Bug Report Also having ElgatoHD/OBS issues
Jackus D
Setting up OBS on my new PC and running intro this problem:
This crash appears to have occured in the 'c:\program files (x86)\obs\plugins\dshowplugin.dll' module.
Fault address: 7196D5B0 (c:\program files (x86)\obs\plugins\dshowplugin.dll)
OBS version: Open Broadcaster Software v0.651b
CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Crashing thread stack trace:
124CF610 7196D5B0 21CD4000 1FFE0000 00001E00 000001E0 dshowplugin.dll!DeviceSource::Convert422To444+0x110
124CF630 719660F8 0090BDF0 0090BDF0 00000070 01000001 dshowplugin.dll!DeviceSource::Preprocess+0x1c8
124CF680 0090DFE3 75557C04 00000000 75557BE0 D9886A1E obs.exe!OBS::MainCaptureLoop+0xb23
124CF9C0 0090BDF5 00000000 75557BE0 D9886A1E 124CFA18 obs.exe!OBS::MainCaptureThread+0x5
124CF9C4 75557C04 00000000 DB6D5511 00000000 00000000 kernel32.dll!0x75557c04
124CF9D8 7776AD1F FFFFFFFF 7775024D 00000000 00000000 ntdll.dll!0x7776ad1f
124CFA20 7776ACEA 0090BDF0 00000000 00000000 00000000 ntdll.dll!0x7776acea
A minidump was saved to C:\Users\Jack\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-06-08_3.dmp.
List of loaded modules:
Base Address Module
I can't find the minidump when i look for some reason, sorry. any help much appreciated.
Jackus D
thanks got it working now :D had to use 'Older Software (windows)' for it to work for some reason, not Newest.
Thanks again
