Hi. For whatever reason, my stream seems to be running well under 60fps, possibly even under 30. I am not sure what is causing it. I have posted a VOD of sc2 workers mining as well as my system specs, a speedtest, and a log. My CPU usage is quite low during gaming + streaming, and game fps never drops below 100. Thank you for any help in advance!
I am using:
-game capture for sc2
-quality: 10
-veryfast
-3000 bitrate/buffer
http://www.twitch.tv/gregsc2/b/380578656
System Specs:
-I7-3770K w/ Corsair H80 Cooler
-32gb ram
-Win 7 Ultimate x64
-GTX 670
-256gb ocz ssd
I am using:
-quality: 10
-veryfast
System Specs:
-32gb ram
-Win 7 Ultimate x64
-GTX 670
-256gb ocz ssd
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
CPU Speed: 3500MHz
Physical Memory: 32721MB Total, 28296MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1920, 1200}
monitor 2: pos={1920, 62}, size={1680, 1050}
monitor 3: pos={-1680, 80}, size={1680, 1050}
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 670
Video Adapter Dedicated Video Memory: 2091581440
Video Adapter Shared System Memory: 2147479552
Adapter 2
Video Adapter: NVIDIA GeForce 210
Video Adapter Dedicated Video Memory: 1026162688
Video Adapter Shared System Memory: 3221114880
Base resolution: 1920x1200
Output resolution: 1280x800
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (ASUS Xonar Essence STX Audio Device)
Using auxilary audio input: Microphone (ASUS Xonar Essence STX Audio Device)
Audio Encoding: AAC
bitrate: 128
Using text output
Using bitmap image
Using bitmap image
device: Microsoft® LifeCam Cinema(TM),
device id \\?\usb#vid_045e&pid_075d&mi_00#7&31bd0065&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
chosen type: YUY2, usingFourCC: false, res: 640x480 - 640x480, fps: 7.5-30, fourCC: 'YUY2'
Using directshow input
Using Window Capture
Using bitmap image
Using graphics capture
x264: profile High, level 4.0
Video Encoding: x264
fps: 60
width: 1280, height: 800
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 3000
quality: 10
SharedTexCapture hooked
Server selection: rtmp://live-3c.justin.tv/app
bufferTime: 1777, outputRateWindowTime: 1000, dropThreshold: 2277
Total frames rendered: 29660, number of frames that lagged: 5 (0.02%) (it's okay for some frames to lag)
x264: frame I:119 Avg QP:21.16 size:137264
x264: frame P:8301 Avg QP:26.41 size: 7609
x264: frame B:21181 Avg QP:32.76 size: 1001
x264: consecutive B-frames: 3.9% 1.3% 2.8% 92.0%
x264: mb I I16..4: 14.9% 22.6% 62.6%
x264: mb P I16..4: 0.9% 1.1% 0.6% P16..4: 10.5% 3.4% 2.3% 0.0% 0.0% skip:81.2%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 2.2% 1.1% 0.2% direct: 0.7% skip:95.8% L0:37.1% L1:45.7% BI:17.2%
x264: 8x8 transform intra:35.7% inter:28.2%
x264: coded y,uvDC,uvAC intra: 73.9% 49.1% 30.6% inter: 2.4% 2.0% 0.8%
x264: i16 v,h,dc,p: 36% 30% 27% 7%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 12% 33% 8% 6% 6% 5% 8% 9%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 19% 17% 9% 8% 7% 7% 8% 9%
x264: i8c dc,h,v,p: 56% 24% 16% 4%
x264: Weighted P-Frames: Y:0.1% UV:0.1%
x264: kb/s:1632.88
Profiler results:
frame - [100%] [avg time: 4.757 ms] [avg calls per frame: 1] [children: 28.7%] [unaccounted: 71.3%]
| scene->Preprocess - [5.3%] [avg time: 0.252 ms] [avg calls per frame: 1]
| video encoding and uploading - [23.4%] [avg time: 1.112 ms] [avg calls per frame: 1] [children: 23%] [unaccounted: 0.336%]
| | CopyResource - [0.294%] [avg time: 0.014 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.252%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | call to encoder - [22.3%] [avg time: 1.063 ms] [avg calls per frame: 0]
| | sending stuff out - [0.147%] [avg time: 0.007 ms] [avg calls per frame: 0]
