Bug Report 32bit obs crashes when trying to stream ps3
Polley
i have uploaded a crash dump file
any help would b much appreciated
  • OBSCrashLog2014-03-23_3.txt
Lain
Lain
What capture device specifically are you using? Definitely not normal.
kasaisaru
Im having the same issue with both 32 and 64 bit versions. My gamcap is a roxio hd pro. I attempted to stream for the first time. Streaming is not a big deal just want the option.
Lain
Lain
Shouldn't work with roxios directly at the moment -- shouldn't crash, but they shouldn't be able to capture. Well, depending on the actual device model. I think there is a roxio that can work with OBS, though not entirely sure.
They will be added in future versions however no matter what.
XtraSurs
The Roxio Standard does indeed work with OBS. There is problems having another device on the screen with it at the same time though. One or the other will show up, then it will crash. If you are really wanting to stream right away instead of waiting for the rewritten obs, get a standard and sacrifice no facecam.
