Lazar Markov
Hey!
I'm setting up a streaming PC with the following relevant config:
CPU: i7 8700k @ 5GHz
Memory: 1x8GB DDR4 2400MHZ
Capture card: Elgato HD60 PRO
OS: Win 10 64bit
I try to encode at 1080p/60fps, however the "fastest" preset I can use is veryfast. Anything lower and the encoder is overloaded. Honestly I was expecting a bit more out of this top-tier CPU, especially since i'm only running OBS on the streaming PC.
However, I did some reading here, and it seems that one of two things might be bottlenecking me:
Could you please shed some light on whether my assumptions hold? Also if it is the case a dedicated GPU is needed, can you elaborate on what for?
I can upload a log file later tonight when I get home, if the information provided is insufficient.
Cheers,
Lazar
OS: Win 10 64bit
- 8GB single-channel memory is insufficient?
- I don't have a dedicated GPU (or I have but it's the integrated Intel UHD 630)
Cheers,
Lazar
