Question / Help 768p problem - how to make it 720p?
redock
Hi guys!
I have 768p screen, and I want to stream in 720p, but when im changing it in that window:
It's cutting borders. And in the window below, there's only 1.25. 1.5 scale etc.
How can I change it?
RikiLayn
Hey,
Umm change the resolution to 720p, then exit settings. Click Preview Stream, then Edit Scene, then you can click on the source you want to adjust. Now drag it/it's corners to adjust size, and position relative to your intended stream resolution. That should be what you needed, I think.
