Acri Resized
Acri Resized 1.0
Alva
I feel a lil bit dumb.....
i extract the folder in /user/appdata/roaming/obs-studio/data/obs-studio/themes
restart OBS but the Theme isnt shown... what i doing wrong ?
You're extracting to the wrong place.
You need to extract to where OBS Studio is installed, the default being C:\Program Files\obs-studio. The adjusted path in this case would be:
C:\Program Files\obs-studio\data\obs-studio\themes
In this example, you will need to be able to elevate to administrator.
Adjust as necessary on your system.
Hope this helps.
--Katt. =^.^=
YorVeX
Can we get an update for OBS 30 please? E.g. the status bar is broken:
Also the new "edit scene filters" button is missing and therefore looks out of place:
