You can ignore this post and go down to my last one: viewtopic.php?f=6&t=4412#p24133
32bit OBS works fine for me, just tried using the 64bit and I get this while previewing stream:
After cliking 'OK' OBS crashes:
This crash appears to have occured in the 'c:\program files (x86)\obs\64bit\obs.exe' module.
Fault address: 000000013F3F9B34 (c:\program files (x86)\obs\64bit\obs.exe)
OBS version: Open Broadcaster Software v0.472b
Crashing thread stack trace:
00000000124DF888 000000013F3F9B34 0000000000000000 0000043800000780 3F80000000000000 3F80000000000000 obs.exe!GlobalSource::Render+0x4
00000000124DF890 000007FEF2FF3A1A 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obsapi.dll!Scene::Render+0x8a
00000000124DF8C0 000000013F40BFDD 00000013B2910C01 0000000000000001 0000000000000001 0000000000000001 obs.exe!OBS::MainCaptureLoop+0xbbd
00000000124DFF30 000000013F40A850 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureThread+0x10
00000000124DFF60 000000007714652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7714652d
00000000124DFF90 000000007737C521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7737c521
A minidump was saved to C:\Users\tesla\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-05-23_1.dmp.
List of loaded modules:
Base Address Module
Here I have provided the log:
Extrapolated from that log:
Using directshow input
Warning -- OBS::CreateImageSource: Could not find image source class 'WindowCaptureSource'
Warning -- OBS::AddGlobalSourceToScene: Could not find global source 'pandora'
Warning -- OBS::CreateImageSource: Could not find image source class 'MonitorCaptureSource'
Warning -- Could not create image source 'localdesktop' in scene 'Desktop'
Before previewing the stream, when I go into global sources and try to edit scenes that involve some sort of window capture, nothing happens and I am unable to edit them (with no crash).
Base Address Module
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
CPU Speed: 3500MHz
Physical Memory: 16330MB Total, 11654MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 2: pos={1920, 0}, size={1920, 1080}
monitor 3: pos={-1920, 0}, size={1920, 1080}
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 680
Video Adapter Dedicated Video Memory: 4232773632
Video Adapter Shared System Memory: 3998572544
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (5- Razer Banshee)
Audio Encoding: AAC
bitrate: 128
DShowPlugin: No audio pin, result = 80004005
device: Logitech HD Webcam C270,
device id \\?\usb#vid_046d&pid_0825&mi_00#7&2ff2ef02&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
chosen type: RGB24, usingFourCC: false, res: 320x240 - 320x240, fps: 5-30, fourCC: 00000000
x264: profile High, level 3.2
Video Encoding: x264
fps: 45
width: 1280, height: 720
preset: veryfast
CBR: yes
CFR: no
max bitrate: 2700
