badbadrobot
Hey guys. So I just setup a second pc to help capture, encode and stream so my gaming computer would have less CPU usage. Now that I have it all setup, I have another problem. I'm having a really hard time setting up the audio so it captures my computer sounds, my teamspeak collaboration, and my headset microphone (logetich G930's USB).
I tried running an the audio jumper cable provided by my LGHD and ran it from my motherboard audio to the stream PC's audio LINE IN, but then I can't broadcast/capture my USB headset. I then tried using Virtual Audio Cable, but then I get about a half second delay on all audio using 3 virtual audio cables. Thats a big no no.
Also, when I use the 3.5mm audio splitter, I can hear feint buzzing / interference in the stream PC.
My guess is I'm going to have to switch to another headset that only uses 3.5mm jacks. But then I still have the issue of the interference/buzzing from the splitters. And I'm still not sure how to capture the mic at that point. Ugh.
Any suggestions on how I should set this up? Anyone that has had this issue before? If it's gonna be this much hassle, I might as well just stick with the single PC setup.
