mintograde
I just switched to 0.541b and did a quick test stream with game capture. After ~30 minutes, OBS crashed with an Out of Memory error. The game being streamed was Warsow 1.03 (x64). Link to VOD (intermittent freezing is due to unrelated packet loss).
The scene used for the stream was created in a previous test build, but I replaced the previous Game Capture source with a new one after installing 0.541b.
I grabbed a screenshot of the Process Explorer graphs for the 15 minutes leading up to the crash:
Relevant log file:
System Specs:
22:02:49: Open Broadcaster Software v0.541b - 32bit (´・ω・`)
22:02:49: -------------------------------
22:02:49: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
22:02:49: CPU Speed: 3292MHz
22:02:49: Physical Memory: 4095MB Total, 1618MB Free
22:02:49: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
22:02:49: monitor 1: pos={0, 0}, size={1920, 1080}
22:02:49: Windows Version: 6.1 Build 7601 S
22:02:49: Aero is Disabled
22:02:49: OBS Modules:
22:02:49: Base Address Module
22:02:49: 01110000 OBS.exe
22:02:49: 610F0000 OBSApi.dll
22:02:49: 60EB0000 DShowPlugin.dll
22:02:49: 6B690000 GraphicsCapture.dll
22:02:49: 60E90000 NoiseGate.dll
22:02:49: 60E70000 PSVPlugin.dll
22:02:49: 65500000 SC2SceneSwitcher.dll
22:02:49: ------------------------------------------
22:02:49: Adapter 1
22:02:49: Video Adapter: NVIDIA GeForce GTX 560
22:02:49: Video Adapter Dedicated Video Memory: 1025966080
22:02:49: Video Adapter Shared System Memory: 3220779008
22:02:49: =====Stream Start: 2013-07-12, 22:02:49===============================================
22:02:49: Multithreaded optimizations: On
22:02:49: Base resolution: 1920x1080
22:02:49: Output resolution: 1920x1080
22:02:49: Loading up D3D10...
22:02:49: Playback device Default
22:02:49: Using desktop audio input: Speakers (Realtek High Definition Audio)
22:02:49: Using auxilary audio input: Microphone (Realtek High Definition Audio)
22:02:49: Audio Encoding: AAC
22:02:49: bitrate: 128
22:02:49: Using graphics capture
22:02:49: Video Encoding: x264
22:02:49: fps: 25
22:02:49: width: 1920, height: 1080
22:02:49: preset: veryfast
22:02:49: CBR: no
22:02:49: CFR: no
22:02:49: max bitrate: 2300
22:02:49: buffer size: 2300
22:02:49: quality: 10
22:02:52: SharedTexCapture hooked
22:03:13: Capture window 0x006F0CDE invalid or changing, terminating capture
22:03:15: Total frames rendered: 630, number of frames that lagged: 5 (0.79%) (it's okay for some frames to lag)
22:03:15: =====Stream End: 2013-07-12, 22:03:15=================================================
22:04:09: =====Stream Start: 2013-07-12, 22:04:09===============================================
22:04:09: Multithreaded optimizations: On
22:04:09: Base resolution: 1920x1080
22:04:09: Output resolution: 1920x1080
22:04:09: ------------------------------------------
22:04:09: Loading up D3D10...
22:04:09: Playback device Default
22:04:09: Using desktop audio input: Speakers (Realtek High Definition Audio)
22:04:09: Using auxilary audio input: Microphone (Realtek High Definition Audio)
22:04:09: Audio Encoding: AAC
22:04:09: bitrate: 128
22:04:09: Using graphics capture
22:04:09: Video Encoding: x264
22:04:09: fps: 25
22:04:09: width: 1920, height: 1080
22:04:09: preset: veryfast
22:04:09: CBR: no
22:04:09: CFR: no
22:04:09: max bitrate: 2300
22:04:09: buffer size: 2300
22:04:09: quality: 10
22:04:11: SharedTexCapture hooked
22:05:00: Total frames rendered: 1293, number of frames that lagged: 2 (0.15%) (it's okay for some frames to lag)
22:05:00: =====Stream End: 2013-07-12, 22:05:00=================================================
22:05:20: =====Stream Start: 2013-07-12, 22:05:20===============================================
22:05:20: Multithreaded optimizations: On
22:05:20: Base resolution: 1920x1080
22:05:20: Output resolution: 1280x720
22:05:20: ------------------------------------------
22:05:20: Loading up D3D10...
22:05:20: Playback device Default
22:05:20: Using desktop audio input: Speakers (Realtek High Definition Audio)
22:05:20: Using auxilary audio input: Microphone (Realtek High Definition Audio)
22:05:20: Audio Encoding: AAC
22:05:20: bitrate: 96
22:05:20: Using graphics capture
22:05:20: Video Encoding: x264
22:05:20: fps: 30
22:05:20: width: 1280, height: 720
22:05:20: preset: veryfast
22:05:20: CBR: no
22:05:20: CFR: no
22:05:20: max bitrate: 1300
22:05:20: buffer size: 1300
22:05:20: quality: 10
22:05:21: Using RTMP service: Twitch / Justin.tv
22:05:21: Server selection: rtmp://live-mia.justin.tv/app
22:05:22: SharedTexCapture hooked
22:05:26: SO_SNDBUF was at 8192
22:05:26: SO_SNDBUF is now 65536
Error: Out of memory while trying to allocate 17547 bytes at 61107C62
- Windows 7 Pro x64
i5 2500k
GeForce GTX 560
8GB Ripjaws DDR3 at 8-8-8-24
