42:   Video Adapter Dedicated Video Memory: 1062043648
18:24:42:   Video Adapter Shared System Memory: 3999737856
18:24:42: =====Stream Start: 2013-05-13, 18:24:42===============================================
18:24:42:   Multithreaded optimizations: On
18:24:42:   Base resolution: 1920x1080
18:24:42:   Output resolution: 1920x1080
18:24:42: Loading up D3D10...
18:24:42: Playback device Default
18:24:42: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:24:42: Using auxilary audio input: Microphone (Blue Snowball)
18:24:42: Audio Encoding: AAC
18:24:42:     bitrate: 192
18:24:42: Using graphics capture
18:24:42: Video Encoding: x264
18:24:42:     fps: 30
18:24:42:     width: 1920, height: 1080
18:24:42:     preset: veryfast
18:24:42:     CBR: yes
18:24:42:     CFR: yes
18:24:42:     max bitrate: 2000
18:24:42: SharedTexCapture hooked
18:25:08: Total frames rendered: 774, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
18:25:08: Total duplicated frames: 0 (0.00%)
18:25:08: =====Stream End: 2013-05-13, 18:25:08=================================================
18:40:18: =====Stream Start: 2013-05-13, 18:40:18===============================================
18:40:18:   Multithreaded optimizations: On
18:40:18:   Base resolution: 1920x1080
18:40:18:   Output resolution: 1920x1080
18:40:18: ------------------------------------------
18:40:18: Loading up D3D10...
18:40:18: Playback device Default
18:40:18: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:40:18: Using auxilary audio input: Microphone (Blue Snowball)
18:40:18: Audio Encoding: AAC
18:40:18:     bitrate: 192
18:40:18: Using graphics capture
18:40:18: Video Encoding: x264
18:40:18:     fps: 30
18:40:18:     width: 1920, height: 1080
18:40:18:     preset: veryfast
18:40:18:     CBR: yes
18:40:18:     CFR: yes
18:40:18:     max bitrate: 2000
18:40:18: SharedTexCapture hooked
18:40:55: Total frames rendered: 1110, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
18:40:55: Total duplicated frames: 0 (0.00%)
18:40:55: =====Stream End: 2013-05-13, 18:40:55=================================================
18:41:45:
18:41:45: Profiler results:
18:41:45:
18:41:45: ==============================================================
18:41:45: frame - [100%] [avg time: 3.589 ms] [avg calls per frame: 1] [children: 89.5%] [unaccounted: 10.5%]
18:41:45: | scene->Preprocess - [0.0279%] [avg time: 0.001 ms] [avg calls per frame: 1]
18:41:45: | video encoding and uploading - [89.4%] [avg time: 3.21 ms] [avg calls per frame: 1] [children: 89%] [unaccounted: 0.418%]
18:41:45: | | CopyResource - [0.195%] [avg time: 0.007 ms] [avg calls per frame: 0]
18:41:45: | | conversion to 4:2:0 - [0.195%] [avg time: 0.007 ms] [avg calls per frame: 0]
18:41:45: | | call to encoder - [88.3%] [avg time: 3.17 ms] [avg calls per frame: 0]
18:41:45: | | sending stuff out - [0.306%] [avg time: 0.011 ms] [avg calls per frame: 0]
18:41:45:
Shade
Just like Dwyrin, the CFR enabling didn't work out.. :(
01:28:43: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
01:28:43: -------------------------------
01:28:43: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
01:28:43: CPU Speed: 3292MHz
01:28:43: Physical Memory:  4095MB Total, 4019MB Free
01:28:43: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
01:28:43: monitor 1: pos={1680, 216}, size={1366, 768}
01:28:43: monitor 2: pos={0, 0}, size={1680, 1050}
01:28:43: Windows Version: 6.1 Build 7601 S
01:28:43: Aero is Disabled
01:28:43: OBS Modules:
01:28:43: Base Address     Module
01:28:43: 00CD0000         OBS.exe
01:28:43: 6E5A0000         OBSApi.dll
01:28:43: 72D20000         DShowPlugin.dll
01:28:43: 74B30000         GraphicsCapture.dll
01:28:43: 73460000         NoiseGate.dll
01:28:43: 74B20000         SC2SceneSwitcher.dll
01:28:43: ------------------------------------------
01:28:43: Adapter 1
01:28:43:   Video Adapter: NVIDIA GeForce GTX 460
01:28:43:   Video Adapter Dedicated Video Memory: 1025966080
01:28:43:   Video Adapter Shared System Memory: 3220779008
01:28:43: =====Stream Start: 2013-05-14, 01:28:43===============================================
01:28:43:   Multithreaded optimizations: On
01:28:43:   Base resolution: 1680x1050
01:28:43:   Output resolution: 1120x700
01:28:43: Loading up D3D10...
