Activating layers with my microphone
vxcheg
Good time everyone
I have several GIF animations (layers). This is a streaming avatar. I animate myself and plan a lot of words from a prepared animation gif. I need my microphone (when I say something) to activate a specific layer (gif animation of a talking avatar). Only when I speak. I think the essence is clear, I'm sure there is a solution (inside the OBS), but I can't find it.
Now I have a script that includes only one layer in the folder, for convenient animation switching with one button (I have it on the numeric keypad)
upd: In addition, I would like the plugin (and script) to determine my voice. And did not capture the noise.
  • 2023-06-17 16-43-43 OBS 28.1.2 (64-bit, windows) - Профиль  vx - Сцены  wonderplay OBS.jpg
You want to analyze the audio signal and (correctly) choose one of those 6 layers to show based on the audio signal alone? The only thing I know of that is that good at analyzing audio is speech recognition. And it's heavily optimized for speech-to-text. Can't do anything else. Probably a lot of research and hard-coding for that one application (and more recently, AI training, which also can't be reused), that would have to be repeated for a different application.
If anyone else knows of a general-purpose version of that concept, I'd be interested too!
Originally, before seeing your list of layers, I thought you had animated a bunch of words and wanted your avatar to lip-sync based on that. That *might* be in the realm of possibility, if you could animate enough words to cover the vast majority of what you're likely to say, and then give it the output of a (good!) speech-recognition program. You'd have to delay everything though, to match the time it takes for the speech-recognition to figure it out. It'd probably be recognizable, but still rough unless you could animate and detect phrases and sentences instead, which is even *more* animation work and more live delay.
Or, you could use the direct lip-sync and other tracking that some VR rigs have now, and render the entire (rigged) model in real-time with those inputs.
vxcheg
Thanks
The described options look complicated and it seems I did not fully understand. Synchronization with words is not needed. I would like to do it on a simple level like that.
When the microphone is active (the lower noise threshold is cut off), it automatically activates and shows the layer I need (looped animation of the talking mouth).
When the microphone is not active (for example, less than -20 dB on the volume scale), then this layer is hidden.
It is necessary that the layer is shown only when I speak.
Ah! Okay. So you really only need two states, possibly with some hysteresis between them to avoid it flipping back and forth with a constant audio level. The Advanced Scene Switcher plugin can do that!
Of course, you can tweak that however you need. I'd consider the "only on change" checkbox to be important; that keeps it from running constantly while the condition remains true.
vxcheg
This is wonderful! I managed to set it up the way I wanted. Thank you very much for the prompt advice.
