Apply FFMPEG -vf filters to Advanced -> Recording output
Gavin H
Hi,
Using OBS 25.0.3 (Ubuntu 20.04 pre-packaged) I'd like to apply a simple -vf "crop=1280:720:0:0" filter definition to the video which gets recorded.
My canvas is an unusual size of 1704 x 720 and I only want to record the leftmost 1280 x 720 - is this possible? I'd hoped this would be close enough: but sure enough I get
warning: 'Failed to set "crop=1280:720:0:0"
That's fair enough because those aren't valid options for libx264 :(
I appreciate that OBS works directly with the ffmpeg libraries rather than just launching a commandline subprocess - is there any way I can squeeze this in without resorting to 'Output to File' and UNIX sockets , and *another* ffmpeg process?
Cheers,
Gavin.
vulgerrity
Curious about this too. did you find a solution? Have you tried removing the quotes around your "crop" command?