01:28:43: Playback device {0.0.0.00000000}.{2cadf44a-82a8-4c50-b2a3-15de86d1fc2d}
01:28:43: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:28:43: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:28:43: Audio Encoding: AAC
01:28:43:     bitrate: 128
01:28:43: Using Slide Show
01:28:43: Using text output
01:28:43: Using bitmap image
01:28:43: Using Monitor Capture
01:28:43: Video Encoding: x264
01:28:43:     fps: 25
01:28:43:     width: 1120, height: 700
01:28:43:     preset: veryfast
01:28:43:     CBR: no
01:28:43:     CFR: yes
01:28:43:     max bitrate: 650
01:28:43:     buffer size: 650
01:28:43:     quality: 8
01:28:45: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:28:45:   New Scene
01:28:45: Using bitmap image
01:28:45: Using text output
01:28:45: Using Monitor Capture
01:28:47: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:28:47:   New Scene
01:28:47: Using bitmap image
01:28:47: Using text output
01:28:47: Using Monitor Capture
01:28:56: Total frames rendered: 330, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:28:56: Total duplicated frames: 0 (0.00%)
01:28:56: =====Stream End: 2013-05-14, 01:28:56=================================================
01:28:59: Using automatic low latency mode
01:28:59: =====Stream Start: 2013-05-14, 01:28:59===============================================
01:28:59:   Multithreaded optimizations: On
01:28:59:   Base resolution: 1680x1050
01:28:59:   Output resolution: 1120x700
01:28:59: ------------------------------------------
01:28:59: Loading up D3D10...
01:28:59: Playback device {0.0.0.00000000}.{2cadf44a-82a8-4c50-b2a3-15de86d1fc2d}
01:28:59: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:28:59: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:28:59: Audio Encoding: AAC
01:28:59:     bitrate: 128
01:28:59: Using bitmap image
01:28:59: Using text output
01:28:59: Using Monitor Capture
01:28:59: Video Encoding: x264
01:28:59:     fps: 25
01:28:59:     width: 1120, height: 700
01:28:59:     preset: veryfast
01:28:59:     CBR: no
01:28:59:     CFR: yes
01:28:59:     max bitrate: 650
01:28:59:     buffer size: 650
01:28:59:     quality: 8
01:29:01: Using RTMP service: Twitch / Justin.tv
01:29:01:   Server selection: rtmp://live-ams.justin.tv/app
01:29:03: SO_SNDBUF was at 8192
01:29:03: SO_SNDBUF is now 65536
01:29:35: Total frames rendered: 896, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:29:35: Total duplicated frames: 0 (0.00%)
01:29:35: RTMPPublisher::SocketLoop: Aborting due to bStopping
01:29:35: Number of times waited to send: 0, Waited for a total of 0 bytes
01:29:35: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
01:29:35: =====Stream End: 2013-05-14, 01:29:35=================================================
01:31:00: Using automatic low latency mode
01:31:00: =====Stream Start: 2013-05-14, 01:31:00===============================================
01:31:00:   Multithreaded optimizations: On
01:31:00:   Base resolution: 1680x1050
01:31:00:   Output resolution: 1120x700
01:31:00: ------------------------------------------
01:31:00: Loading up D3D10...
01:31:00: Playback device {0.0.0.00000000}.{2cadf44a-82a8-4c50-b2a3-15de86d1fc2d}
01:31:00: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:31:00: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:31:00: Audio Encoding: AAC
01:31:00:     bitrate: 128
01:31:00: Using bitmap image
01:31:00: Using text output
01:31:00: Using Monitor Capture
01:31:00: Video Encoding: x264
01:31:00:     fps: 25
01:31:00:     width: 1120, height: 700
01:31:00:     preset: veryfast
01:31:00:     CBR: no
01:31:00:     CFR: yes
01:31:00:     max bitrate: 650
01:31:00:     buffer size: 650
01:31:00:     quality: 8
01:31:02: Using RTMP service: Twitch / Justin.tv
01:31:02:   Server selection: rtmp://live-ams.justin.tv/app
01:31:03: Total frames rendered: 66, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:31:03: Total duplicated frames: 0 (0.00%)
01:31:04: SO_SNDBUF was at 8192
01:31:04: SO_SNDBUF is now 65536
01:31:04: RTMPPublisher::SocketLoop: Aborting due to loop exit
01:31:04: Number of times waited to send: 0, Waited for a total of 0 bytes
01:31:04: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
01:31:04: =====Stream End: 2013-05-14, 01:31:04=================================================
01:31:11: =====Stream Start: 2013-05-14, 01:31:11===============================================
01:31:11:   Multithreaded optimizations: On
01:31:11:   Base resolution: 1680x1050
01:31:11:   Output resolution: 1120x700
01:31:11: ------------------------------------------
01:31:11: Loading up D3D10...
