nfun45
This generally happens more frequently when the webcam is being used.
Sample: http://www.twitch.tv/nfun45/b/553653181
Thanks, Jim. I believe this is what you're looking for? I've used OBS Log Analyzer and this is what I'm given: linkHm, I need a different log file if that's okay. Instead of giving me the file, use the help menu. Your logs can be accessed in the application via the Help menu ->Log Files menu item. Give me the last log file where this happened. I definitely want to figure out what's going on here and what sort of system you have because this is very unusual.
I've tested 44.1kHz with OBS v0.625b, but the audio/video starts off desynced.Okay, here's what I want you to do, first, I want you to set your audio to 44.1khz in encoder settings. Then try OBS again.
Then, if that doesn't help, I want you to try the latest test build: https://github.com/jp9000/OBS/releases/download/0.63b-test1/OBS_0_63b_test_1.zip -- We've changed things a little bit with audio in it. See if this helps at all (though I'm not sure if it will).
Third, if neither of those things work, I want you to try this:
1.) Open a command prompt as admin
2.) bcdedit /set useplatformclock true
3.) Restart the computer
and then let me know if that helps at all
