Hello, I'm not brand new to streaming. But i AM new to streaming 720p+ good quality.
I recently upgraded my internet from 25mb down 2.5up to 50mb down 10mb up, allowing me to stream 720p and 1080p (1080p frowned upon by twitch, and most users cant even watch the stream live because of the 10mb buffer)
Anyways my question is in regards to my video quality below
http://www.twitch.tv/l0g1stixgaming/b/443632200
I am doing the gameplay + rendering / streaming all on the same computer. Specs are
Intel Core i7 3770k @ 4.7GHz (delidded, temps are 55-61c under load)
Asus Sabertooth Z77
SLI GTX 670 2GB @ 1136 / 3404 (temps are fine and clock isn't throttling)
16GB Corsair Dominator @ 1333MHz
120GB Mushkin Chronos
11.5MB Upload (Streaming @ 4000 because of twitch frowning upon anything higher)
When i watch my streams in full screen, it seems like there is a foggy haze, almost like a pixelation. You don't see it if you dont watch it in full screen. Does this have to do with my monitor (Which is by no means anything good). Or a setting that i can change? If increasing the bitrate is what will solve the issue, then i guess i am stuck with it
Downscaling to 1280x720 from 1920x1080
AAC /w 128bitrate
Using Lanczos Filter /w 60 FPS for smoother streaming gameplay
Using Very Fast Preset /w Above Normal Process Priority
Using Game Capture
Encoding @ 4000 / 4000 QB Value @ 10
Now i do have Dxtory, and i have attempted to use that with OBS, It does work. But it seems like the OBS Game Capture has put the once great Dxtory + Streaming Software to shame. So i've been using OBS by itself
Asus Sabertooth Z77
AAC /w 128bitrate
Using Game Capture
