Bug Report 720p fit to screen doesnt work
godlesas
I play on 1360x768 monitor and I stream at 720p. When I try to fit to screen on game capture mode it just zooms in 1360x768 resoution, it won't fit it. Monitor capture works as it should but I really need to use game capture mode
Jack0r
The Helping Squad
Thanks for reporting back. And yes for gamecapture sources, using stretch image to screen is correct.
The GameCapture source will use your obs resolution as its base so the game will fit into obs that way.
(If other people read this thread, make sure you dont need to check "ignore aspect ratio" as this would stretch the image and you would loose quality)