01:31:11: Playback device {0.0.0.00000000}.{2cadf44a-82a8-4c50-b2a3-15de86d1fc2d}
01:31:11: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:31:11: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:31:11: Audio Encoding: AAC
01:31:11:     bitrate: 128
01:31:11: Using bitmap image
01:31:11: Using text output
01:31:11: Using Monitor Capture
01:31:11: Video Encoding: x264
01:31:11:     fps: 25
01:31:11:     width: 1120, height: 700
01:31:11:     preset: veryfast
01:31:11:     CBR: no
01:31:11:     CFR: yes
01:31:11:     max bitrate: 650
01:31:11:     buffer size: 650
01:31:11:     quality: 8
01:31:17: Total frames rendered: 131, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:31:17: Total duplicated frames: 0 (0.00%)
01:31:17: =====Stream End: 2013-05-14, 01:31:17=================================================
01:31:17: Using automatic low latency mode
01:31:17: =====Stream Start: 2013-05-14, 01:31:17===============================================
01:31:17:   Multithreaded optimizations: On
01:31:17:   Base resolution: 1680x1050
01:31:17:   Output resolution: 1120x700
01:31:17: ------------------------------------------
01:31:17: Loading up D3D10...
01:31:17: Playback device {0.0.0.00000000}.{2cadf44a-82a8-4c50-b2a3-15de86d1fc2d}
01:31:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:31:17: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:31:17: Audio Encoding: AAC
01:31:17:     bitrate: 128
01:31:17: Using bitmap image
01:31:17: Using text output
01:31:17: Using Monitor Capture
01:31:17: Video Encoding: x264
01:31:17:     fps: 25
01:31:17:     width: 1120, height: 700
01:31:17:     preset: veryfast
01:31:17:     CBR: no
01:31:17:     CFR: yes
01:31:17:     max bitrate: 650
01:31:17:     buffer size: 650
01:31:17:     quality: 8
01:31:19: Using RTMP service: Twitch / Justin.tv
01:31:19:   Server selection: rtmp://live-ams.justin.tv/app
01:31:20: SO_SNDBUF was at 8192
01:31:20: SO_SNDBUF is now 65536
01:32:49: Total frames rendered: 2299, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:32:49: Total duplicated frames: 0 (0.00%)
01:32:49: RTMPPublisher::SocketLoop: Aborting due to bStopping
01:32:49: Number of times waited to send: 0, Waited for a total of 0 bytes
01:32:49: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
01:32:49: =====Stream End: 2013-05-14, 01:32:49=================================================
01:34:26:
01:34:26: Profiler results:
01:34:26:
01:34:26: ==============================================================
01:34:26: frame - [100%] [avg time: 8.359 ms] [avg calls per frame: 1] [children: 94.3%] [unaccounted: 5.67%]
01:34:26: | scene->Preprocess - [80.5%] [avg time: 6.726 ms] [avg calls per frame: 1]
01:34:26: | video encoding and uploading - [13.9%] [avg time: 1.159 ms] [avg calls per frame: 1] [children: 13.5%] [unaccounted: 0.395%]
01:34:26: | | CopyResource - [0.144%] [avg time: 0.012 ms] [avg calls per frame: 0]
01:34:26: | | conversion to 4:2:0 - [0.191%] [avg time: 0.016 ms] [avg calls per frame: 0]
01:34:26: | | call to encoder - [13%] [avg time: 1.088 ms] [avg calls per frame: 0]
01:34:26: | | sending stuff out - [0.12%] [avg time: 0.01 ms] [avg calls per frame: 0]
01:34:26:
VoD : http://twitch.tv/shade_cst/b/403206967
Krazy said:
Post again if the issue isn't resolved, but it should be. It better be.
dodgepong said:
Is that a threat? o_O
Now I am in a big trouble ! :O !
dwyrin
Ok. So i told the audio to force desktop audio to use video timestamps as a base for audio time, and use mic qpc timestamps and now i'm back in sync again.
Lain
Lain
It seems in some rare situations with certain hardware the desktop audio timestamps returned by the windows functions aren't correct, and using "force desktop audio to use video timestamps" option fixes the problem for them. I appreciate the info though.
Shade
Indeed, thanks for the answer Jim.
And thank you Dwyrin, we had the same exact issue and the "force desktop audio to use video timestamps" fixed it. :)
