Added Spanish translations (#85) Added German translations (#86) Fixed unresponsiveness in some cases when capturing failed Fixed WirePlumber 0.5.11 pausing targeted streams when sources are destroyed
Added Multiple Applications mode (capture/exclude multiple apps per source) Added Brazilian Portugese locale (#62) CMake uses GNUInstallDirs now (#69)
Added french locale (#57) Fixed some audio crackling (#55)
Fix incompatibility with OBS Studio 28 and 29 (#50)
Fixed sources connecting to the default system sink when using WirePlumber 0.4.8 or older Output sources now list duplex devices (#38)
Some applications not playing audio are now shown in the targets list (#37)
Fixed device captures being unable to change target on newer versions of PipeWire Fixed device captures resetting to "Default" when opening the properties after the original target node has been lost Fixed errors when hiding/showing the sources
Added an option to the app capture source that allows choosing how to display and match targets (#21) App capture sources now use the application audio icon
Fixed the exclusion setting not being saved Fixed app capture not working with Mumble
App captures now filter streams using the app's binary name, you may need to reconfigure some sources App captures now allow setting them to target apps not in the selection list
