Scale To Sound
Scale To Sound 1.2.5
  • Fixed compatibility with OBS 31.1
  • Like
Reactions: kslen
  • Fixed crash on exit (#6)
  • Improved performance and effect loading failure handling a bit
  • Love
Reactions: Phantom_Hugger
  • Added a timeout to reset size when no audio data is received
  • Added positional alignment options
  • Properly let audio sources being deleted be destroyed
  • Like
Reactions: BOLL
  • Fixed a bug where deleting the source this filter gets audio data from did not destroy that source
  • Like
Reactions: BOLL
Changes
  • Added an audio ceiling option (at what dB level should the filter scale before it reaches max size)
  • Like
Reactions: BOLL
If updating from a 0.x.x release, delete the files of the previous version you have installed
On Windows those are
  • (OBS install folder)\obs-plugins\32bit\obs-scale-to-sound.dll/.pdb
  • (OBS install folder)\obs-plugins\64bit\obs-scale-to-sound.dll/.pdb
  • (OBS install folder)\data\obs-plugins\obs-scale-to-sound
For the other platforms just delete the folder obs-scale-to-sound
on macOS: /Library/Application Support/obs-studio/plugins
on Linux: ~/.config/obs-studio/plugins
Changes
  • Added a smoothing option
  • Like
Reactions: BOLL
